Question about Maytag Washing Machines
The washing machine filled with water, put the soap in and then some towels, after I closed the lid and the machine stopped working.
  • Aaron Fredric
    Aaron Fredric May 11, 2010
    Hey there make, model and top or front loader please
    Genius:
  • 1,028 Answers
Sounds like lid switch went ..try raising lid and listening for click when closed ..even if it does click could still be switch there is a small fuse and contacts inside switch 3 screws along top of console to be removed and console will lean forward to allow access to switch
Posted on Sep 07, 2008
Hi there. I have a 9kg Tech-Magic Top loader. I loaded it with towels. It filled with cold water then it shut down-altho all the lights still working..it just stopped 1nc it reached desired capacity.
Maybe it is over loaded.....
Remove the towels and put into a bucket.....
Using a plastic bowl...try removing some of the water to see if it comes on after closing the lid again....
If all else fails, also try unplugging the unit for 30 minutes and plugging it back in.
Good Luck!
Mar 06, 2017 | Washing Machines
Beko wm5120...no power even with new fuse
Instructions
  1. Close the lid or door. Washing machines automatically stop when the lid or door is open. Lift the clothing and move it slightly. If the washing machine is overloaded with towels or heavy garments, it might become unbalanced. The washer won't run until the items are adjusted.
  2. High-efficiency machines might stop running when regular detergent is used or too much high-efficiency laundry soap is poured in. If you suspect that the laundry soap is the problem, cancel the cycle and press the "Spin" or "Drain" cycles. Restart the cycle, but do not add more detergent.
  3. Inspect the water outlets. Turn faucets to the left to ensure that both the hot and cold water hoses are open. Tug on the hoses to make sure they are attached and inspect the hoses for thin spots that might be causing leaks. Make sure the hoses aren't kinked. Detach the hoses and run clean water through them to remove clogs.
  4. Is the washer's cord plugged into a grounded outlet? Never use extension cords to power washing machines. Check the circuit box for blown fuses.
Feb 02, 2011 | Washing Machines
The water to my washer stopped when I closed the lid; now it won't resume filling the tub. What to do? (I have water to other places in the house.)
Try pouring water through soap tray without spilling. you can finish the cycle now. Thereafter check your inlet water connection for free flow.
Apr 01, 2010 | Washing Machines
Maytag Atlantis stopped mid cycle
Bad/worn/broken lid switch look at the back of the lid there is a little lid cam there that hits a switch,if this switch isn't engaging it will do just what you are describing.use a small screw driver to push the button in and see if it starts.
Sep 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
If you open lid during operation, washer fills all the way to top
if you really want to see, simply stick an object (like flathead screwdriver) into the little hole that the lid presses into to click the switch, hold it there
Aug 29, 2009 | Kenmore Oasis HE 27082 Top Load Washer
GE wcxr1070a washing machine. fills with water
Check the water level switch and the plastic tubing to the switch.
Sometimes soap scum stops up the plastic hose and the water level switch does not close to send power to the timer.
If the plastic hose is good and the water level fills and stops replace the water level switch.
Mar 21, 2009 | GE WCXR1070A
Washer wont start
If the machine fills with water normally but then just sits there, you might have a bad lid switch - that's the safety interlock that won't let the machine start unless the lid is closed. Check the switch and also make sure the lid engages it when you put the lid down. Of course there could also be a problem with the motor, but first check that switch.
Mar 08, 2009 | Roper Washing Machines
Washer won't agitate, drain or spin
it only has one block fuse and should be located somewhere close to where the power cord comes into the washer. Go here www.repairclinic.com/SSPartDetail.aspx?s=t-LSE7806A-%3d%3di435797&PartID=435797 this is what you need to check.
Mar 02, 2009 | Maytag LSE7806A Top Load Stacked...
quite possible that the fuse has gone bad again, if that s the case i would recommend replacing the fuse, and the lid switch.
Dec 08, 2008 | Maytag LSE7806A Top Load Stacked...
Small brown spots on whites
This often is called "lint" but is really a "whiting" left by un-dissolved soap and can be seen at it's worst on dark colored clothes. This is made worse in a colder climate where the cold water entering the washer is much colder than normal. Things that can effect the quality of the finished washed products.
Too much soap: ( we have a test for this further down the page ) If you follow the manufactures instructions on the box, then chances are you ARE using too much soap. They like to sell you their product, I find cutting usage in 1/2 of what the box says will still wash good and also cut your chances of getting "whiting" on your clothes.
Over loading the washer: Even if the agitator is suppose to go back and forth, the clothes are not. If you can hold the lid button on your washer so you can watch the clothes wash, they should 'roll" in the basket and not go back and forth like the agitator. The clothes will go down the side of the agitator, across the bottom of the basket, up the side of the basket and across the top of the water in a rolling motion. Overloading is not just too many clothes but also too little water for the size of the load is another way of having a overloaded wash load.
Water temp is important: Use a thermometer to test the temp of the incoming water in your washer. Hot water should be close to 140 degrees F. Warm water fill should be 100 degrees F. Cold water is approx 60-80 degrees F. What happens in a cold climate location is the cold water temp drops as the outside temps drops, once the water temp gets below 60 degrees F, it can no longer dissolve the soap properly and will most definitely leave "whiting" on the clothes!! Do not use a cold wash, wash your clothes in as warm as poss.  water as they can take. If you have delicates you want to wash in cold, start washer out with warm water as you are putting in the soap and fabric softener and clothes, then switch to cold to let it finish filling up, this will give you a warmer wash but not as cold as straight cold water. I find most washes can be done in a warm wash / cold rinse just fine. If you need ( and probably will ) to adjust your warm water fill, turn on the hot water tap fully, turn off the cold water tap. Let the water start to fill on a warm wash setting. Then slowly turn on the cold tap adding the cold water to the hot water making a warm fill....use a thermometer to set water temp and leave the taps stay when you get about 100 degree F water fill. I adjust my own washer usually twice a year, one on summer time and once in the dead of winter.
Test for too much soap or soap retention: Put in a load of towels or dark clothing that has been bad for the "whiting" problem. These items are bad for holding soap and getting what is called -soap retention-
Wash the load in the warmest poss. water, DO NOT add any soap. Let the washer fill with water and wash for approx. 5 minutes, lift the lid and observe what is on the top of the water. If you see soap and bubbles on top of the water, your clothes have soap retention, this soap came out of your clothes. Let the load finish with out adding any soap and wash all clothes effected with this "whiting" residue. Once all the soap is washed out of the fabric and you start to add some to each load, use about 1/2 of what the box says. Liquid soap has less problems with "whiting" than the powder does, but I find powder soap is better at getting my own personal clothes cleaner.
Nov 15, 2008 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
26 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
