Question about D-Link Express EtherNetwork DI-604 Router
Range problem What variables may cause my wireless product not to receive signals at the maximum advertised distance?
    Novelist:
    Scholar:
  • 128 Answers
Link Air lets you access your network from anywhere you want. However, keep in mind, that range is limited by the number of walls, ceilings, or other objects that the wireless signals must pass through. Typical ranges vary depending on the types of materials and background RF noise in your home or business. The key to maximizing range is to follow these basic principles: 1. Keep the number of walls and ceilings to a minimum - Each wall or ceiling can rob your D-Link Air Wireless product of 3-90 ft. of range. Position your Access Points, Residential Gateways, and computers so that the number of walls or ceilings is minimized. 2. Be aware of the direct line between Access Points, Residential Gateways, and Computers - A wall that is 1.5 feet thick, at a 45 degree angle, appears to be almost 3 feet thick. At a 2-degree angle it looks over 42 feet thick! Try to make sure that the Access Point and Adapters are positioned so that the signal will travel straight through a wall or ceiling for better reception. 3. Building Materials make a difference - A solid metal door or aluminum studs may have a negative effect on range. Try to position Access Points, Residential Gateways, and Computers so that the signal passes through drywall or open doorways and not other materials. 4. Make sure that the antenna is positioned for best reception by using the software signal strength tools included with your product. 5. Keep your product away (at least 3-6 feet) from electrical devices that generate RF noise, like microwaves, Monitors, electric motors, UPS units, etc. 6. If you are using 2.4GHz cordless phones or X-10 (wireless products such as ceiling fans, lights, and home security systems), your wireless connection will degrade dramatically or drop completely. Anything using the 2.4Ghz frequency will interfere with your wireless network. For the average home, range should not be a problem. If you experience low or no signal strength in areas of your home that you wish to access, consider positioning the Access Point in a location directly between the Residential Gateways.
Posted on Feb 16, 2006
Digitech two way radio bps wt552ab, settings to use. how do i link the two radio's
I'm not familiar with this specific model, but the general rule for two-way handheld transceivers is that you have to set them both to the same radio channel (one of 8), set the same CTCSS tones and/or digital alert codes, and start learning to use them at about 20-50m distance. If you're close enough to talk to each other without the radios, the transmitted signal may overload the receiver and it won't work. If you're at the maximum advertised range, you'll need to have rare and optimum conditions (such as, from one hill-top to another) or it won't work. Don't expect to get 10km range unless you can see each other through telescopes.
Jan 08, 2014 | Radio Communications
Lacrossetechnology
Hi Susuan,
One of these methods below should get your device working properly. Good luck!
LaCorosse Tech Support email address.
The product information page
From the manual:
915MHz RECEPTION CHECK FOR OUTDOOR TEMPERATURE SENSOR
The atomic clock will receive the temperature data within 3 minutes. If the temperature data is not being received 3 minutes after setting up (the display shows "- - -"), then please check the following points:
1. The distance of the atomic clock or outdoor temperature sensor should be at least 6 feet (2meters) away from any interfering sources such as computer monitors or TV sets.
2. Avoid placing the receiver onto or in the immediate proximity of metal window frames.
3. Using other electrical products such as headphones or speakers operating on the same signal frequency (915MHz) may prevent correct signal transmission and reception.
4. Neighbors using electrical devices operating on the 915MHz signal frequency can also cause interference.
Note:
When the 915 MHz signal is received correctly, do not re-open the battery cover of either the outdoor temperature sensor or atomic clock, as the batteries may spring free from the contacts and force a false reset. Should this happen accidentally then reset all units (see Setting up above) otherwise transmission problems may occur.
The maximum transmission range is 330 feet (100 meters) from the outdoor temperature sensor to the atomic clock (in open space). However, this depends on the surrounding environment and interference levels. If no reception is possible despite the observation of these factors, all system units have to be reset (see Setting up).
May 24, 2013 | La Crosse Technology Ws-8418u-it Atomic...
Wi-fi distance of beetel 450tc1 adsl2+router
Things That Affect Wireless Router Signals1. Many wireless routers are using the same wirelesschannel. Many manufacturers choose channel 6 as the default.2. Analogue video senders used to send audio and video toother TVs in the home.3. Microwave ovens emit interference in the 2.4GHz band.4. Wireless speakers and console controllers can causeinterference with the wireless router.5. Bluetooth devices, newer Bluetooth devices can jump todifferent frequencies if there is a connection problem.6. Power cables located near the wireless router can causedrop outs and speed reduction.7. Fish tanks will cause massive Wi-Fi shadow on the other sideof the tank from the wireless router. 8. Depending upon the location of large mirrors will reflectwireless signal away your computer.9. Building materials will block wireless signals such asplasterboards with metal foil, reinforced concrete walls and floors. Alsoobjects near the wireless router such as metal filing cabinets and otherelectrical appliances. 10. Blinking Christmas lights can reduce Wi-Fi performanceby 25% when it is close to the wireless router.
Mar 28, 2012 | NetGear WGR614 Wireless Router
How can I increase the distance the router will broadcast?
If you are having problems receiving a decent signal , then try changing the channel the wireless is broadcast on your router if that fails to improve things your only other option is to buy a range extender. Thiis will be paired with your wireless network and then it will transmit the signal further
Feb 23, 2011 | Linksys Wireless-G Broadband Router
Linksys WRE54G WIRELESS 802.11G RANGE EXPANDER Range
The actual max distance of the range expander is about 50 feet, and sorry to say but it cannot bounce the wireless signal from it on a wall....
Jan 25, 2009 | Linksys Wireless-G Range Expander (WRE54G)
Connecting
For problem number 1, your linksys home router has a maximum signal range of 100 to 150 feet, that is less than 50 m. The reason for the poor connection is the distance between the laptops and the wireless device. Try moving the router closer to the center point from where both laptops are stationed. If you can make the maximum distance between 30 and 40 meters (shorter the distance the better the connection strength) from the router to both laptops this may solve the first problem. If you cannot change the location of the router, then you may want to consider switching to a wired connection for the laptop you are trying to review from, (the maximum distance for cat 5e ethernet cable is 100 m).
For problem number 2, I am unsure what you mean by system does not work, do you mean your laptops will not turn on, or that you cannot pick up a signal from the wireless device?
Apr 06, 2008 | Computers & Internet
Intel 2915AB Connection problem
Intermittent disconnection issues on a radio/wireless network will generally be caused by interferance (speakers, power board fully loaded, High wattage Lamp (flourescent bulbs usually) all parked too close to the wireless router, access point or network card. or possibly due to interuption of the active signal possibly because the distance of the router and network card/access point is just on the edge of the best signal limit and disruption occurs when someone or something gets up and moves itself inbetween the two service points)I resolved my disconnection issues by purchasing a wireless Kite for the access point and router, which will intensify the radio signal and bring the access points within closer range of each other, friends of mine have resolved intermittent signal issues by making a thin tube of rolled tinfoil about 30cm long slipped over each aerial affected by the intermittent signal disconnection. Also verify the "line of sight and non line of sight" signal distance limits for your radio equipment as the signal distance will decrease depending on the age of your wireless equipment, most equipment is in the 30Ft non line of sight- 100Ft line of sight arena out of the box but you can expect to half this figure after 3 - 5 years of continued use. Basically three options Interferance, Interupption or age only distance testing will verify this accurately IE: bring the router and access point withing 1Ft of each other and start walking away still holding the access point, whilst a user monitors the radio network condition.
Aug 04, 2006 | Intel 2915ABG 802.11a, 802.11g/b Wireless...
Maximum advertised distance
D-Link Air lets you access your network from anywhere you want. However, keep in mind, that range is limited by the number of walls, ceilings, or other objects that the wireless signals must pass through. Typical ranges vary depending on the types of materials and background RF noise in your home or business. The key to maximizing range is to follow these basic principles: 1. Keep the number of walls and ceilings to a minimum - Each wall or ceiling can rob your D-Link Air Wireless product of 3-90 ft. of range. Position your Access Points, Residential Gateways, and computers so that the number of walls or ceilings is minimized. 2. Be aware of the direct line between Access Points, Residential Gateways, and Computers - A wall that is 1.5 feet thick, at a 45 degree angle, appears to be almost 3 feet thick. At a 2-degree angle it looks over 42 feet thick! Try to make sure that the Access Point and Adapters are positioned so that the signal will travel straight through a wall or ceiling for better reception. 3. Building Materials make a difference - A solid metal door or aluminum studs may have a negative effect on range. Try to position Access Points, Residential Gateways, and Computers so that the signal passes through drywall or open doorways and not other materials. 4. Make sure that the antenna is positioned for best reception by using the software signal strength tools included with your product. 5. Keep your product away (at least 3-6 feet) from electrical devices that generate RF noise, like microwaves, Monitors, electric motors, UPS units, etc. 6. If you are using 2.4GHz cordless phones or X-10 (wireless products such as ceiling fans, lights, and home security systems), your wireless connection will degrade dramatically or drop completely. Anything using the 2.4Ghz frequency will interfere with your wireless network. For the average home, range should not be a problem. If you experience low or no signal strength in areas of your home that you wish to access, consider positioning the Access Point in a location directly between the Residential Gateways.
Feb 16, 2006 | D-Link Air Xpert DI-774 Wireless Router
Feb 16, 2006 | D-Link Air Xpert DI-774 (DWL-774) Wireless...
Maximum range
Since wireless networking uses radio frequencies to communicate between your computers and networks, the maximum distance that 802.11b can operate depends on environmental factors that will affect your network: 802.11b Typical Outdoor Coverage Area 802.11b Typical Indoor Coverage Area 590' 11Mbps 50' 11Mbps 984' 5.5Mbps 125' 5.5Mbps 1476' 2Mbps 150' 2Mbps 1800' 1Mbps 200' 1Mbps
Feb 16, 2006 | Belkin (F5D6230-3) Wireless Router
D-Link Express EtherNetwork DI-604 Router Logo
101 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
