Question about Creda C362E Electric Kitchen Range
Creda c366e cooker
The fan assisted oven keeps coming on on its own, we dont know about it till we feel the warmth and then we can see the elements glowing but the fan part dont actually kick in and its not set by timer or anything as far as we are concerned its turned off can you help ? thanks in antisipation
SOURCE: creda cooker not working properly
my creda cookers hob and top oven is working,but my fan oven is not heating up,the fan works though.
Posted on Sep 06, 2008
chessmaster2
  • 160 Answers
SOURCE: Creda C461E Cooker
the control thermostat may also have been burned out. check it.
repair manuals can be located from here.
http://search.msn.com/results.asp?cp=65001&RS=CHECKED&Form=CO&v=1&cp=65001&q=appliance+manuals&Submit1=Go
Posted on Dec 05, 2008
chessmaster2
  • 160 Answers
SOURCE: creda concept halogen cooker -2nd hand
bad timer, or the elements are bad. or the breakers are all kicked. check the breakers and the gfci plugs for the kitchen, just as is below.
for the apartment problem, check the breakers in the breaker box, and turn off then back on. if still not working, check the kitchen plugs for a gfci plug (has a tiny push button in the middle, push to reset) being kicked.
SOURCE: need instruction manual for creda / hotpoint collection S T C C
You can download it as a PDF here:
http://www.hotpointservice.co.uk/hs/pages/manual/manualSearch.do
Cheers
Posted on May 21, 2009
57 varieties
  • 1653 Answers
SOURCE: Hi - I have a creda solarplus cooker (48349) - I
It’s basically as simple as:
Turn off the gas supply to the range.
Turning off the mains power to the range.
Remove the back panel behind the grill.
Remove the 2 power connectors to the grill element.
Remove the earthing wire to the element screw terminal.
Unscrew the grill element securing screws(s) - there will be 1 or 2 depending on the element fitted to your range.
Refit the new element (make sure it has the same mounting screw holes as the one you want to remove) then secure it.
Reconnect the earthing wire to the element screw post.
Make sure that neither of the element tags touch the chassis - check with a continuity tester of ohm meter and adjust if required.
Reconnect the power cables to the element.
Reconnect the power and check that the element works correctly.
Disconnect the mains power again and replace the rear panel(s).
Reconnect the mains power and recheck that the grill functions correctly.
Turn on the gas supply.
Posted on Oct 05, 2009
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
Hi, I have a creda colonial range cooker. Yesterday I was using the fan oven and it tripped a fuse in the main fusebok of our house. I reset the fuse and now the 2 oveens wont work. The lights come on and...
All electrical appliance has a safety fuse located somewhere in the interior, most of the time it can be replaced.
always unplug electricity before attempting to repair on any electrical appliance
Sep 13, 2017 | Creda Colonial 42352 23 in. Electric...
Hi, the oven is not working in my Creda Collection freestanding cooker. I have had the element tested and proved to be ok. Also the fan does not move. The timer is set to manual. Can you assist?
If the element is okay and the element and fan aren't working together then it will be a problem further up the line. The next question I would normally ask is is the electronic timer in manual mode. When you turn the oven on does the oven indicator light come on?
Feb 17, 2011 | Ovens
I didnt get a user manual with my creda cooker dont know how to set the timer
try this site for your manual
kitchen.manualsonline.com/manuals/.../creda/creda_oven_product_list.html
hope this helps
Apr 28, 2010 | Ovens
Hi.i have a hotpoint creda c362e cooker the rings work grill works but main oven and top oven elements dont come on even when lights come on when switched on fan works but no heat could you help me on this...
Hi.
Frpm the sympton's you list, I would say that the main oven element has failed, espsecially if the fan is working o/k.
The element is located at the rear of the oven compartment behind a removeable cover.
In addition to the grill elements in the top oven compartment, there is an additional base element which you can't see.
If you turn the top oven on, the base of the compartment should get hot, if it does not, then the base element has probably failed.
Hope this helps.
Jan 09, 2010 | Creda Ovens
Oven fan wont work
You need to determine if you are getting a mains feed to the fan motor, if not, then you need to trace the wires bcck to source and work from there,
If you are getting a 240 volt supply, then the new fan is faulty.
Hope this helps you.
Dec 15, 2009 | Ovens
Creda concept cooker oven stopped working fan still going light gone when cooker was on opened door and there was sparks comming from were the fan is and a bit of smoke then oven stopped its 5yrs old
circular element has gone. remove rear panel inside oven and element will be in sight. to replace, remove also back external panel and element is held in by two nuts usually. make a note of wiring before starting. element cost is about £30
Aug 31, 2008 | Kitchen Ranges
Creda cooker not working properly
Jan 23, 2008 | Creda C362E Electric Kitchen Range
Creda C362E Electric Kitchen Range Logo
123 people viewed this question
Top Creda Kitchen Ranges Experts
richie46
ray gallant
Pamela Leach
Pamela Leach
Are you a Creda Kitchen Range Expert? Answer questions, earn points and help others
