Question about iRiver Audio Players & Recorders
Just formatted my player and now when i switch it on it says FAT SUPPORT ONLY
  • Anonymous Jan 05, 2009
    I have the same problem and can't figure out how to fix it--any suggestions?
sandrew
  • 2961 Answers
SOURCE: How can I format the mp3 player?
Windows only formats in fat32 or ntfs, only Win95 or 98 formats in fat, so you may have to go to the manufacturer web site and look for a formatting programme. Otherwise, there may be a factory reset or similair on the mp3 player, select this and everyting should be deleted.
Posted on Mar 16, 2007
Mp3 player keeps saying "no files" when i unplug
I had the same problem. I formatted it to FAT format and it started working again. It has to be FAT. FAT 32 and EXFAT don't work.
Nov 08, 2010 | RCA TH101 MP3 Player
FORMAT ERROR
I finally figured out that when I format my Nano Plus, I have to select "FAT" from the "File System" drop-down list (even though the manual says you can select "FAT 32"). When I selected anything other than "FAT", Windows could not complete the format and the player would not get past the start-up logo.
Aug 08, 2010 | Audio Players & Recorders
When turned on the screen displayed FAT is
First try to reset the player 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. Next try to switch USB modes 1. Turn the player OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the player to the PC. If none of these things work try and format the player - You will lose all your music - sorry -- For your Clip: 1. From the Main Menu, select Settings > Format. 2. Select Yes. You can also format using Media Player -> start Media Player **** If you have Media Player 10 --- Connect the Sansa player to the PC in MTP mode (Previous step USB mode). Click on the Sync tab.( be sure your player shows in the pull down menu) Click the pencil icon on the upper right corner of the window. Click OK to start formatting. ***** Now if you have Media Player 11--- Click the Sync tab. On the left panel, look for the player. It is usually the last device listed. Right-click on the player and select Format Click OK to format.
Jan 23, 2010 | SanDisk Sansa Clip MP3 Player
I TURN ON MY MP3 PLAYER A SANSE FUSE AND IT SAY THE FAT IS CORRUTED PLUG IN TO YOUR PC TO RECOVER FAT
You can try to format the mp3 player.
Go through the : Setting>Control Panel>Administrative Tools>Computer Management>Disk management>
Try to format fat files system.
hope this help you
Regards
uttam
Dec 29, 2009 | SanDisk Sansa Fuze MP3 Player
Sansa fuze FAT error
Plug your Fuze into your computer. Open "My Computer," right click your Fuze and click "Format," a window will pop up with settings on how you want to format it, make sure it's set to FAT, then click "Format."
May 09, 2009 | SanDisk Sansa Fuze MP3 Player
Sandisk sansa problem
It isnt a fat or fat 32 player..It is a mp3 and or a wma player. And you could be missing the proper device driver depending on your computers os..Pre 2000? file compression file format
Jun 29, 2008 | Mach Speed TRIO Onyx MP3 Player
Format the player error
Connect the device in Storage Device (USB Mass Storage) Mode and then format the storage disc to FAT
you can use the DOS command:
format X: /fs:fat
This idea came from another tech not me.
Feb 05, 2008 | Lexar LDP-200 MP3 Player
Won't let me add music
For the Insignia NS-DA1G, NS-DA2G, KIX, NS-DV2G, NS-DV4G:
These units come set to a FAT formatting. If you have changed this to NTFS or DOS, you will cause problems with your player. Be sure it is formatted correctly.
If you have formatted your player to FAT (recommended), FAT-16, or FAT-32, try using the software reset in the MENU - Settings area of the players internal software.
Dec 11, 2007 | Insignia NS-DA1G MP3 Player
Mar 16, 2007 | Samsung YP-T7X MP3 Player
21 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
