Question about D-Link Express EtherNetwork DI-604 Router
Cable modem connection
How do I configure my router to work with a Cable modem connection?
    Novelist:
    Scholar:
  • 128 Answers
Step 1 Log into the web-based configuration by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing). Note: The address 192.168.0.1 is NOT on the Internet. The web-based configuration is built-in to the router. Step 2 Click the Home tab and click the WAN button. Dynamic IP Address is the default value, however, if Dynamic IP Address is not selected as the WAN type, select Dynamic IP Address by clicking on the radio button. Click Clone Mac Address. Click on Apply and then Continue to save the changes. Step 3 Power cycle the cable modem and router: Turn the cable modem off (first) Turn the router off Leave them off for 2 minutes** Turn the cable modem on (first) Wait until you get a solid cable light on the cable modem Turn the router on Wait 30 seconds ** If you have a Motorola (Surf Board) modem, leave off for at least 5 minutes. Step 4 Follow step 1 and log back into the web configuration. Click the Status tab and click the Device Info button. If you do not have a public IP address under the WAN heading, click on DHCP Renew and then click Continue. It may take a few minutes to obtain an IP address. Static Cable Connection The instructions below are for users who were given a static IP address from their ISP (Cox Business, TDS DSL, PacBell Business, Interbaun, InReach, Inficad, FlashCom, DCAnet, and Cavalier). Step 1 Log into the web based configuration by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing). Step 2 Click the Home tab and click the WAN button. Select the Static IP Address radio button and enter in your static settings obtained from the ISP in the fields provided. If you do not know your settings, you must contact your ISP. Step 3 Click on Apply and then click Continue to save the changes. Step 4 Click the Status tab and click the Device Info button. Your IP Address information will be displayed under the WAN heading.
Posted on Feb 16, 2006
Where to connect router on modem
Your modem should have an rj45 ethernet port. Connect your router with an ethernet cable to the modem. You will need to configure your modem and router to work properly. Once everything is configured, you will be able to share your internet connection through your router to all attached devices. For more information, please provide your exact make and model numbers for your router and modem and always remember, Google is a great source for information. Hope this helps.
Dec 04, 2013 | Motorola Computers & Internet
The cable modem is working but my wireless router isn't connecting to the internet.
1. Log into the router
2. On the configuration page make sure the "clone MAC address" is bulleted or checked.
3. Save settings / restart cable modem.
4. After cable modem restarts then restart the router.
5. log back into the router then go to the status page and make sure you have an outside IP address.
6. Open a browser (internet) to verify you have connectivity.
May 20, 2010 | D-Link (DI-784) Wireless Router
Modem router(quest gateway) works on one computer but won't connect to two other computers. was working on two ,and now only the one wired to it.
Place your wireless G router in a wide open and central location. Don't connect the power plug into the router, yet. Make sure your computer is turned off.
1. Step 2
Connect all the devices.
Find the Ethernet cable that connects your PC to the modem. Unplug the Ethernet cable from your PC and insert it into the wireless G router's WAN port. You should have an additional Ethernet cable that came with your router. Take this cable and plug one end into one of the LAN ports on the router. Then connect the other end to your PC's Ethernet port.
2. Step 3
Turn on your modem, router, and PC.
Plug the power plug adapter into the modem. Turn on the modem. It'll take approximately 30 seconds for the modem to boot up. Connect the power plug adapter to the router and the other end into a power strip or outlet. Like the modem, it'll take about 30 seconds for the router to boot. Turn on your PC.
3. Step 4
Verify lights are on for your devices.
Make sure the following lights are on for your router: power, WAN, and LAN light. If you don't see any of them lit, confirm these devices are turned on. Make sure the Ethernet cable connections are installed correctly.
4. Step 5
Install and configure software.
Use the setup wizard application to configure your Belkin wireless G router. Set up features, such as creating your password and setting up your time zone. Continue to follow the setup wizard so you can configure  other settings.
May 11, 2010 | 2wire (1000-400108-001) Router
PS3 and Netgear WGR614 V7 Router
Basically the PS3 wireless settings needs to be configures with the Netgear wireless router settings.
To test if the modem is connects to the Internet, connect a computer into the modem, if it works then the modem is configured correctly. If it doesn't work, then contact your ISP and get them to test your modem connection.
For details on how to configure the PS3 click on the WEB link :-
wii.php">http://fixhomenetwork.com/xbox-play-station-wii.php
Dec 20, 2009 | NetGear WGR614 Wireless Router
No internet signal, but full service.
You don't indicate your configuration or model, but assuming that you have a high speed modem (like cable or DSL) what usually works is:
Shut down your computer, unplug the cable modem and the router from power (remove the connection from the adaptor on back, no need to go to the wall unless that is more accessible) . Connect all three - computer to router, router to modem. Make sure that the ethernet cable between the router and the modem is in the router uplink port and that the computer is plugged into one of the four ports that look alike. Wait 30 seconds - plug in the modem. Wait another 30 seconds, plug in the router, wait another 30 seconds and boot the computer.
If this doesn't work, repost with what did happen. If you have a different configuration than I assumed, please post a clarification giving your actual configuration including model numbers.
Aug 03, 2009 | Computers & Internet
Bought a Belkin router model # f5d8326 4 v2 was told this worked for cable modems not working yet
Make sure the modem is configured properly so it would detect the router. Most of the time, modems now has DCHP capability, meaning it has the ability to hold the username and password you ISP has provided you. The most effective way of making modems work with routers is to bridge the modem first before connecting the router.
Bridging the modem is done by opening the interface of the modem. To pull up the interface of the modem, type the default gateway of the modem in the address bar of your browser(intenet explorer)
Look for the "connection configuration" button and choose "bridge ethernet" as the connection type.
Once the modem is bridged, connect the router to the modem, then configure the router to set the connection type to pppoe. Once done, type your username and pw your ISP have provided the save the settings. This should cpnnect you online..
May 12, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Linksys BEFSR41 Cable/DSL Router and RCA DCM425 Connection issue
hi,
first u configure the modem as bridge. And then u connect the linksys router, wht ever u config u configure in the router. it should work fine.........
Mar 12, 2009 | Linksys Wireless-G WRT54G Router
Configuring
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router and repeat the same steps.
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username (email address format) and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
if you are still having trouble configuring your device, try to call supportrix
Jul 10, 2008 | Edimax BR-6104K Router (br6104k)
Doesnt connect
hello!
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
if you are still having trouble configuring your device, try to call supportrix and use supportcall as your promo code for 1 free technical support. :-)
Jun 08, 2008 | Linksys WRT300N Wireless Router
Hooking up rounter to cox cable
hello!
-- is the router working fine before or is it a brand new router
note:
May 27, 2008 | Linksys Wireless-G WRT54G Router
D-Link Express EtherNetwork DI-604 Router Logo
261 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
