HP PHOTOSMART PLUS B209A All-In-One Printer Logo
Posted on Aug 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ihave a B209a printer. Has been working well till now. Now I have print jobs in the print queue. The status reflects "paused" but I cannot get it "restarted". I never paused the print jobs
Anonymous
Level 2:
  • Expert 155 Answers
  • Posted on Aug 21, 2011
Anonymous
Expert
Level 2:
Answers
155
Questions
0
Helped
37950
Points
523
Try to cancel all print jobs, if it still there or wont remove turn of the printer and cancel again all print jobs
How to resume Kyocera KM4050 kx if it shows paused from printing source e.g computer?
If the status from the printing source writes "paused" despite the green tick, there are a few possible reasons why this may be happening:
  1. Printer software: The printer software may be set to pause the print job. Check the printer software settings to see if there are any options to pause the print job.
  2. Print queue: The print job may be paused in the print queue. Check the print queue on your computer or device to see if the print job is paused. If it is, try resuming the print job.
  3. Paper jam: A paper jam can cause the printer to pause the print job. Check the printer for any paper jams and clear them if necessary.
  4. Low ink or toner: If the printer is low on ink or toner, it may pause the print job. Check the ink or toner levels and replace them if necessary.
  5. Connectivity issues: Connectivity issues between the printer and the computer or device can also cause the print job to pause. Check the connection between the printer and the computer or device and make sure it is properly established.
If you're unsure about any of these steps or are not comfortable troubleshooting the printer on your own, it's always best to contact the printer manufacturer or a professional technician for assistance. They can help diagnose and fix the problem safely and effectively.
How do I take Canon imageCLASS D320 All-In-One Laser Printer off from "paused" status?
On the printer properties on the computer there will be a paused option (Normally marked as "Pause Printing") in the printer drop down menu on the Printer Queue screen. Click this to remove the tick next to it and it should start printing again.
2answers
Key is flashing. Internet blue light is on. Printer gets signal for print job but won't print until I USB connect it to my Macbook OS 10.6.
Follow the steps below to resolve the issue
The print queue and Dock printer icon
When you start a print job, you will see your printer icon appear in your Dock. Click the Printer icon to open the print queue, which is a list of print jobs that are printing, on hold, or paused. The print queue will also display messages sent from the printer.
You can alternatively open the print queue from the Print & Fax pane of System Preferences.
printer%20queue.png In the Print Queue toolbar you have these buttons:
  1. Delete - Deletes the selected print job.
  2. Hold / Resume - Will hold / resume the selected print job.
  3. Job Info - Shows details of the selected print job, such as job name, status, Completed, Job Message, and so forth.
  4. Pause / Resume Printer - To Pause / Resume the Print Queue.
  5. Supply Levels - Will drop down the Supply Levels sheet showing you the levels of ink / toner your printer has.
  6. Printer Setup - Lets you configure the printer's name and location details.
  7. Printer - Sets the Print Queue window into Printer mode.
  8. Scanner - Visible if you have a multi-function printer connected via USB. Click it to set the Print Queue into Scanner mode.
You can see what your print job looks like with Quick Look. Click the arrow on the print job just to the left of the Status column or select the print job and press the Spacebar.
From the Print Queue menu bar, the "Printer" menu has these additional options:
  1. Customize Toolbar... - Used to add and remove item from the Print Queue's toolbar.
  2. Make Default - Will set the printer pertaining to this Print Queue your default printer.
  3. Print Test Page - Will send the CUPS Printer Test Page to your printer.
  4. Network Diagnostics - Will bring up the Network Diagnostics application, used to check each layer of your network connection.
  5. Log & History - Used to open the Console application and show you the log entries for your current and past print jobs.
  6. Show Printer List - Will open the Print & Fax System Preference showing you the list of Print Queues.
From the Print Queue menu bar, the "Jobs" menu has these additional options:
  1. Show / Hide Completed Jobs - Will alternate Show / Hide in the Print Queue all completed printer jobs and completed functions, like checking the supply levels of your printer.
  2. Show Everyone's / My jobs - Will alternate showing Everyone's / My print jobs.
You can control-click (or right-click) your printer icon in the Dock for this convenient menu:
printer%20proxy%20dock%20menu.png From the Dock menu you can see your printer's status, toggle Pause and Resume Printer, Auto Quit (once print job completes) on / off, and from the Options sub-menu you can toggle Keep in Dock on / off.
My print job won't print in color. even when I select "color" on the "options" menu of PowerPoint.
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
1helpful
Printer has always worked great, gets lots of office usage, but now suddenly won't feed; the machine will turn on, when the print queue is activated, but just "clicks", won't feed and the error...
Try The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
  • Connectivity :
1helpful
I have an HP Photosmart c4180 all-in-one printer. I just tried to install an HP98 cartridge refilled at Office Max. The printer responds with a message: "Cartridge not recognized". There is no...
  • Connectivity :
Trying to print, but Status Paused is showing
Hi
Thanks for using FIxYa. Please turn the printer off and then cancel all the print queues pending in the bottom toolbar by double clicking on the printer logo if you want to delete all the pending printing files. Now turn the printer on. If you do not want to cancel all the printing jobs then you can double click on the printer logo showing in the right side of the bottom tool bar and then right click on the printing jobs pending for printings then click on restart printing. Issue will be resolved and it will not show ‘paused status’.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
1helpful
k24674
Grand Canyon Tech
Grand Canyon Tech
