Question about Whirlpool Duet GHW9150P Front Load Washer
Why does it flash F 24 when i push the button to wash??
Check the screens where the water hook ups go in. You will likely have to take the blue plastic connections off but that's not hard one screw from the outside and gently tug the wires out from the thermostats. Unplug the washer first just to be safe
Posted on Jan 26, 2009
  • 725 Answers
F24 is a water temp sensor error. If the sensor reading is not within specs during the water heating portion of the wash cycle this code will come up.
1) water was too cold or hot when it filled the washer.
2) you have a bad or unplugged connection of the thermister..
3 you have a faulty thermister..
hope it helps
Posted on Sep 07, 2008
When troubleshooting my shx46a05uc bocsh diswasher it show a flashing light on the delicate/Eco button and regular wash light stays on. What does that tell me?
sounds like the electronic switch usually a Thyristor is not switching when you push the eco button, You could try disconnecting the the machine from the mains then push the buttong in and out a few times to see if the push button has a bit of dust on the contacts..
Sep 18, 2013 | Bosch 24 in. SHX46A05UC Built-In...
My Whirlpool GU2400XTP83 stopped during the wash cycle and there is a blinking light above the "light" cycle button. I can not reset the dishwasher, stop or start it.
To reset the dishwasher push in this order the,
HIGH TEMP WASH- HEATED DRY- HIGH TEMP WASH- HEATED DRY - CANCEL/OFF
the control will be reset...but more importantly how many times ina row does the light flash..it will indicate what error code its displaying??
example if it flashes 4 times then a pause then flashes 4 times again its displaying the error code#4
7 flashes then pause then 7 flashes its displaying the error code#7 ect ect
GENE
Sep 05, 2011 | Whirlpool 24 in. GU3200XTP Built-in...
Clean light is blinking, when you shut door and push start cycle nothing happens
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Mar 21, 2011 | Kenmore 24 in. 16039 Built-in Dishwasher
Dishwasher will not start. The clean light is flashing on and off. If I push the cancel button it appears to be draining but there is no water in the tub and it just continues. When I push the start...
Kevin
Jan 20, 2011 | Kenmore 24 in. 16039 Built-in Dishwasher
My dishwasher won"t wash. Help me, PLEASE???
Try pushing and holding the "Air Dry" button for at least 4 seconds. This should turn the control lock off.
Sep 14, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
I have a kenmore Elite Ultra Wash Dishwasher that won't run. The lights for the various wash and dry options come on, but when I push the start button, it flashes green three times and then goes off.
Sounds like a safety - lock is operating.
Close and press start button - keep button derpressed untill machine actually starts - maybe 8 seconds or so.
If this does not do it, unplug for 24 hours then try again.
Aug 04, 2009 | Dishwashers
LIGHTS FLASHING ON PANEL
The lights flash when the door is not shut all the way, or the sensor that detects that the door is shut is not sensing the door is shut. Try pushing in on the door while hitting the start button.
Sep 11, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Whirlpool 24 in. DU1055XTP Built-in Dishwasher
I don't know if your dishwasher is the same as mine, but this solution may be what you need. For electronic panel dishwashers made by whirlpool (mine is a whirlpool but with a kenmore name on it), some of them can be reset by pushing in sequence the Heated-Dry button followed by the Normal-Wash button, several times in a row. that is... Push Heated-Dry, then Normal-Wash, Then Heated-Dry, then Normal-Wash... Repeat until all lights light up. When all lights light up you can stop. The washer will then take 5-10 minutes to go through a diagnostics cycle, which is about 18-25 steps or so. You can bypass one step at a time by pushing the STart button. This may not apply to your washer, but is pure gold if it does. Good Luck!
May 26, 2007 | Whirlpool 24 in. DU1055XTP Built-in...
Wont start
Feb 13, 2007 | Frigidaire 24 in. FDB1051RE Built-in...
Whirlpool Duet GHW9150P Front Load Washer Logo
46 people viewed this question
Dan Webster
Dan Webster
Sal De
