Question about Intel Motherboard
Ethernet card?? I called my internet provider to have them check my service as I am having problems connecting to the internet. They had me run a command prompt (ipconfig) which came back with the message "media disconnected". I was told that they believe that I have a problem with my ethernet card. I tried using the free downloads to "fix" the problem but my computer won't run the programs. Is this something I can fix myself or do I need to take it in to have the ethernet card looked at and possibly replaced?
    President:
  • 2,961 Answers
Ethernet pci cards are very cheap, if its a desktop pc, turn it off, switch off at mains, but keep plugged in, then touch something metal to discharge yourself of any static.
Simply remove the side of your pc and unscrew the clamp that holds in the card, pull card out, push new card in gently then replace the clamp and screw.
Restart up pc and the card will be found automatically, then ask for the driver cd, run the cd, and your up and running again.
Posted on Sep 07, 2008
My dell optiplex sx280 cannot connect to the internet.how do solve this problem?
Check if you have proper Ethernet Card Drivers
If you are connecting via modem check drivers for the same.
please have a word with you Internet Service Provider.
Let me know what happens
Apr 30, 2014 | Dell OptiPlex SX280 PC Desktop
How Do I connect to internet with my desktop without Ethernet cable
To connect wireless to a network ..you need a wireless router or access to a near by one ..and you need to install a wireless card on computer if it has non ..This can be a pci card and you will install it on a pci slot inside and install its driver and after that connect to the network available ..or use a wireless card on usb ..
If you do not have a network free near by ..you can connect using the wireless card to another computer connected to the internet ..or install a wireless router on your Ethernet cable ..and a card in computer or a usb one ..
In my opinion the wireless card and router is the best way cause connecting trough another computer can be tricky and slow..
another way ..if you do not have any other means is to use a wireless modem on usb from a mobile network ISP (internet service provider )
This can be the same provider as your mobile phone one ..
Dec 18, 2011 | Dell Dimension 4500 PC Desktop
Internet not conect
If you are unable to connect to internet. There are few things you can try:
1) Reinstall the Ethernet drivers. Go to control panel> add/remove programs> uninstall the Intel or Realtek Ethernet drivers.Then reinstall the drivers from the motherboard disc provided with this pc. Make sure you install only the ethernet drivers.
2) If your pc is giving any kind of error message like limited connectivity then its a problem with your ISP(Internet service provider) or the windows operating system itself. Call your ISP and let them check the issue if they can't help go for a repair install of windows using the disc.
Hope that helps!
Sep 17, 2011 | Dell Dimension 4500 PC Desktop
Safari wont load pages on a mac
Are you using wireless or wired connection? Have you already called your internet provider to check if the problem is in their end?But no worries there's a lot of trouble shooting step you can do to to fix the issue.
If your using wireless connection I suggest to use wired or Ethernet connection first to isolate the problem and follow the step below:
1. Go into System Preferences -> Network and see if you have a "green" button for the "Ethernet Connection". If it is red, it is disabled. Also check to see if the Airport interface is also green and at the top of the list. If it is, you should turn it off and move it below the Ethernet connection. If you are running Leopard, you can do this by clicking on the little "gear icon" at the bottom of the left column and choose "Set Service Order". Then drag the Ethernet service so that it appears above the Airport service. If the Ethernet service is red (disabled) use the same button to "Enable the service".
2. If you don't see the Ethernet Service, try to add it by clicking the "+" button.
After any changes you make, make sure you click the "Apply" button.
3. If all of that doesn't work, reboot and reset your PRAM followed by a Safe Boot.
You should also disable the other services like "bluetooth" and "firewire". I am referring to the Network Preferences only. You can keep bluetooth enabled for keyboard, mouse, phone, etc. You just want it disabled as a Network service.
I hope this information will be helpful. Thank you for using FixYa!
Your feedback is greatly appreciated.
Mar 07, 2011 | Apple safari
Modem keeps loosing connectivity. I have to turn off the modem and restart it to access the internet. Running 2Wire Gateway.
call your internet service provider and report first this incident. in most cases its with the service provider that has problem causing disconnection in your internet.
Take a look also with your modem device, observe when you got disconnected does led indication lamp turn off or your modem restarted itself. that could also be a problem with the power supply of your modem. better check with multitester if output voltage from power supply is dropping.
go check also the ethernet cable if this is not loose, fix it properly, you should hear a snapping sound means it is lock properly.
Feb 09, 2011 | AT&T High Speed DSL Modem
Not conect internet
first you must have an ISP Internet Service provider which will provide you with a modem and leads you can choose either a dial up,usb,or an ethernet connection to connect to the net or if you have a laptop you can choose a wireless usb modem which can work on a desktop aswell once you recieve the modem just insert the disk provided and follow the prompts
you might have put in the wrong password or user id check to make sure you have put these in correctly first make sure the caps lock is on/off what ever applies to your user and password id that you provided to your ISP
also
make sure your routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps
Jan 19, 2011 | ASUS GEFORCE FX 5200- X 128MB DDR AGP8X...
I have had problems connecting to internet all weekend (internet - red light), am on now but internet and ethernet green light keep blinking, is this ok.
No because dsl light should be solid green light. You need to contact your ISP to check if there is a problem on the network.
Jul 11, 2010 | Computers & Internet
US doesn't stop blinking!!!
Heres how i install my modems
1.Turn off all equipment
2. Take an ethernet cable going from the modem, and plug it into the ethernet slot on the computer.
3. plug in the modems power and give it 1 min to power up.
4. Power up your computer and see if it gets connection.
Troubleshooting.
1.Go to the control pannel and look at internet connections.
2. Look for your connection (LAN), and see if is connected.
3. If it isnt connected than it is a problem on your ISP's side.
For other support
1. Call your internet service provider for help.
2. Call the customer support line for the modem.
May 09, 2008 | Linksys EtherFast Cable Modem with USB and...
Dell inspiron 1525
check your lan card maybe it is disable, try to enable it
Apr 12, 2008 | Dell Inspiron 6400 Notebook
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
