Question about Empire DV-35 Heater
Empire DV-235-1 Heater
Heater is old but really runs well with two issues.
1) lighing pilot can be a little difficult due to significant air flow from heater through pilot opening when the cover is open - it is okay if you use a lighter - but matches blow out.
2) pilot always goes out after three days - light again and it runs for three day and out again.
    Genius:
  • 1,665 Answers
Check also for any bad dirty or loose wire connections.
Posted on Sep 08, 2008
    Scholar:
  • 163 Answers
Its Wiring harness connections may need inspection and cleaning.
    Scholar:
  • 191 Answers
There is a thermostat which is creating the problem
  • Moses Clive
    Moses Clive Sep 08, 2008
    Check the element connections which are pushed on spade connectors. see if one of
    them has come off. just push it back on its terminal and it should work fine.
    Regards
I have a Empire wall furnace Model # DV-235-2-SG 3500 BTU'S the electrical igniter will click but the pilot won't go on.
Clean the hole of the pilot light and clean the metal where the spark comes from and goes to. Could be bad igniter though.Mine here iffy, so I just light it with a long match while holding down the button in pilot mode. don-ohio (:^)
Dec 23, 2016 | Heating & Cooling
So much air blowing in the pilot on DV-35-2SG heater won't stay lit
Unfortunately if its wall vented the wind can hit it just right and pop off the pilot this happens on older models a lot check your vent if its too much of an aggravation you may have to relocate it
Jan 17, 2013 | Empire DV-35 Heater
EMPIRE MANUAL DV2353SG
I believe all the Empire manuals are there to download or read at their website: EmpireComfort.com.
Nov 08, 2011 | Empire Direct Vent Wall Furnace;...
My empire heater wont turn off and just keeps blowing cold air. pilot is lit and all thermostat wires seem to be connected. any ideas?
Sounds like the thermostat for the blower motor (not the gas thermostat) has shorted. Remove front cover on stove. Follow the wires from the blower motor back to the blower thermostat. Replace with new one. Blower model # DRB-1.
Dec 04, 2010 | Empire DV-35 Heater
I have an Empire dv 210 gas heaterand pilot wont stay lit
The thermocouple has went bad Here is a link that describes what a thermocouple is how to replace it and has instructional videos
http://www.ehow.com/way_5185498_thermocouple-replacement-procedures.html
I could try to describe the procedure. But the link is more detailed and the videos are really good.
Hope this helps
Please leave feedback
Dec 11, 2009 | Heating & Cooling
Heater doesn't start.
Check the length of your thermostat wire. Mine was about 10ft and I experienced the same problem. Reduced it to 6 and the problem was fixed.
Oct 12, 2009 | Empire DV-35 Heater
Pilot lights and one panel burns
Empire faw 40 makes a loud bang when starting up. There are three burners. The pilot light is on one burner. When the furnace starts, gas is lit on that burner and the flame is passed on to the other burners by a small channel that can get stopped up. You just have to remove the burners and clean the channel with a small file, like on a finger nail clipper. This can be difficult due to the pilot assemble being attached with two bolts. The bolt on the right has to be removed with a short screw driver. You can not get a socket on it. After you remove it there is enough play to remove the bracket and gas burners.3_4_2012_5_06_50_am.jpg
Nov 23, 2008 | Empire DV-215 Direct Vent Natural Gas...
Empire DV-215 Low Flame Issue
Either a restriction in the gas train, low gas pressure or a bad gas valve. Check the pressure on the gas line when on pilot and again when the burners are running. Depending upon what type of gas it runs on, you should have at least 4" W.C. if Natural Gas and 10" W.C. if Propane. If gas pressures test good and all valves are open, you are looking at replacing the gas valve.
Dec 08, 2007 | Empire DV-215 Direct Vent Natural Gas...
Empire DV-35 Heater Logo
513 people viewed this question
Top Empire Heating & Cooling Experts
Paul Carew
rudyjoe
Level 1 Expert
vance jones
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
