Networking how can i connect 3 computers to dialup usb moderm
How to install a modem (brand: BILLION)?
Posted on Sep 09, 2008
One computer will not connect to the internet
If your computer can't connect internet, but another computer with same network are connecting internet and axis that. So it can be issue with your moderm or router.
May 08, 2017 | Internet Computers & Internet
Connecting wireless with AOL dialup
you will have to open up your network connections to check the state of your internet connection
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be fire walled
http://download.cnet.com/tp2-drivers-zip/3000-2108_4-188609.html
http://download.cnet.com/nr1-drivers-zip/3000-2122_4-178365.html
make sure your isp provider is allowed in your firewall settings
your network adapter might not work, and you do not have network connectivity or any related network functionality.
hope this helps you
Oct 28, 2011 | D-Link DWA130 Wireless N USB Adapter USB...
When trying to use Outlook Express 6, I get an "Error Message " stating "an error occured while establishing the dail up network connection AOL Dailer"
If you are using DialUp Internet Service from AOL, try establishing a connection first and the open Outlook Express.
If you have broadband (cable/dsl) internet service from another company, then your computer is incorrectly setup. In this case, open Control Panel, Internet Options, then click on the connections tab and delete all and any listed dialup connections or simply select the "Never dial a connection" option right under the dialup connections list box.
Also, if you are not using the AOL software, I'd recommend that you uninstall it completely to free lots of resources and speed up your computer as a result. For this, go into the Control Panel, add/remove programs and remove all AOL applications from the list.
Feb 14, 2010 | Computers & Internet
How do i set my lg rumor to data/modem setting
1. Get GPRS activated on your phone number from your service provider. 2. Install the PC suite of LG on your PC. That means install the phones drivers. When you do this all drivers including that of phone ad modem will be installed. 3. Ask you service provider for the following info a) IP Address. b) Proxyport Number. c) Proxy Port settings. d) APN. And set then to your phone. 4. Connect the phone to the PC and allow Windows to detect the phone and load its drivers. 5. Go to Control Panel->Network Connections. 6. Setup the dialup connection for your phone modem. 7. Your service provider will also give you the number to dial from your dialup connection. Enter that in the dialup. 8. Connect. The connection will take around ten seconds. And you are on.
Nov 25, 2009 | LG RUMOR Cellular Phone
Moderm speed
Your question is garbled but I'll try to explain some of it.
Your ethernet LAN jack on your computer is probably 100mbps and the ethernet LAN jack on the modem is also 100mbps, connect them together and it will tell you that it is connected at 100mbps because they are both working at the same speed.
As for the other connections, you are mixing usb and ethernet up so much that I can not tell from what you are connecting together.
Sep 14, 2009 | Computers & Internet
I brought a Buffalo WHR-G300N Wireless N Router, did all the login screen thing, connected all the cables correctly and everything.. but I can't load the IP Address ( 196.182.11.1 .. Not sure if thats...
If you are using the router as an Access Point, 192.168.11.1 wont work unless it is in Router Mode. You should find out LAN IP for the G300N, and use that to access it with username "root"and nothing for the password.
192.168.11.1 is for:
Moderm >>> WHR G300N >>> Computer
LAN IP is required to access
Moderm >>> Router >>> WHR G300N (Access Point Mode) >>> Computer
Jan 23, 2009 | Dishwashers
Use a wired router for dial-up (NETZERO) connection..
You want to use a LAN with a router that uses a dial-up as a backbone internet connection for your LAN.
This is absolutely possible.
If you just want to share the connection that one computer has, and dont want to buy a router that has a built-in modem, try this
If you are running windows, There is a feature called Internet Connection Sharing (ICS.) It will share the dialup across the network.
Just 1 hookup the router and all the pcs to it. 2 Dialup the machine with the modem. 3 Enable ICS on that machine. 4 Youre LAN is online.
In XP, goto the network connections, and while you have 2 active connections in there (the dialup and the LAN port connected to the router), right click the dialup, goto properties. goto advanced tab, and click on enable ICS.
The other computers should be served IP's automatically and NAT'd out to the internet by the computer running ICS.
(The other computers should be automatically setup to the internet like they should be and connected to the dialup riunning on the ICS (host) computer)
May 16, 2008 | Linksys (R) RT41P2-AT 4-Port Wired Router...
Router
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem
Step 1: Shutdown the computer.
Step 2: Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and test the Internet connection.
if this still didnot work, maybe you need to upgrade the firmware of your router
Apr 28, 2008 | Linksys Wireless-G WRT54G Router
My Wireless internet card don't work
i think you are a little confused, your laptop may have a wireless card internally, but you need a wireless broadband or cable router for the wireless adapter to pick up a signal.
A fax modem cannot be wireless and cannot be broadband as you cannot fax using a broadband connection.
Assuming you have a broadband connection you will need a wireless modem/ router or roter connected to a broadband modem, not a standard 56k dialup modem as they aren't wireless or broadband.
Nov 08, 2007 | Toshiba Satellite A60 Notebook
Setting up an MN700 Base Station with dialup
1. disable all ICS and all Proxy settings on all machines 2. connect the NIC to the MN700 using Port 1 3. set up the MN700 and the wireless connection 4. switch the MN700 to Bridging mode 5. enable ICS on the host computer The basic object is to have the working connection for your dial-up, then set up the base station as an access point only, then share the working connection via ICS through the NIC. Quite similar to having a switch box, but you're going wireless with it. You don't need to feed the MN-700 any of the normal info like your Internet Service Provider's IP/DNS, etc., because your computer already is sharing that info.
Feb 19, 2006 | Microsoft MN-700 Wireless Router
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
