Question about Sony Playstation 3 (PS3) Console
Ps3 reset I hooked my ps3 up to a new plasma tv and it only goes up to 1080i and the tv i used to have goes up to 1080p..now when I hook it up to the new tv thats only 1080i with my HDMI cable it says invalid format. The only I can think of is that it is set at 1080p and the tv wont plat the picture so I need to reset the ps3 to default or somthing.The sound comes through just not the picture...thanks BILLY
  • jabeelm786 Jan 08, 2009
    Will this solution also delete all of the memory/gamesaves and music etc etc aswell?
  • JasonMannn Mar 24, 2009
    its the same as the other guy's problem. TV goes up to 1080p, put when u set it 2 1080p it says "invalid format". So it will only work on 1080i
    Sergeant:
    Champion:
  • 236 Answers
Turn the PS3 off. hold the power button for at least 5 seconds or until you hear another beep.
This should reset all your ps3's settings.  If you have an HDMI connection, wait for a couple of seconds so that the PS3 recognizes and negotiates the right video output for your TV.
Posted on Sep 08, 2008
Dynex HDTV says not supported when PS3 is connected via HDMI
Have you tried changing the video output settings on the PS3? It may just be on a setting that the TV does not support. For instance, if the poutput setting is 1080P, and the TV only supports up to 1080i, you would get a "not supported" signal. Hook the ps3 to a tv that it works on...turn it on, go to settings- display settings-output settings- select HDMI as the connector type- if it asks for 3D tv size...select the size- now you need to set the resolution...select all resolutions that the TV supports, since it is a dynex...it is likely a 720p TV. So I would start by selecting only 720p, and then hook the system to the Dynex TV and see if it works now. If it works, you can go back in and attempt to select 1080i or 1080p to see if they work... but again, being a Dynex, it is probably only a 720p TV... The PS3 is likely trying to output a 1080i or 1080p signal...which that TV doesn't support.
Mar 21, 2014 | Video Game Consoles & Games
I just bought a used ps3 i hook it up to my emerson hd tv and it shows format not supported , i then hooked it up to my poleroid hd tv and it works fine this all thru the hdmi cable
What are the specs on your emerson, does it support 1080p? Make sure you have the right settings on your ps3. If your emerson supports 720p and 1080i then it will not give you a 1080p picture and you might run into issues.
Mar 06, 2011 | Televison & Video
Trying to hook-up a PS3 to my Toshiba 32AV500U thru HDMI but I get no picture. I forget how to get to the setup.
The Toshiba 32AV500U cannot display 1080p. Hook up your PS3 to your computer monitor, provided that it can display 1080p, or some other TV that can, then change your Video Output settings under Settings> Display Settings and uncheck 1080p, which will allow the PS3 to display in 1080i. Once you do that, then hook up the Toshiba via HDMI and it will work with no problem.
Nov 25, 2010 | Toshiba 32AV500U 32 in. LCD HDTV
Trying to connect PS3 to Samsung HL-S4676S tv using HDMI cable. I get message saying mode not supported
So I had this same problem. I found that when I hooked to a 1080p TV my PS3 was working, however when I hooked to my 1080i it said Not Supported Mode. So I then hooked to the 1080p and told my PS3 to limit it's self to 1080i mode and hooked it to my Samsung TV and it worked just fine. Give that a try and it should solve the problem. Hope this helps.
Oct 09, 2010 | Samsung HLS4676S Television
"Invalid format" how do I change from 1080p to 1080i or 720i?
I had a second playstation hooked to another tv in my home and took a controller from the non-LG-TV-displaying ps3 and one from a working ps3 on a seperate TV. And used the working ps3 to guide me to the settings menu on the ps3 that was not displaying video. Anyways, if you cannot see the tv screen because it is set on 1080p and your LG will not display it (Only displays up to 1080i). Start The PS3 and press the D-pad buttons in this order.
Left 10+ times. (This Takes you to the far left icon in the XMB)
Right Once. (This is the settings icon)
Down 20+ times. (To reach the bottom of the settings)
Then Up 4 times (This is Display Settings)
Press "X" Once. (This enters Display Settings)
Press Up 5 times (This Makes Sure you are at the top of the sub-menu at Video Output Settings)
Press "X" Once (This Enters Video Output Settings)
Before pressing any more buttons, Know what cables you have pluged into your TV.
For HDMI Just Press "X" and it will auto adjust to for the new TV.
For Component / D-Terminal Output Press Down Once Then "X", and X Again (This changed my ps3 from the 1080p-Invalid Format back to 1080i and fixed my problem.
For Composite Video Output Press Down Twice, Then "X" and X again.
For AV MULTI / SCART Output Press Down Three Times, Then "X"and X again.
Apr 26, 2009 | Televison & Video
I have a ps3 i had it hooked up to a 46" samsung 1080p, then i drove 2 miles with ps3 in box and hooked up to a mitsubishi 1080i 52" tv and i could only see part of the ps3 screen either in game...
tv's are difffrent and the ps3 knows that.
You need to adjust the settings on the ps3 or on the tv.
It still works at your home correct?
If so its just a compatability issue with your ps3 and trying
to get it to work on another tv.. It thinks its still 1080p when its actually 2 miles down the road on a 1080i
Go to your system settins on your ps3 and change them to work on a 1080i
Good luck
And if you have anymore questions or if this dosn't work, please feel free to ask
Sep 11, 2008 | Video Game Consoles & Games
Hooking up a PS3 through HDMI
what you have to to is hold the start button till the TV shows 480i then you will have what you need, it will set up for your tv
Feb 08, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Hooking up my new PS3 to my five year old 55" Mitsubishi HDTV.
The Sony outputs 180P, not 1080i. There is a difference. I don't know what exactly, but Sony says 1080p is for superior.
Dec 31, 2007 | Mitsubishi WS-55809 55" Rear Projection...
My tv shows its's geting 1080i only
1080p signal... THE MITSU. WD-65731 has a resolution of 1080p its just the res your PS3 is pumping into your screen is loaded with a little bit more pixels than you 1080p res MITSU. I suggest getting a MITSU WD-57731 since it has a 1080P/24 input. and has great clarity and HD ample for the BD of your PS3. however the differences in picture rate and quality is very small. goodluck.
Sep 22, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
233 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
