Question about Pure Digital Flip Video Ultra Camcorder
~ USB Not Recognized (Unknown) ~
I have tried this on XP and Vista for the Flip Ultra to get my videos off.... however, each time I plug the USB inside, it says the device is not recognizable and it is "malfunctioning" potentially. The USB is simply not reading or something....
SEE PHOTO Here:
Here's the funny thing... it was working perfectly just a few days ago and then I went out to take some more videos, BOOM I get this error.
I even called support and they told me to go Device Manager - >delete unknown device option and reboot. Same problem even after support there.
I'd like to ask people here for any solutions....before I send the flip camcorder for a refund and never get this thing again. Seems error prone.
Thanks!
Anyone else experience this?
  • 15 more comments
  • letian Sep 07, 2008
    Thanks!
    The first solution does not work. The third solution of localization does not work because I see the problem on three different computers.
    The second may and so I checked your link through MS DOS, removed hidden files, then went into device manager and ONLY removed the "unknowns" under the USB tab.
    Perhaps I need to remove ALL the grayed out ones as well? Is this safe? This includes the "Generic USB devices" What about other tabs? The instruction is very unclear.
  • letian Sep 09, 2008
    Mastersaint,
    I used the instructions in the link of showing the hidden devices and removing all the "unknowns"... however it does not work. It cannot be the localization factor because this does not work on three computers.
    Just to make sure I did the link instructions right, do you also rid of the "Generic USB hub" ones as well? Those are grayed out.
  • letian Sep 10, 2008
    I wanted to see if any other experts have had this problem with the Flip (doesn't work due to USB unrecognition on 3 computers after initially working just FINE brand-new)...The video inside works just fine, it's just the computer loading part.
    I then asked one expert who suggested somethings but nothing really solved. This is my attempt to fix this before never buying a flip again. This was just too weird .... If anyone knows what this is or if it's a super rare bad device, I'd really appreciate it.
    Robert,
    There's no cable involved here, it's only the USB right? Also rescan means to check Devices -> USB in the Control Hardware panel right?
    Lastly the camera is not turned on, it AUTOMATICALLY has the "Connected" screen on when plugged in. I can't really turn the camera on when plugged in
    You know anything that can be done here? Thanks!
  • letian Sep 24, 2008
    My problem has not been answered or solved.
    Now before I return this device..... is there any way to fix it?
    According to mastersaint, it's the device issue since it occurred on three computers (seperate USB channels) This has got to be the strangest problem to suddenly occur on the device out of the blue.
  • robertweb Nov 18, 2008
    I have the exact same problem with my Flip Video Camcorder on two computers. Both are running XP SP2 with slightly different vintage Pentium CPU's. The first time I connected to each computer everything worked fine, like auto pilot the software loaded and the videos were easy to transfer. Subsequent connections were a 1 out of 20 shot to get the Flip recognized by the computer. On the rare change the computer connected the transfer would almost never complete. After more reboots than I could count I returned the unit for warranty repair, they sent me a DVDROM with my videos and a "repaired" unit but the exact same response. I am capable of digging in to hidden files, safe mode and DOS if needed but this simple camera should not be so hard. I have also connected to every USB port on my PC (when possible without a cable) and the response is always the same. I'd love an answer that does not require me to use my Engineering Degree.
  • nchiger Nov 26, 2008
    i got the same problem and it has worked before
  • Anonymous Dec 25, 2008
    I have the same problem and none of these solutions have helped me.
  • hidebrasue Dec 31, 2008
    3 days playing with this and trying suggestions from Flip tech support have got me nowhere...USB not recognized.
  • heather_marr Jan 05, 2009
    Not sure what to do, I connect my flip to my laptop, it says it's connected, and nothing happens.
  • K-kok Apr 28, 2009
    I have the exact same problem. My Mino worked perfectly for 6 months and then I tried pluggging it into my computer and it said "USB device not recognized" over and over again. I tried it on my other computer and got the same message. I says somthing about the device malfunctioning. I have tried all the solutions on this page and none have worked.
    I emailed Pure Digital and told them about my problem. I even told them that there are many other people with the same problem looking for a solution. They have not responded.
  • scijohn May 09, 2009
    I bought 2 Flip Video cameras for my kids and I have the same problem with one of them.
    The problem is with the device - not your computer.
    One plugs in (same computers, same usb cables, same usb ports) and downloads without a problem. The other one causes Microsoft XP and Vista to say "USB not recognized..."
    I wish I had a solution but at least I know which device to blame.
  • Anonymous May 16, 2009
  • sheilahsmail May 19, 2009
    I have the exact same problem as everyone. I have the Flip Mino. I took a video two days ago and when I plugged it in yesterday, it did not work. Same message, "USB Not Recognized". Do you know how I can at least get my video files out of it? Do you plan to return it? What did the manufacturer said when you contact them?
    I forgot to mention, I tried this in 4 different computers: at my work with HP Tower, at home with my Acer Netbook, at my hubbie's laptop: Compaq, and my son's Gateway computer --- all with Windows XP. The conclusion... it's not the computer, it's the Flip!
    I give up! I tried everything you posted here and it did not work. Do you know how I can I at least download the files before I throw this Flip out the window?
Worked for me! Take out the battery and plug into your USB port without the battery, your computer should recognize the device and you can get your files off of the flip.
Posted on Apr 04, 2010
  • Anne Straub Sep 23, 2011
    I have a MacBookPro and was having the same problem. I tried using a different usb port, different computer, powered hub, and plugging in without batteries and so far, nothing has worked.
    Now looking into whether it's worth data retreival.
Hi everyone,
I was able to connect the Flip to my computer via USB by first removing the battery pack. Hope that works for you!
Huthead Ted
Posted on Jan 19, 2010
I was able to get the computer to see the camera by Disableing the "Standard Enhanced PCI to USB Host Controller" in the Device Manager and the camera would be seen by the computer and files could be removed. Hope that this helps someone.
Posted on May 17, 2009
    Brigadier General:
  • 6,966 Answers
I believe that the consensus is the the Flip USB interface is malfunctioning. I was made to understand that the manufacturer has identified an issue. Pls see this page. Alternately, it may be a corroded USB pin(s) on the camera itself. Have you tried cleaning the contacts?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 25, 2008
  • Leah B May 30, 2011
    I had the same problem and I just got off the phone with Flip. They told me to take the battery out of my flip ultra hd and then plug it into the computer and sure enough, the software popped up and started downloading videos!!! Once it was all complete, then I unplugged usb from computer and put battery back in and deleted videos and all is good. Yay!!!!
I had the problem when I inserted the Flip into the front of the computer.
I deleted all the unknown devices as someone else suggested and then plugged it into the back of the machine.
Apparently front USB ports often have less power than the rear ones so the device wasn't getting all the juice it needed.
You may find that you've got more USB devices attached to your hub than you used to, therefore draining more power. Try removing some of your devices
Posted on Jan 15, 2009
I have the same problem with my flipvideo. Brand new, straight out of the box, this thing didn't work from the first minute. I plugged the unit into my computer (with the power off) and immediately got an error report stating "USB device not recognized" something along those lines also that it had malfunctioned. My computer is running XP home edition and has SIX usb ports, all of them giving me this error if used.  The same flip video loads just fine on a friend's Mac computer. No luck with my Windows XP PC though.  I highly doubt it's an issue with dirty usb connections, poor wires, etc. Much too many people are having this same problem. I even returned my flipvideo for repair they sent me a replacement that does the EXACT same thing.  I am very keen with electronics but this product is HORRIBLE!
Posted on Nov 20, 2008
    Sergeant:
  • 208 Answers
It seems that many people are still getting the 'USB Device notRecognized' problem from time to time. Unfortunately there is no easyfix.
Firstly, it's recommended that you make sure every one of yourmotherboard drivers are completely up-to-date, but you probably alreadyknew that.
In XP, after a USB port isn't used for a long while the USB driverbuilt into the OS sets the OHCI controller to suspend. When you plug adevice back in, it can sometimes fail to 'wake up' properly. Thisproblem was supposedly fixed in SP1 but there is a related registryhack that may still be able to help.
Run regedt32.exe and navigate to;
HKEY_LOCAL_MachineSYSTEMCurrentControlSetServicesUsb
Create the Usb key if it doesn't already exist. Under this key, create a new DWORD value called DisableSelectiveSuspend and give it a value of 1. Then restart the PC.
A long shot perhaps, but I recall having similar problems with aUSB hub built into my Microsoft keyboard and adding this key seemed tosolve it. It wouldn't hurt in trying ~ USB Not Recognized (Unknown) ~ - icon_smile.png.
Alternatively, removing all entries relating to USB in DeviceManager and all associated USB drivers will force XP into refreshingthe USB driver stack.
Begin by unplugging all USB devices, then use Add/Remove Programsin Control Panel to uninstall any USB driver software. Next, boot upinto safe mode and go to Device Manager. Once in device manager makesure 'Show hidden devices' is checked under the View menu. Uninstallall device entries in this order;
1. USB peripheral devices (printers etc.)
2. HID and/or Composite USB (Human Interface Devices) You're using PS/2 input devices so you may not have this entry.
3. USB Root Hub(s)
4. USB Host Controller(s) (Universal or Enhanced Host Controllers)
Then boot back into Windows (not safe mode) and it should populatethe Root Hubs & Host controllers again. Proceed to plug your USBdevices back in, starting with your powered hub. Be aware that most USBprinters and scanners need to have their drivers installed first beforeyou plug them in.
Hopefully some of this may be of help, let me know how you get on.
And i would like you to refer to this article too support.microsoft.com/default.aspx?scid=kb;en-us;817900
Thanx for using fixya.
Bye, Take care.
Before you post, do your homework. Flip Video camcorders should be turned OFF before being plugged into the USB port.
Posted on Nov 04, 2008
    Genius:
  • 1,239 Answers
Hi i think there is problem with usb reader as some error will be attached to program
Posted on Sep 10, 2008
    Brigadier General:
  • 5,158 Answers
Remove the device from device manager... then rescan for devices... other issues maybe be the cable itself... try another cable if you have one
Robert
Posted on Sep 07, 2008
  • Roberta Smith
    Roberta Smith Sep 08, 2008
    Removing all the usb devices should be safe as only the ones that are present on your computer will be reinstalled.
    Robert
    I still have to mention the merely obvious because it is often overlooked. The camera is powered up ?
  • 928 Answers
Actually this has happened to me as well but with different devices. Normally what you can do is shut the computer down then turn off the device. Turn back on teh computer then turn on the device. AFter that it should work. you can also try another USB port. If thatdoes not work another option would be to follow the link below.
http://www.hat.net/geeky/node/221
If this does not work try another computer as the problem may be localized to yours.
  • Thomas Lim
    Thomas Lim Sep 07, 2008
    I already replied via your ask me
  • Thomas Lim
    Thomas Lim Sep 09, 2008
    If the problem occurs on three computers that means that the problem is with the device that you are using. The instructions that I gave on the link is a solution to a problem that would not happen to 3 computers at the same time.
I'm having a hard time getting my Flip HD to charge. It is brand new and this is the first time I've had to charge it. Sometimes the red light is on and steady and other times the red light is flashing. ...
I had this charging problem with 2 new Flip Ultra HD cameras...red light flashing..nothing on the screen after plugging in the USB port.
I removed the battery..plugged camera into USB port..pc recognized the camera... installed flipshare software..updated software...plugged battery back in..all good.
Why on earth the book doesn't mention these steps is beyond me.
Oct 11, 2010 | Pure Digital Flip Video Ultra Camcorder
Failure in the camera's USB ports
Finally I solved it!!!!
Situation: My Computer (MAC And PC) wasn't recognizing the FLIP ULTRA HD, because it has a corrupted file, but couldn't format because there was no communication between camera and computer
Solution:
1. Charge your batteries until get the FULLY CHARGED icon (Green Battery)
2. then remove the batteries without unplugging the USB 3. Voila...computer recognize the USB
4. Format the Camcorder with the Following tutorial: http://www6.nohold.net/CiscoFlip/ukp.aspx?vw=1&docid=763c871b45fc4b20b5a671b24c909
20e_Reformatting_and_Reinstalling_FlipShare_
on_a_Flip_Camcorder.xml&pid=4&respid=0&sni
d=2&dispid=0&cpage=search
5. Install software in camera...
6. CONTINUE VIDEO CLIPPING!
Jun 28, 2010 | Flip Video Flip Ultra Camcorder
Hello. We have a Flip HD video camera. After
I have this exact same problem on my Flip all the time. The only solution I've found is that you have to unlock it, open up the battery pack on the front, take it out and put it back in. Then it turns on. I've had this problem with two different Flip HDs, so I think there's a bug in the camera -- it only happens after I've plugged it into the adapter on the computer and then taking it off.
Feb 10, 2010 | Pure Digital Flip Video Ultra Camcorder
Usb not recognized on when I connect my flip ultra to any computer (mac or pc)... it has worked in the past on my mac and now is recognized by any computer... driving me crazy...
the camera has to powered and on ...and be sure you plug in the right kinda usb ...it needs to be a 2.0
so ..install a 2.0 driver to be sure you have one ..and after that with the camera powered ..plu one by one in each usb port..until it is seen in one...also look at the camera cause some devices need to confirm from them the connection via usb ...
it has to be seen ..if it's not ..change the cable it may be damaged..
Jan 30, 2010 | Pure Digital Flip Video Ultra Camcorder
USB adapter does not go in the USB port on my computer. Seems like it's the wrong size.
The Flip Video Ultra Camcorder has a 'standard' full-size USB connector: please ensure that you are not trying to plug it to other type of input and use a USB extension cord if locations of your computer USB ports are mechanically incompatible.
Hope it helps. Let me know how you go.
Jan 05, 2010 | Pure Digital Flip Video Ultra Camcorder
My Flip Video Ultra (out of warranty) has a six minute video of my grandson's piano recital that I would like to retrieve from the camera. However, on my PC laptop running XP and the Dell Desktop, when it...
Hi there kathleen,
If you plugin other usb device, does the computer recognizes it? With your xp computer, plugin your Flip and turn it on. Try to right click your windows start button and choose Explore. Then from the left panel, look for the drive letter associated with your Flip. If you're lucky, upon clicking on that drive, it will show its contents to the right.
If the above did not work, then we may need to format your Flip and try to recover the video using a recovery software later.
Jan 02, 2010 | Pure Digital Flip Video Ultra Camcorder
Cannot get the flip camera to play videos or recognize the Flip shareware on my laptop. Working on Windows XP
You may just have a simple problem with the device 'Drive Letter' allocation.
When you plug in the Flip into your USB your computer will assign the device a drive letter, if this letter is used already say for a network or mapped drive or other USB connection the Flip will not be recognized.
To check and see if that's the problem, plug in the Flip and go to your desktop
(right click) on My Computer / Manage / Disk Management
In that list see if the device is listed (you'll know by the name or storage size of the device) If it's there right click and 'change drive letter' to an unused drive letter.
Hopefully this will fix your problem.
Nov 02, 2009 | Pure Digital Flip Video Ultra Camcorder
Brand new Flip freezes my laptop!
Mp4Clipper::OpenInputFile could not open file
Jul 09, 2009 | Pure Digital Flip Video Ultra Camcorder
My computer does not recognize flip video F 260 ultra camcorder
do u have the driver cd which came with the product. else go to the web site of the company locate the driver and load it on ur computer.
May 17, 2009 | Pure Digital Flip Video Ultra Camcorder
Vista driver for usb gamepad Gigatech
You can either try and force install the XP driver of this device, or you can manually set the device up as an unknown gaming device.
Mar 05, 2009 | eMachines eMD620-5133 Notebook
Pure Digital Flip Video Ultra Camcorder Logo
5,323 people viewed this question
Top Pure Digital Video Cameras Experts
Rommel Balcita
sharky633
sharky633
tomikles
Level 1 Expert
Are you a Pure Digital Video Camera Expert? Answer questions, earn points and help others
