Battery not charging
Battery will not hold any charge.
Indicatorlight flashing orange all the time.
Power option says battery not connected ???
Any suggestions ?
    Brigadier General:
  • 5,158 Answers
Make and model of the laptop
Robert
Posted on Sep 07, 2008
Battery Light Flashes Orange My battery light is flashing orange (4 times)
Does the battery hold charge for long?
THe flashing means not charging..
test another power adapter or change battery
Sep 18, 2013 | Lenovo 3000 N100 Notebook
Orange light flashing, no chargine
A replacement battery must be the EXACT same power spec as the original in DC volts and Milliamps, or you could damage the Mobo components. Some aftermarket batteries do not work well. The connections may be different.
Jan 31, 2013 | Dell Latitude E5500 Laptop
Battery indicator flashing red when running on battery or on main supply and battery is 75% charged
When your battery indicator is flashing Red, it usually means that the charger is defective.
Dell also had a recall on some of its batteries. To see if you qualify for a free replacement click here: http://www.dellbatteryprogram.com/
If you want to reset your battery utility follow these steps:
1. Let the battery run completely dead. (Make sure all your work is saved)
2. Fully charge battery (You may still have flashing lights but if you turn your computer on and enter BIOS you can see the charge level)
3. Once again run battery dead.
4. Remove battery and wait 5-10 minutes.
5. Replace battery and use in normal operation.
If you found this information helpful, please give me a big thumbs up when you rate my answer. Thanks!
Feb 03, 2010 | Dell Latitude D600 Notebook
I have a Dell Inspiron 1525 that won't start. The battery light would flash orange 4 times then blue once, and then start over with the same sequence. Pulled the power board and fixed the solder joints on...
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
Dec 27, 2009 | Dell Inspiron 1525 Notebook
Continuous alternating one green and three flashing red battery
note.gif NOTE: Battery operating time (the time the battery can hold a charge) decreases over time. Depending on how often the battery is used and the conditions under which it is used, you may need to purchase a new battery during the life of your computer. Check the battery status light — If the battery status light flashes orange or is a steady orange the battery charge is low or depleted. Connect the computer to an electrical outlet.
If the battery status light flashes green and orange, the battery is too hot to charge. Shut down the computer, disconnect the computer from the electrical outlet, and then let the battery and computer cool to room temperature.
If the battery status light rapidly flashes orange, the battery may be defective. Contact Dell _I found this on : http://support.dell.com/support/edocs/systems/latd820/en/ug/index.htm Hope this helps and good luck. if i "fixed ya" please rate me. thanks-jmattes
Oct 22, 2009 | Dell Latitude D820 Notebook
My battery light flashes green and orange whether its charging or unplugged? is there a problem?
Flashing green and orange: battery is too hot to charge
if it flashes orange 4 times it means a defective battery
check the system setup (usually by hitting something like F2 or DEL when the laptop first powers on). there should be an option in there to "re-learn or "refresh" the battery. it will send it through a few charge/discharge cycles and then if the battery isn't toast it should work thereafter
Jul 07, 2009 | Dell Latitude D600 Notebook
Latitude d505 not charging
If the system runs using the AC adapter, but the battery doesn't hold a charge and the battery indicator LED flashes orange, then replace the battery (A battery with an internal failure may flash 4 times orange then once green and repeat)
The normal lifespan of a PC battery is 300 to 500 recharge/discharge cycles (roughly 12 to 18 months)
Jan 31, 2009 | Computers & Internet
Dell Inspiron 5160 flashing orange / green power LED
If your Dell notebook battery flashes four orange one green, there might be a problem with your battery.The battery life is also shorten and doesn’t last longer than an hour.gets hot sometimes.
pls see this if it helps
http://www.wareprise.com/2007/07/05/dell-notebook-battery-flashes-four-orange-one-green/
pls do rate me FIXYA if i helped u
Nov 29, 2008 | Dell Inspiron 5160 Notebook
Dell latitude D600 battery charge light flashing
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 09, 2008 | Dell Inspiron E1705 Notebook
Dell Latitude C610 battery claims its too hot to charge....
The charge light flashing orange-orange-orange-green....-orange-orange-orange-green.... usually means the battery has reached the end of its life and now it needs replacing.
There are three ways to test your battery:
1) If the battery has a button on the bottom of it and a row of 5 leds, then push AND HOLD the button for 5 seconds. The LEDs should all turn OFF, then turn back on showing a pattern. If all five LEDs turn on, the battery is dead.
2) Open the Dell Quickset application (doubleclick it in system tray), go to Battery Meter, go to the battery health tab, and pick your battery. It should tell you there if the battery is healthy or not.
3) Reboot your computer and go into the bios. Pick the Battery tab in the bios. It will list the battery health there.
Jan 20, 2008 | Computers & Internet
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
