Hi I have a Beko Washing machine WM5552 T. Lately the electrical control is giving me different cycle ti,es on the LED. e.g If I put a load in today it will tell me it is going to take 1.5 hours, then tomorrow it will tell me that it is going to take 15mins!!! Please help
  • 1462 Answers
SOURCE: Whirlpool washing machine
check that the machine ramps up to spin speed reasonably and distributes the clothes- ie doesn't spring straight up to spin speed. if this is ok then the fault may well be the shock absorbers located at the bottom of the machine and going from base to tub. check also that the counterweights are intact
Posted on May 09, 2007
Timon90
  • 126 Answers
SOURCE: washing machine
Check the brushes in the motor.
Posted on Jan 28, 2008
  • 22 Answers
SOURCE: washing machine will not spin or drain
look at my post "eco smart won't drain, smells hot". It could be something stuck in very lowest part fo drainage area. you have to remove the motor on bottom of washer to see into this area and remove blockage.
Posted on Oct 21, 2008
barkencoa
  • 3463 Answers
SOURCE: how to change brushes on beko washing machine
remove rear cover of washer, locate and remove belt.
Unfasten motor ,disconnet motor lead, and remove motor.
Brushes are located at opp end to motor pulley.
Replace if less than 5mm long.
Plz rate my solution.
Thanks
Posted on Jan 21, 2009
  • 2468 Answers
SOURCE: My washing machine is blowing my fuse!!
either the motor start capacitor on the machines motor is shorted,the motor winding itself is grounding itself out to the case and shorting or you may have a bare wire touching the metallic frame in the machine
Posted on May 14, 2010
Why is my washing machine not shutting off the water and flooding?
It sounds like you need to replace the Water Solenoid or Solenions.
This is where your washer hoses connect to your machine . They are little electric valves that open and close to put water in your machine . It is getting stuck opened and over filling the machine . Here is a like to where I get parts to fix almost anything . Good Luck !!! Grant
http://www.m-and-d.com/Appliance-Parts.html
Aug 11, 2014 | Washing Machines
Have Beko WME7247W Washing Machine problem. On full wash the mc loads water then stops. Timer does not progress. Water does not heat. Drum does not turn. On Spin and Drain cycle pump works but spin does...
I had a similar sort of problem, and finally called a Beko engineer out. The machine was pushed too far back and had either blocked the water pipe, or waste pipe.... can't remember which, but simply pulling the machine out by an inch cured the problem!
Mar 09, 2014 | Beko WME7247W Washing Machine
Washing machine fills with water but then won't wash, spin or drain
Hi Claire if your beko washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Jan 28, 2014 | Beko Washing Machines
Hi, my Beko washing machine, WMA 1512 W stops half way through wash cycle and leaves conditioner in drawer, won't rinse and I have to manually turn dial to spin, any ideas please?
Beko washing machine, WMA 1512 W stops half way through wash cycle and leaves conditioner in drawer This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 26, 2013 | Beko Washing Machines
I have 2 duet washing machines and am familiar with fixing the F21 problem as described above, however, this time with our newest duet, only about 1.5 yrs old, I took the panel off and checked the...
F21 F 22 CCU /touchpad/LED assembly unable to transmit/receive data to/from the CCU central control unit
Possible causes/procedure:
1. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the
touch-pad/LED assembly and Central Control Unit (CCU).
9150 tech sheet
Jan 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a kenmore he2 plus washing machine that keeps giving a code of f-21 on the final rinse cycle. i cant seem to figure out why that happens. sometimes it works, sometimes not. what could be causing...
HI. This error occurs if the touchpad/LED assembly is not able to transmit/receive data to/from the central control unit (CCU).
Possible Causes / Procedure
1. Check the touchpad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touchpad/LED is responding.
2. Unplug washer or disconnect power. Gain access to the touchpad/led and CCU assembly.
3. Check wire harness connections to the touchpad/LED assembly and Central Control Unit (CCU).
Replace failed component.(which will be the CCU, if the harness is connected without any faults or worn connections present)
Nov 25, 2009 | Kenmore Washing Machines
Brand new dishwasher, doesn't drain water and will not work now!
hi,
try this site
http://www.cookshomeappliance.com/dishwasher_troubeshooting.htm#Constant Noise During Washing or Drying
please rate my suggestion..
Apr 11, 2009 | Beko Dishwashers
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
