Neff 24 in. S5409X0 Built-in Dishwasher
How do I reset my dishwasher
posted by lizzie21 on Sep 07, 2008
Hi, I have a Neff S5409 and have the problem where it sounds like it is trying to drain and will not fill with water. We have checked the filters and removed the inside cover to check for blockages, there weren't any. The dishwasher then worked ok, but finished the programme and hadn't drained. I then put it onto another programme and it drained ok. I have gone to use it again and now will not fill at all, just the sucking/pumping sound. Any ideas what could be wrong please, typically the machine is just over 2 years old and out of warranty. Is there any way I can reset it, cos it sounds as if it's confused to me. Incidentally have just returned from 2 week hols and it was working fine before we went and used iton our return about 6 times before the problem occured. Thanks for your help.
Comment posted on Sep 08, 2008
Thanks I'll get hubby to give it a go, how would it suddenly flood though when I had been using it perfectly ok.
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Sep 07, 2008
Helpful (85)
TaPuna
Rank:Master Master
Rating: 85%, 5 votes
Sounds to me like you have put the dishwasher into flood mode, this happens when there is water in the base panel, try leaning the dishwasher back and see if any water comes out. :)
Comment posted on Sep 09, 2008
sometimes dishwashers flood when too much powder is used as the foam can overflow into the base. If you have just cleaned it and taken the spray arms off make sure they are the correct way up and not blocked as this can also do it :)
Rating Locked! (?) lizzie21 has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on How do I reset my dishwasher:
I don't want to Accept this solution
Can you Help with these Dishwashers problems?
aquasafe gets hot will not start but wants too ?and...
put detergent into salt cpmpartment !! PLEASE HELP
Hi, I have a Neff S5409 and have the problem where it...
The dwasher does'nt seem to want to do anything when...
I have a builtin Kenmore dishwasher that has a lock on...
Loading problems.
Repair Service
Find Dishwasher Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
