Question about HP Pavilion dv6000z Notebook
Vertical lines in my laptop screen
Hello! I've been using my Compaq Presario (M2223AP) Laptop for 2 years now, then all of a sudden I saw 2 vertical lines on the screen. 1 line is a clear red line (but not so thick & dark) located about 1/3 from the left of the screen while the other is a very faint (thin, almost transparent) line located about 1/5 from the right of the screen. I think it might be a monitor problem. I'm not very good in fixing computers so I have not done anything about it yet. I'd appreciate your help very much. Thanks! I just recently got a new HP Pavilion dv6000 Entertainment PC notebook and after 3 days a thin white line is on the right side of the screen. I have not done anything to get rid of it, what do I do?
  • veeratumma Jan 07, 2009
    Hi All,
    Recently my note book also showing 10to 15 very thines 1cm wide on extreem bottom of the screen.Pls advise any solutions for this.
  • hardahmed Mar 18, 2009
    Mine is a tablet pc hp tx2030..almost an year of usage i get a one pixel red vertical line on the left side of the screen around 1/3 of an inch..My guessing is that since the notebook is used heavily it could be the VGAs fault of overheating and displays artifacts on the screen and it could also mean the LCD is faulty...
    Problem Solver:
  • 8 Answers
Try using an external monitor,every laptop has a blue VGA connector,just connect a monitor there and check is those lines
disappear,if it does,probably you have a problem with the internal connection of your monitor to the motherboard.
Posted on Sep 07, 2008
    Problem Solver:
  • 11 Answers
HP Pavilion DV6000 Notebook main problem's are Power Problem, Vista Error etc..
For these problems you can visit a link by just Click Here .
For any other problems with this Notebook you can Click Here
Posted on Oct 08, 2010
    Problem Solver:
  • 13 Answers
If you don't have any external Monitor with you, you can start the notebook and keep on tap F10. You will get BIOS Setup Utility. You can check whether the lines are present or not. If you find the same lines in BIOS setup utility screen, the defnitely we can confirm that it is a hardware issue with the notebook LCD. At that point, you can use your notebook factory warrenty and send the notebook for free mail in service.
If you don't find the lines in BIOS, then it is a software issue. Just reinstall the Video Drivers and that may resolve the issue.
Posted on Sep 09, 2008
Have you tried hooking it up to an external monitor?
This would ensure that it's the screen and not the video card..
If you do that and you receive a good picture then it could be something as simple as a loose video cable. Or it could also mean something like a bad video card or the expensive one, a bad screen.
Mar 08, 2009 | HP Pavilion dv8000t Notebook
I had the same problem - sent it in to Acer and they replaced the LCD for 500 bucks!
Aug 18, 2008 | Acer Aspire 9500 Notebook
the lcd (liquid crystal display) is damaged at this time, nor the inverter, that is of course inside of your pc, im afraid you need to send this to a repair shop
cheers
Aug 12, 2008 | Dell Inspiron XPS M140 Notebook
if this line is there during boot up then it is a monitor problem usually. but if it is not then it is a problem with your windows files. you could try reinstalling your windows from the disks you were given with it? otherwise i will look into it. email me if you need more help. milliprowd21@yahoo.co.uk
thanks
matt
Jul 30, 2008 | Acer TravelMate 2300 Notebook
My understanding is that you have 2 laptops with the same problem, if that is the case, you need to replace the lcd. When you have lines on lcd's, that is a sign of a bad lcd.
Jun 10, 2008 | Toshiba G15-AV501 Qosmio Notebook
There can be 3 possible reasons for this
1)Screen connector cable is loose. You can try to re-seat it and see if works.
2)display card problem. Connect your laptop to an external monitor and see if the problem persists. If it does not then
3)You will need to get a replacement LCD screen.
Hope this helps!
May 04, 2008 | Dell Inspiron 6400 Notebook
what i recommend you to test is to press behind your monitor and see that the line goes off or not.If it does..that mean you have a loose connection,it can be fix.Incase no then you have problem with your LCD.Normally if its LCD problem then you fix this problem,all you have to do is change the LCD.
goodluck,takecare.
May 04, 2008 | Toshiba Satellite P30 P35 Series Notebook
thats monitor problem dude, better go to the nearest repair center of your toshiba to assist you bout this problem.
Mar 10, 2008 | AMD Compaq Presario Turion 64 Notebook
Check it on External monitor prior to replacing the screen.. If the problems there as well its not the screen..
Feb 06, 2008 | Toshiba Satellite P35-S609 Notebook
you could try and download a new display driver from here http://h10025.www1.hp.com/ewfrf/wc/product?cc=mx&lc=en&dlc=es&product=499234 if that dosent help Id imagine it is the screen that is at fault.
Jun 09, 2007 | Compaq Presario Laptop
HP Pavilion dv6000z Notebook Logo
1,038 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
