Question about Kitchen Ranges
Frigidaire flat top stove
Oven don't work and the surface wont heat but the clock works fine
rockitman187
  • 2559 Answers
SOURCE: Surface of stove heats very hot when oven is on.
This is normal and designed to do so.
Posted on May 15, 2009
SOURCE: GE Spectra range
I just moved into a new apartment and my stove wasn't working properly. After reading the very helpful information posted by kd3ke, I decided to turn off the breaker to my stove, take off the back covering, and check out what was back there. I was experiencing the same problem as posted.... the burner light, oven light and clock were all working however, the burners did not get hot nor did the oven. After taking off the back panel, the cord did have just as he stated, a black, white, and red wire however the plug attatching to the stove did not have cordinating colors. It was just a grey cord with 3 copper wire heads. It seemed to me that the cord was twisted and therefore everything was backwards. Since I was relying on his post, that would explain why the stove still did have some power, just not all, because the voltagages were wrong. I flipped the three cord wires, reconnected them to the stove and then plugged it in and turned on the breaker... everything works now!!! :) I don't know if this will help anyone else since it may not be the same problem if your stove was working properly previously, but it fixed the problem for me since I had just moved in.
Posted on May 24, 2009
SOURCE: Frigidaire Stove clock resets to 12:00 when igniters turned on
I have the same problem. This is an intermittent problem, maybe once every 20 to 30 starts the clock goes resets and the appliance beeps just like if unplugged it and then plugged it in again. I’m an electrical engineer and this sounds like the microcontroller that runs the appliance is being reset by noise caused by the spark igniters. This is definitely a design problem. Separating the wiring of the igniters and the control board should help. When I get a chance I’ll have to connected an oscilloscope and look at the noise. The control board microcontroller reset pin probably needs an RC snubber or an isolated ground. If /when I find something more definite, I’ll place another posting.
Posted on Jan 18, 2010
SOURCE: Frigidaire electric stove, burners work oven does not. No clock
one of the stoves does not work. What could be the problem and how to fix it?
Thanks
Posted on Sep 13, 2010
SOURCE: frigidaire model fef336ece.oven and broiler wont
thermostat possible open check not sure if this model has a resettable or not
Posted on Oct 21, 2010
Oven will not heat at all. Stovetop works fine
Phillip, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Oven Wont Heat or Not Working Bake and Broil Element Testing Oven...
Electric Stove Troubleshooting Oven Not Working
Top 6 Reasons Electric Oven Wont Heat Electric Range Troubleshooting
Stove Terminal Block Replacement Frigidaire Electric Range Repair part...
Jun 17, 2016 | Kitchen Ranges
Why would there be no heat from frigidair oven elements?
Make sure the oven timer is set properly, if its turned off, the oven will not go on. Also check if the oven has separate fuse, it may have blown.
Aug 24, 2014 | Frigidaire Stove/Oven/Range Black Glass...
Top and bottom heating element does not work on Frigidaire electric range ES300
Usually when both elements are not working and everything else is working fine, the problem is your OCU (oven control unit), commonly known to consumers as the clock.
The clock controls the oven and most times does not produce an error code when it fails.
You will need the actual model number from a sticker located on the oven frame when you open the bottom drawer, the sticker will have the model and serial number clearly listed.
Do a Google search for that model number and find the clock.
I've provided a link for what probably is the proper clock but without the full model number I can't say for sure:
http://www.appliancepartspros.com/frigidaire-clock-316207529-ap3764682.html
Apr 05, 2013 | Frigidaire PLEF398AC Electric Kitchen...
Thanks
Jan 06, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Our frigidaire flat-top electric stove stopped working
Sound like you make have a loose neutral on the cord where it attaches to the range or in the electrical receptacle where it plugs in, you can check the cord by pulling the range out, remove the small access cover to the cord connection area, after you have unplugged it and just tightened all the nuts to all connections on the cord. I advise an electrician to check the receptacle. I hope this has helped you. Have a great new year.
Dec 28, 2017 | Frigidaire FEB27S5A Electric Single Oven
Frigidaire model MGF331BFWA...Oven isn't lighting(heating)up
Stove wont heat up. Stove top elements are working fine. do you think it is the heating coil/element in the oven?
Mar 01, 2009 | Ovens
Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Dec 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Kitchen Ranges Logo
166 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
