Question about Belkin (F5D72304F5D7000) Router
Range I do not seem to get very good range out of my 54g products?
    Novelist:
    Scholar:
  • 128 Answers
All wireless products are subject to radio interference. The performance is a direct result of the operating environment. Other products that use the same frequency can drastically reduce the performance of the wireless product. Try changing the operating channel or moving the wireless Access Point.
Posted on Feb 16, 2006
Cant connect belkin 54g router to internet
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Jan 07, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Tip
What wireless network card to I need to use on my WLAN ?
In 1997 the Institute of Electrical and Electronics Engineers (IEEE) created the first WLAN standard.
They called it 802.11 after the name of the group formed to oversee its development. this first version only supported a maximum network bandwidth of 2 Mbps today it has been improved to over 300Mbps using MIMO devices based on this first version, a comparable wired LAN on CAT5e Ethernet twisted pair cables usually is classes at a minimum of 10Mbps to a maximum speed of 100Mbps (often called 100/10Mbps)
Here is a summary of all the Wi-Fi versions and letter numbers upto the present day in 2010.
In 1999, the 802.11b specification was released for the the domestic market, supporting bandwidth up to 11 Mbps at the same time the 802.11a was released for the business market upporting bandwidth up to 54 Mbps it was much more expensive and signals had more difficulty penetrating walls and other obstructions so it was dropped.
In 2003, WLAN products supporting a newer standard called 802.11g it combines the best of both 802.11a and 802.11b it supports the same bandwidth as 802.11a of 54 Mbps (hence it is often called 54g this is the Wi-Fi standard), it uses the 2.4 Ghz frequency for greater range the 802.11g technology is backwards compatible with 802.11b, all WLAN cards will call this 802.11b/g
Some versions offer 128g which is 54g twice but only if the router will supports this doubled speed, the majority of all routers use a V.90 modem which will only support 54Mbps (aka 54g).
The newest IEEE standard in the Wi-Fi category is 802.11n (called MIMO technology) . It was designed to improve on 802.11g in the amount of bandwidth supported by utilizing multiple wireless signals and using antennas instead of one, it support data rates of over 100 Mbps upto 300Mbps and also offers somewhat better range over earlier Wi-Fi standards due to its increased signal intensity. All 802.11n equipment will be backward compatible with 802.11g/b networks.
Most internal WLAN cards are plug and play on the PCI bus, however more and more version are being provided as either a USB or PCMCIA version for laptops and desktops, this version below will work with all versions 11b, 54g and 11n upto 300Mbps ( if the router that you have will suport it.
The latest technology is called Wi-MAX is designed for long-range networking spanning miles or kilometers as opposed to local area wireless networking or WLAN. The other end of the Wireless technology spectrum, that split from 802.11b is called BlueTooth and works up to a maximum distance of 10 Meters used exclusively as the standard in Mobile Phone devices like headphones and short distance inter-connection to other phones and PC's.
on Jul 21, 2010 | Computers & Internet
The wifi range only works in the 2 closest rooms to the desktop computer that has Belkin 54G Gateway router. If we go to other rooms in house with laptops, the wifi no longer works. How can we improve...
There are a number of Wireless Range Extenders on the market which will suit your requirements.
They work with your existing wireless router, use Google to search for these products.
Dec 11, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
How does the wireless range of 54g compare to 802.11b and 802.11a?
The range of 54g products is the same as 802.11b. They both operate in the same 2.4GHz frequency. Both 54g and 802.11b have better wireless range than 802.11a.
Feb 16, 2006 | Belkin (F5D72304F5D7000) Router
Is 54g certified by the Wi-Fi Alliance?
54g products can be certified today by the Wi-Fi Alliance for interoperability with 802.11b products. Broadcom is working with the Wi-Fi alliance to accelerate interoperability testing among 802.11g products.
Really see 54 Mbps with 54g?
As with any wireless protocol, 54g has overhead associated with it that limits performance. While signaling data rates of up to 54 Mbps may be achieved, like most shared media (e.g. Ethernet) throughput will be significantly less. There are two scenarios for 54g performance. In an environment with only 54g clients, throughput can exceed 24 Mbps. This performance is equivalent to that of 802.11a, although 54g is usually available over a greater range. The second scenario is where 802.11b clients are present. RTS/CTS flow control must be used to allow 802.11b clients to recognize and establish communications with 802.11g access points. This leads to delays in transmission and drops peak throughput to about 10 Mbps. 54g performance is still well in excess of the maximum measured speeds of 4-5 Mbps for 802.11b. The use of RTS/CTS is important because it provides determinism to the wireless network, ensuring a minimum bandwidth for each user. Like Ethernet, 802.11 LANs normally use a ג?œcarrier sense media accessג? mechanism to signal transmission without asking for permission from the network. As the network becomes highly loaded, collisions occur more frequently and the network can become saturated with packet retransmission attempts that eventually make it impossible for any data to get through. RTS/CTS provides a more formalized flow-control mechanism that avoids this problem.
Performance
54g products will perform differently depending on whether or not there is 802.11b traffic in the immediate environment. The rules-of-thumb for throughput are: In an 802.11g-only environment, throughput will be between 4-5 times the throughput of an 802.11b network. The maximum throughput can exceed 24 Mbps. In an environment that includes 802.11b devices, throughput will be about double the throughput of an 802.11b network. The maximum throughput can exceed 10 Mbps. In addition, all 54g radios have better sensitivity than current 802.11b radios, and 54g provides outstanding coverage in its 802.11b compatible mode.
What is the difference between 802.11g and 54g?
54g implements the latest draft of the IEEE 802.11g specification. The two primary distinctions between 54g and 802.11g are: 1) 54g is designed to enable 54 Mbps connectivity. The 802.11g draft specification makes 54 Mbps connectivity optional, and simply requires up to 24 Mbps connectivity to comply with the specification. 2) 54g products are based on the same wireless LAN chipset, which means they are interoperable. Because the standard is not final, it is not yet possible to test for 802.11g interoperability.
What is 54g?
54g is Broadcom's maximum performance implementation of the draft specification for IEEE 802.11g wireless networks. This technology is expected to quickly become the next mainstream wireless LAN technology because it works faster and farther, is backward compatible with 802.11b and is affordable. Authorized products displaying the 54g logo use Broadcom's 54g wireless LAN chipset and ensures that products are designed to be completely interoperable at maximum performance with other 54g products and are compatible with the draft IEEE 802.11g specification.
Belkin (F5D72304F5D7000) Router Logo
66 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
jason
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
