Question about Microsoft Standard Wireless Optical Mouse
Microsoft Wireless Optical mouse 2.0 Sticky central wheel
How do you clean that so it movesw smoothly? Even to take it apart?
  • Anonymous Oct 19, 2008
    The scroll-wheel doesn't spin freely. The pressure required to make it rotate sometimes "clicks" it (in it's function as a middle mouse button).
I just took mine apart to fix same problem, works much better but not sure for how long.
Quite simple to dismantle the unit.
Take the battery cover off, remove batteries.
There is a small screw in the middle of the battery cavity, you will need a very small Phillips head screwdriver.
Gently ease the base (holding circuit board) from the top shell
The wheel unit can be gently eased out of its cradle, use the small screwdriver to pop it out, watch out for the small spring between base and wheel unit, don't lose it
You can disconnect the wheel unit from the circuit board by unhooking the small plug connector
Now defluff, then clean the wheel - I used a tiny amount of turps on a cloth, anything similar should work. If you look closely the reason the wheel won't roll smoothly is that the gel ring on the wheel is too close and rubs at the front and back of the cradle. Once grime builds up, this problem makes the wheel unusable. Roll the wheel back and forth along a clean surface once cleaned, should start rolling freely again.
I also unscrewed the top shell from the mouse buttons (all one piece, pinch the plastic pegs in the centre of the shell together to release) and cleaned the whole unit up before putting it back together
Don't forget the spring when putting the wheel unit back. When screwing the base to the top shell make sure there is no play between the two parts before you put the batteries back in, mine was a bit tricky to get tight again but worked fine second attempt
Posted on Oct 20, 2008
Microsoft wireless mouse 1000 fix scroll wheel
I had a scroll wheel problem with my Microsoft Wireless Mouse 1000 and fixed it as follows.
With the corner of a sharp Stanley knife blade, I carefully peeled off the large pad at the back of the base of the mouse and removed the two screws that are hidden under it. Next I removed the screw located under the batteries. This allowed the top and bottom of the mouse to be separated. I cleaned out the inside with a small paintbrush and then sprayed a small amount of isoproplyl alcohol into the sensor at the right of the wheel. Now it's as good as new.
Aug 27, 2012 | Microsoft Wireless Optical Mouse USB...
Cleaning the Microsoft Wireless Mobile Mouse 4000
I disassembled my Microsoft Wireless Mobile Mouse 4000.
You need a set of precision screwdrivers to do this.
1. Peel up the teflon pad on the bottom of the mouse with a flat head screwdriver. Leave the other (the one under your fingertips) alone.
2. That will reveal a tiny silver screw. Remove that and then lift the gray upper section up from the back, then pull it free by moving it toward the back. The clips up at the front go in a forward direction, but they are not clipped in. You could just shake it free.
3. There are 4 tiny black screws. 2 at the front and 2 at the back. Remove them.
4. Use a flathead screwdriver to pry the retainer clip from the back of the mouse. It's just held on by a couple of little nubs. Don't break it. Be gentle with this part.
5. Now, the mouse can come apart. You need to pull the bottom of it free at the back and then slide the entire bottom section back. There is a little piece of circuit board that sticks out underneath the right-click area that will get hung up on the upper shell if you try to pull it straight down. This will take a little bit of prying since it's all clipped together, but it will come loose.
That's it. I didn't take any of the inner parts apart after that. I will say that my sticky scroll wheel was scraping against the upper shell. By loosening the two screws at the front, it relieved some pressure and let it run more smoothly. I didn't actually have to take it all apart after step 2 in order to fix that issue.
Mar 08, 2012 | Microsoft Wireless Optical Notebook Mouse...
How to activate wireless notebook optical 3000
The inside of the mouse may have collected enough dust to interfere with the rollers. If you turn the mouse over, there is a door that surrounds the little roller wheels you can remove. Remove the door and clean the inside out with canned air and a very soft brush. Be sure to clean the dust from around the wheels, etc. Reassemble the wheel section and all should be OK.
Jan 26, 2010 | Microsoft Wireless Notebook Optical Mouse...
Wireless opitcal microsoft mouse 2000 sticking when rolling
Jan 06, 2010 | Microsoft Wireless Notebook Optical Mouse...
The scroll button on my mouse is stuck, will not turn.
If the scroll button is sticky, take a q-tip and clean the wheel off on the outside and as much in the inside as possible. Dampen the q-tip with water.
If that doesnt' work, look for screws that hold the mouse together, unscrew the screws and take the mouse apart. At that point clean the scroll button and then put everything back together.
If the mouse still doesn't work properly then at that point, you'll need to get a new mouse.
Jan 01, 2010 | Microsoft Wireless Laser Mouse 5000
The wheel on my Microsoft mouse does not roll smoothly, how do I clean it?
Open it up, scrape the crud off the three wheels underneath with your fingernail, then swab them with a Q-tip and rubbing alcohol.
Oct 24, 2009 | Microsoft Standard Wireless Optical Mouse
Left mouse button doesn't work
You need to check the mouse settings.
If the mouse settings are ok. Then you need to replace the mouse.
For more information please visit the below mentioned link.
http://www.microsoft.com/windowsxp/using/setup/personalize/mouse.mspx
Aug 14, 2009 | Microsoft Wireless Notebook Optical Mouse...
Microsoft mouse wheel sticky
yes it is possible but be careful doing so. There are some very tiny springs and some very delicate metal wheels and such inside that can be very easily bent. I would suggest a can of compressed air blown in and around the wheel to try and dislodge any dirt or dust that has gotten in there. You can usually find a can at staples or even home depot.
Dec 20, 2008 | Microsoft MOUSE Wheel INTELI EXPL OEM TIL...
Microsoft Wireless Optical MOuse
I've noted that certain mousepads do cause problems- it seems to be with the graphics on the pad- reflective/light/dark areas on the pad cause the different movement patterns. I'd guess a pad with a dull non-reflective & uniform color might be best.
Sep 13, 2007 | Microsoft Wireless Optical Mouse USB...
Microsoft Standard Wireless Optical Mouse Logo
4,019 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
