Question about Kenmore 79383 Dual Fuel (Electric and Gas) Kitchen Range
Kenmore 790 gas range
When you turn the burners on get aloud humming noise does it with all burners
  • Anonymous Nov 24, 2008
    Same problem with a model #790: the stove works, but all the burners make a noticeable siren-like noise when burning--especially at higher settings.
    Thanks for any help. John
  • 2692 Answers
SOURCE: Kenmore gas range 790
Look at the burner and se if all of the holes coming out of the burner have a flame.If not, Turn it off and remove burner lok for obstructions like burned food. ALso use  soapy water on  the gas line(s) leading from the oven control to the burner as well as the fittings . If you get bubbles you have a leak at that point.  Tighten fittings if that is the case.
Posted on Dec 27, 2008
SOURCE: one burner will not ignite, unless one of the
It was only a loose wire.. Thank you
Posted on Jan 07, 2010
TheMobilian
  • 8220 Answers
SOURCE: burner will not light
That is the burner switch for that particular burner gone out or a loose connection. You may can get just that one or you might have to buy the harness. I have a video about this: HERE
Posted on Jan 14, 2010
muffteck
  • 202 Answers
SOURCE: I have a kenmore gas range model #790. When I turn
dont use it may blow you up bad gas valve and saftey sender
Posted on Mar 27, 2010
SOURCE: Kenmore electric range 790. Both the broil and
Kenmore oven 790.91072601, bake & broil not working, relays are cycling but no heat... Sounds like I have the same problem but its the night before Thanksgiving and Iam in panic mode... I've orderd a new Temp Probe part # 316233902. did you ever get yours fixed
Posted on Nov 24, 2011
Kenmore gas range 790, not getting gas to the stove top, oven works, all 4 igniters fire when any knob is used. Is this a safety shutoff and how do I fix it?
Burner Spark Electrode Replacement - Kenmore Gas ...
? 2:23
www.youtube.com/watch?v=U0VcfMJPaiY
Nov 12, 2010 - Uploaded by RepairClinic.com
+Tony Eatinsky If the electrode is not damaged than the spark module ... I have a kenmore gas stove ( 362.7555190) that won't ignite unless I use a match. ... I have a Kenmore Elite 5 burnergas range top, it auto light continually sparks? .... You most likely will need to cut or grind off the screws and get new ...
kenmore model 790 gas range. the gas stove top burners ...
www.shopyourway.com > Manage My Life > Questions
kenmore model 790 gas range. the gas stove top burners stopped sparking. ... NOTE: I do not recommend measuring voltage unless you have experience and feel ... if the spark module is getting 120 volts when the burner knob is turned to the ...
Oct 19, 2015 | Kenmore Kitchen Ranges
Oven doesn't work. Display F30 code. Gas Range model: 790-78579405. First time usage for oven. All stove burners does work. Some blogs mentioned "reset" red buttom but couldn't find it from the back metal...
Part of the model number 790 says, that the range is made by Fridgidaire. F30 means the sensor is bad and/or main board. There is no red button. You can find you part here: www3.sears.com
Kenmore range repair in orange county, ca
Feb 11, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Model 790, propane, right rear will not light, piezo sparker works, seems like no gas to that one burner- ( the simmer )
i have a kenmore gas range when i turn front and rear burner no light but i can hear the sparker and smells the gas. any suggestions?
Jan 21, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Burner will not light
Jan 06, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I have no heat coming from the oven portion of my kenmore 790 electric range after hearing a "pop" sound. fyi, the element looks intact.
Top burners are working, broiler is working, bottom oven burners dont ignite and dont heat the oven? What can we do?
Dec 30, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Dec 27, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore 79383 Dual Fuel (Electric and Gas) Kitchen Range Logo
80 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
