Question about HP vs19 (Silver) 19" LCD Monitor
OSD Lockout My name is Patsy Davis and I live in Charlotte, N.C. All of a sudden, something called "OSD Lockout" keeps popping up and I can't seem to be able to turn it off. It is driving me crazy. Can you help me get rid of this thing? I can't even hear the audio programs on my computer. Patsy Davis pmksou@yahoo.com
  • 8 Answers
Hold the menu/ok button for ten seconds, to unlock the OSD.
If this doesn't solve the problem, then it's probably the button that got stuck.
There are two things you can do to repair it, but both require that you dismantle the casing, which voids any warranty.. so, if the monitor's still covered by the warranty, or if money is not an issue, have it repaired by professionals on an accredited brand shop (check your warranty details for more information on this subject).
If not, remove the casing, locate the menu button's contact switch on the circuit board, and try to release it using something thin like a screwdriver, x-acto knife, or set of plyers.
If this doesn't work, chances are the menu button is stuck on a loop, sending a continuous signal to the board (which keeps locking/unlocking the OSD).
If so, your only solution (other than take it to a repair shop) is to remove it, by prying it off with a screwdriver or set of plyers.
Of course, you'll lose access to the OSD features, but I guess this is better than to have a message stuck on front of your screen all the time..
This is a tried and working solution, since I had this problem myself (with a Philips 190B monitor), and solved it successfully, with this method.
Posted on Sep 25, 2008
  • 89 Answers
Try to reset your lcd monitor, you can check the manual on how to reset it.
Posted on Sep 07, 2008
  • Gerald John Pacquing
    Gerald John Pacquing Sep 07, 2008
    try also to hold the MENU button for ten seconds to unlock or lock the OSD
Monitor display says OSD Lockout /no signal input how to fix this?
This document pertains to LCD monitors .
One of the following messages appears on the screen (over the items being displayed).
OSD Lockout
OSD Lock-out
... or similar message.
This message occurs when the Menu button on the front panel is pressed for more than 10 seconds. OSD lockout prevents the OSD menu from opening on the screen when a button is accidentally pressed.
NOTE: The button may be different and the procedure might vary on some monitors. Please check your monitor User Guide to find the exact procedure if this procedure does not work.
To remove the OSD Lockout message, release the Menu button (if something was pressing against it), and press and hold the Menu button again for about 10 seconds - until the message goes away. If the OSD Lockout message does not go away, the button may be stuck or the hardware behind the button might have become defective.
Aug 31, 2013 | Dell Computers & Internet
I have a w1907 HP monitor. It keeps displaying a small box in the middle of the screen that says osd lockout. I am still able to get online and use my computer normally except for this box in the middle of...
NOTE: The button may be different and the procedure might vary on some monitors. Please check your monitor User Guide to find the exact procedure if this procedure does not work. To remove the OSD Lockout message, release the Menu button (if something was pressing against it), and press and hold the Menu button again for about 10 seconds - until the message goes away. If the OSD Lockout message does not go away, the button may be stuck or the hardware behind the button might have become defective.
Jan 03, 2011 | HP w1907 LCD Monitor
Osd lockout
I hope it helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 29, 2010 | HP w1907 LCD Monitor
This osd lockout pops up quiet often on my screen what can it mean?
Try this
OSD (On Screen Display) lockout. To resolve the issue you can hold the power button of the monitor until you get another message something similar to "OSD unlocked"....if the problem continues. Switch of the monitor and remove the power cable and connect it again.
Mar 25, 2010 | HP Pavilion dv6000z Notebook
OSD lockout, monitor menu appears and changes input automatically
the menu button might be jammed, try pressing it long and releaseing it, sometimes that happens to me
Feb 14, 2010 | HP vp17 Monitor
HP 2009m monitor. OSD lockout keeps appearing on
try holding menu button also if it doesnt workout
Nov 30, 2009 | HP 2009M Monitor
OSD LOCKOUT
1. Replaced the Micro switchs.
2. press the menu switch 15 to 20 secunds.
Nov 02, 2008 | Computers & Internet
OSD Lockout
Jan 09, 2008 | HP vs15 15"LCD Flat Panel Monitor
HP vs19 (Silver) 19" LCD Monitor Logo
278 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
