I have a Midland Marine Radio 78-101 that does not power on. 12V is going into the unit but when I turn the on-button, nothing happens. There are no on-board fuses. Any idea what the problem might be?
SOURCE: Reset button or fuse
washer keep draining
Posted on Jan 13, 2008
robotek
  • 1512 Answers
SOURCE: unit wont turn on
.Hi jepenny
The board you are looking at is the standby cct and power switching PCB. It sounds like that is working, so you have probably lost power to the transformer primary or the transformer is open circuit. Check for blown fuses and replace with exact same type and rating.
Be sure to unplug at the wall before touching any internals!!
If you can find no blown fuses, the power transformer may have failed. Good luck, get back to me here is you need any more advice. Thanks for using "FixYa"
regards
Graeme
Posted on Feb 18, 2008
SOURCE: wii fit board wont sync
Ok I feel a little silly, there is a sync button on the console (inside the flap by the power on button) and the board (inside the battery compartment on the underside of the board) as soon as I pressed them at the same time it worked. Goodluck everyone.
Posted on Feb 09, 2009
  • 85 Answers
SOURCE: how to attach 12V to car fuse box
if it is led it most likely is a low volt and very low amps. you can go behind the radio and find the switched wire using a test light when you turn on car the test light will light you want to use this wire and splice it in using the blue scissor type splicers no cutting or soldering required. This wire will be close to the black and red wire going into radio. Possibly a red wire as well if there are two red wires one might be switched and one always on for retaining clock or radio stations in memory.
Posted on Feb 21, 2009
  • 3 Answers
SOURCE: Clarion M5675 won't turn on
Take the stereo all the way out and hook the black wire to the negative terminal and the yellow and the red wire to the positive terminal on a charged car battey. If it still does not turn on you may have fuse in the back of the deck. If not it's probably fried.
Posted on Apr 19, 2009
I have a Midland VHF Marine radio mod 78-100 and I have lost the three pin power cord. anyone know the +/- configuration within the existing pin setup so that I can make another?? The cord is NLA.
I quickly checked the net for available diagrams and didn't find one for your radio. If you feel comfortable simply remove housing from the radio and check color of the wires and markings where those wires are connected to circuit board.
Feb 02, 2018 | Midland Boating
Will a Midland 75--810 communicate with a marine band radio?
Sorry Paula
The 75-810 is an CB radio that DOES have Wx capability but it won't communicate with marine band VHF's.
Hoe this helps you out.
-Steve
Oct 31, 2015 | Boating
Any trick to power up radio? Radio has 12 V connected and will not turn on
There should not be a "trick" to getting the radio to work. Make sure that the power connection is actually sending 12v. Also verify that the ground is good, that can cause issues. If possible, connect another 12v device to the power and ground and see if that one works.
If so, there may be a fuse on the radio that is blown. There are often fuses inside the case, near the power supply. If you are comfortable doing it, open the radio and see if you can find a fuse and verify that it is good. If not, take it to a radio shop and have them check it.
Oct 31, 2014 | Boating
How do you turn up the power on a midland 1001z
have you ever listened to a radio that 4 channels away and you have to go to that channel to hear what they are saying and they sound great? Well actually they don\'t because if they did they wouldn\'t be splashing you 4 channels away.A cb radio is supposed to put out no more than 4.5 - 5 watts max. thats because you will be the one doing the splashing if you turn it up to much.For one thing not only do you have to turn up the modulation and the power but also the voltage it takes to operate the radio at the higher voltage and this is the killer ,you will still sound better at the lower voltage but you will have no voltage to run the power so now its not activated so you turned it up for nothing.
Feb 13, 2014 | Midland 1001Z 40-Channels Base CB Radio
I have a Midland 1001Z (in use about a year) that draws power when it is off. This happened when the unit was not in use and drained the car's battery. On the bench I checked and there's about 500...
it shouldn't be drawing. if there was a real problem with the radio it shouldn't even turn o..,off.clicked is switch power the juice.pulling actually is it if see actually to meter clamp a need would you resistance will have nothing to do with power drawing. you will alwayssee zme sort of resistance. on. I have left a cb on in my vehicle for over a week and it did not kill the battery. I think what ever drained your battery has little or nothing to do with your b radio. ohms is resistance. it is not a measurement of current. this does not tell our it is drawing anything
Jul 06, 2011 | Midland 1001Z 40-Channels Base CB Radio
On many of my Midland G-30 / G-28 radios, when you turn them on, the display shows full power. When you press the PPT button, the unit shuts down and the display show OFF. I've tried many battery/radio...
I had the same problem with my Midland G-30 radios. The problem is with the batteries not the radio. I put a test meter on my batteries and saw the were not making full voltage/amperage. Got two new batteries ($15 each on ebay) and problem was solved. These are great GMRS portables. Replace the batteries and you will be very happy with the unit.
Apr 20, 2011 | Midland G30 (15 Channels) 2-Way Radio
Nothin will work
If you've got 12v constant on the yellow, 12v switched on the red, and chassis ground to black, your fuses are good the radio is powered properly.
When you plug the harness into the back of the radio you should hear the CD transport cycle. That's telling you the radio's getting power. Hit the reset button (pin-hole switch on front panel) and hold the small square open/close button for 2-3 seconds.
If still nothing, the radio needs service. I'd send that model to Alpine in CA for repair.
Jan 26, 2008 | Alpine CDA-7998 CD Player
Computers & Internet Logo
119 people viewed this question
David Payne
David Payne
