Nintendo Wii Console Logo
Posted on Aug 21, 2011
Need to connect to internet - Nintendo Wii Console
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Aug 21, 2011
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
1346
Points
18
Turn on your Wii and on the menu in the bottom left corner use your Wiimote to press the "Wii" button. Then click "Wii Settings". Using the arrows on the wiimote scroll to the right once and select "Internet". Select "Connection 1" and choose either wirless or wired internet. From there just follow the steps for either option you chose. Enjoy internet on your Wii!
How do i connect to the internet i changed me service?
hi Inga.
see if this helps you out.
To open Network Connections, click Start, click Control Panel, click Network and Internet Connections, and then click Network Connections. If your DSL or cable modem is always connected and your ISP does not require a user name and password, you do not need to run the New Connection Wizard.
How do you get access to the Internet? Internet Service Providers (ISPs) If you want to access the internet at home, you'll need an Internet Service Provider (ISP) and a router to connect to the ISP. ISPs often provide a router with their service. This means more than one computer or device in your house can use the broadband connection at the same time.
you could also go to this link and its a step by step way of finding out how to connect tp the internet,
How to connect to the internet
3answers
Router operation without Internet connection.
Yes i can help you with this
You dont need internet connection
1helpful
I need diagram to connect t3624, I can't connect
A Diagram to connect to the internet? No Such Thing!!!
If you are having problems connecting to the internet tell us what is going on. What happens when you click on Internet Explorer? Do you have an Internet Service Provider? Did you pay the Bill?
1helpful
How to get internet work in samsunge250i
Hi Hello, you want to connect the internet, try this if you to connect the internet you need the GPRS setting on your cellphone, and if you that setting i think you are successfully connect to the internet.
but you need to load you sim before you connect the internet. i wish that i help you. :)
404 error on samsung SGH E250 while connecting internet .......help me with a solution for this
Internet connection setting is on wired and i need to change it to wifi
I believe this website can answer your problem.
Note: You need either an "Xbox 360 S" console with built-in WiFi or an "Xbox 360 Wireless Networking Adapter" to have a WiFi internet connection. If you can use a wired internet connection, you should use it because a wired internet connection connects faster than a wireless internet connection.
Do we need wireless internet to be able to install our internet tablet mid 7015 4G?? If we can connect with regular internet how do we go about doing this?
If you need to connect to internet by wire then you need the following.
  • An internet connection
  • A Router that has RJ-45 port(s)
  • A straight network cable
  • Device with RJ-45 port with built in LAN card (In your case it is "internet tablet mid 7015 4G"
Connect the straight cable with the router and connect the other end with your device where you want the internet.
1helpful
2answers
Modem
Assuming that Windows has recognized the modem, and has loaded the correct device-drivers, Windows can use the modem.
You'll need to find an Internet Service Provider that provides "dial-up" service.
You'll need to have a land-line telephone (not a cell-phone) with your local telephone-company.
Connect a 4-wire cable (not an 8-wire Ethernet cable) from the "line" port on the modem to the telephone wall-jack.
Then, follow the instructions given you by your Internet Service Provider to configure your modem to connect to their dial-up server. Or, telphone them, and their Technical Support staff will guide you through the necessary configuration steps.
Internet
Start from ground zero
1. Is everything Powered up?
2. Check you internet connection
a. Can you directly connect to the internet by connecting a computer to the device providing the internet?
If this is good, then do this for later. ( it may not be needed but is good to have)
go to 'Start' -> 'Run' ->CMD[Enter]
Now you have a DOS box.
here
type CD \[Enter]
type IPCONFIG /all > ipdata.txt[Enter]
exit[Enter]
This copies the working IP Config that may be needed later.
Now connect in this order Internet connection to WAN Connection of router
Then connect one of the the LAN Connections of the router to
the working computer.
Turn off everything for 15 min.
No I am not kidding. Technical reason: Clear the ARP Table back at the ISP.
Restart the router then the computer.
Still no internet?
More details will be needed.
Router Make and Model
Internet Connection Type
Computer Make, Model OS and Version.
Good Luck
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
