Question about Canon PowerShot SD600 Digital Camera
Help lens is jammed
  • 489 Answers
Hi
Your lens needs to be cleaned, repaired or replaced. There are online places that will do it for a decent price and there are others that overcharge by way too much.
I know, because I own one that charges a reasonable price to do the repair! (Google 'darntoothysam')
Just let us know if we can help! Good luck from
Darntoothysam com
Thomas
Posted on Sep 26, 2008
Zoom error
There is a problem in the zoom functions of the lens assembly. Dust and lint can get in it and jam it, and you can try to spray compressed air into the lens in hopes of freeing it up. A gear can also be jammed, or stripped. If it's just jammed, you may be able to fix it yourself. Here is a web page that details all the things you can try to get it working. They say about half of the cameras with these problems can be fixed by trying their suggestions. The article says it's for lens errors, but it applies to the problem you're having:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
If none of these tips help, the camera will have to be serviced. Get an estimate first, since the cost of repair can exceed the replacement cost of a new one. Good luck, and hope this helps.
Jun 14, 2010 | Fuji FinePix A600 Digital Camera
Jammed Lens
take a look in this web.....maybe helps
regards
german
http://doekle.nl/canon_17_85_IS_repair.html
Apr 03, 2010 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
L730 wont turn on, lens stuck half way
Hi, Lens is jammed, lens motor gearbox requires restting. If you in the U.K I can help you out.
p.m me at kiddo242@hotmail.com
Aug 09, 2009 | Samsung Digimax L730 Digital Camera
Lens extends part way then jams. New battery does not help.
Have it repaired. There are authorized service centers throughout the county. I know of one in North Miami and Delray Beach, FLorida. You can contact Kodak on line as well
Apr 15, 2009 | Kodak EasyShare C330 Digital Camera
Lens jams when extending or retracting
This is either due to a cracked internal roller or a cracked/broken internal cam. The lens will have to be sent to Tamron for repair.
Apr 12, 2009 | Tamron 28-300mm f/3.5-6.3 Minolta Mount...
I have a camera canon powershot and the lens was out of the camera while it was off. Now when i try to power on the camera the message error: "lens error. restart the camera".
you have a mechanical jam in the lens gear chain. It happens often when lens is extended, the camera may have slight impact or pressure on the lens, it damages the plastic gear chain and jams. You can try with very light force, jiggle the lens while tuning on the power to disengage from the jam. If this does not help, you need a help from repair technician. Average repair price for this repair would be around $115. -James
Apr 07, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Nikon s200 when camera turned on lens error
You may have a jammed lens assy. When the camera is turned on, camera go through a few stages of processing to be ready to take picutre and if the lens does not respond mechanically, it will give you a lens error. Lens jams due to sand or impact (even unnoticable light impact). If the lens is extended out you can somehow grab the lens barrel lightly with two fingers while turning the power on and nudge it side by side. If this did not help, take it to a reliable local technician for a diagnostic(should be free). Good luck. -james
Mar 28, 2009 | Nikon COOLPIX S200 Digital Camera
Lens jammed on a kodak v1253
I fixed my v1253 following these steps:
1. Pulled the battery when the lens starts to come out before it could power itself off.
2. Gently pull the telescope out until it clicks.
3. Use a fine tip paint brush to clear debris out of the cracks.
Camera works just fine now.
Jan 30, 2009 | Kodak EASYSHARE V1253 Digital Camera
Canon 20d - lens stuck / jammed
HI BRIAN ,,I AM SAGHA CAMERA REPAIRER,I THINK UR PROBLEM OCCURS DUE TO JAMMING OF PLASTIC MOUNT ON THE METAL BODY OF 20D.TRY THIS
1} LUBRICATE THE JUNCTION WHERE LENS GET ATTACHED TO THE BODY WITH KEROSENE THEN TRY TO RELEASE THE LENS.REMOVE THE BATTERY FROM CAMERA ,TRY AND HEAT UP THE JUNCTION WITH HAIR DRYER A LITTLEBIT THEN TRY TO RELEASE THE LENS.
2}IF THIS THING ALSO DOESN'T WORK THEN YOU HAVE TO SACRIFICE THE LENS PLASTIC MOUNT PUT SOME SHARP KNIFE LIKE OBJECT IN THE JUNCTION OF LENS & CAMERA & THEN PUSH IT UPWARDS WHICH WILL BREAK ONE OF THE PLASTIC LENS MOUNT COLLOR AND LENS WILL COME OUT WITHOUT DAMAGING YOUR CAMERA .LATER YOU CAN GET REPLACED THE LENS MOUNT FROM SERVICE PERSON. BUT NOW ATLEAST YOU CAN USE CAMERA WITH OTHER LENSES.
Sep 29, 2008 | Canon EOS-20D Digital Camera
JAMMED LENS
The track inside of the lens and maybe other damage has been done. This is something that you cannot do yourself, unless you are trained, have access to the parts, and experience in camera servicing.
You should send the camera to the manufacture authorized service rep for an estimate.
Apr 14, 2008 | Samsung Digimax S600 Digital Camera
Canon PowerShot SD600 Digital Camera Logo
61 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
