Question about Saeco Incanto Classic Espresso Machine
Saeco Incanto Classic coffee machine won't charge water circuit
Help please! After moving house and finally unpacking my Incanto classic coffee machine i found that the machine worked for a couple of coffees and then stopped. Now the 2 green lights blink (for the 2 cup sizes) which is normal, but also the red left light is blinking. The manual says that this light blinks when the water circuit needs to be charged, however the machine won't do this no matter what i do. Now machine site there with the 2 green lights and one red light blinking, So problem somewhere related to getting the water to cycle through the machine. Much appreciate if you can offer any ideas or suggestions, I've cleaned the machine out and pulled all i can apart to clean etec but no change..
  • Legends1 Sep 14, 2008
    I posted the above and ended up fixing the problem myself... I ended up taking it to a saeco service centre. They told me i needed a new CPU board ($300!!) and I told them it was n't worth getting fixed and paid the $55 service charge and took it home. I asked the service guy a few things about how the thing worked and found his knowledge and bit scratchy. Anyway I took it home and pulled the top off and found that the water pressure knob micro switch was not being activated when knob was being turned. I repositioned the knob (must have been knocked or something) and it is now working!! Annoyed with the Saeco service centre telling me it needed a new CPU board and paying $55 for them to tell me rubbish.
geox29
  • 65 Answers
SOURCE: Incanto-classic coffee beans do not flow to grinder
The machine automatically stir the beans since the blade make vibration and doing that shake the bean all around.Make sure the the tank is half full so the weight will help on that.If the container is almost empty the bean will fly around and don`t get in the grinder.Back up the machine to the original factory grinding and try to adjust again the wheel
Posted on Jun 17, 2008
  • 40 Answers
SOURCE: Saeco Incanto Classic Espresso Machine Saeco
Do you get coffee? If it is just no water/steam, could be a blockge in the steam wand, or blockage in water lines. First test easy one - the steam wand. If the steam wand is o.k- then check for blockages in water lines/components ( pump, boiler, steam boiler). If you do not feel confortable with testing all the untis where water flows, contact Saeco USA Inc. to locate a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Posted on Jun 20, 2008
mirran
  • 515 Answers
SOURCE: Saeco Incanto Issue
Make sure the magnet in water tank flow up when you fill it with water.
Let me know if you need any instruction.
/Mirran
Posted on Aug 15, 2008
EsWorld
  • 1618 Answers
SOURCE: Seaco Easy wont work/Warning light blinking always
Try descaling the machine. If there is no water getting to the brew unit then it might be blocked, if you checked the brew unit then the blockage might be at the boiler or one of the lines.
Posted on Jun 04, 2009
EsWorld
  • 1618 Answers
SOURCE: Saeco Incanto classic no coffee coming out, no lights flashing...
Check brew unit the screen is clogged.
Posted on Sep 19, 2009
Saeco incanto classic
http://www.partsguru.com/SaecoIncantoClassic.html
Apr 24, 2014 | Saeco Incanto Classic Espresso Machine
Prime indicator always flashing after 3 seconds (saeco incanto classic)
sounds like thermostats...are shot..will need a model number to help you out.
Mar 10, 2008 | Saeco Incanto Coffee Maker
I have a Saeco Incanto Classic. There is hardly any water coming through the coffee dispenser even if I only use the preground doser without inserting coffee. While the little water comes out it makes a...
Sounds like the the shower screen under the red o-ring in the brew group needs to be cleaned, you can remove the screen and clean or you can purchase some espresso machine soap puro caff or puly caff, and run it through the brew group using the preground method the clean out coffee oils.
Aug 26, 2011 | Saeco Incanto Classic Espresso Machine
How to drain coffee machine saeco s-class incanto classic
Subject: How to drain boiler of Saeco Incanto Deluxe
I got an answer from Saeco Customer Service as follows:
Good Afternoon,
All you need to do is have the machine turned on and up to temperature. Make sure that you have a full tank of water as well. Make sure the machine is set for hot water, then turn the knob on the side of the machine to start water flow. Once the water is flowing out, remove the water tank and, leaving the knob turned open so that the water that's in the system drains out. Once water stops coming out, close the knob and shut the machine off.
The water is now drained from the system.
Thank You,
Customer Service
Saeco USA
800-933-7876
Feb 23, 2010 | Saeco Incanto Classic Espresso Machine
I have a Saeco Incanto Classic and the ventilate message will not disappear, even after sending 4 full watertanks through the steam nozzle. The solution posted above does not work.
Having read the other reviews here, I was prepared for the cryptic "VENTILATE" message. (The manual refers to this procedure as "Loading the circuit", which doesn't help to clarify things.) Of course this refers to what Americans would call "priming" the machine. As mentioned in another review, there is a plastic hand pump supplied for priming, but that is only needed in the event that the electric pump fails to self-prime. All I had to do (following the quick-start instructions) was to select the Hot Water function; the internal pump quickly primed itself. i hope this helps Lee Davidian
Jan 17, 2010 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Housing Jammed
http://216.244.99.185/custompages/Manuals/Incanto%20RS%20SBS.pdf
Here is the manual. Try page 11. Did you take the drip tray out first? You move the "push" part to the right and while doing so use your other hand to pull the whole unit out. The "push" part is a small movement.
Jan 17, 2009 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Sirius S Class
Take off the top of the machine, look at the printed circuit card and see if you can see anything that is broken.
Look at the fuse in the machine to see if they need to be reset.
Best regards
/Mirran
Oct 17, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Classic Espresso Machine Saeco Coffee Machine Type SUP 021YDR Display shows Ventilate when I follow instructions and turn the Hot Water and the water knob the water is not coming through....
Apr 12, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
70 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
