Question about GE WSXH208A Front Load Washer
Ge front loader washer wsxh208a
Spins back and forth but wont cycle threw and wont drain out. thats it
any help will be appreciated greatly.
    Genius:
  • 1,028 Answers
Remove bottom cover and clean pump
Posted on Sep 07, 2008
My front loader is not spinning properly
You will need to remove the back of the unit and pull the boot off that goes from the tub to the pump and clear the filter.
Dec 10, 2012 | GE WSXH208A Front Load Washer
Water won't drain on the wash or rinse cycle
Hi.
If the machine does not drain the parts to be tested are rain system, motor and control board must also be tested. If machine is a top loader testing will start from lid switch. The first action will consist in checking the drain hose at the back and checking the drain filter accessible from lower front side of your GE WSXH208A.
Here a page about drain and spin problems.
If you need parts or schematics see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 14, 2011 | GE WSXH208A Front Load Washer
My ge front end loader washer won`t spin water or pump water out
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jan 29, 2011 | GE WSXH208A Front Load Washer
My front loader shakes.. when in the wash and spin cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Oct 13, 2010 | GE WSXH208A Front Load Washer
Washer would not drian nor spin
no the solution is that the drain pump is dead and needs to be replaced open the front panel of the front loader and locate the filter and clean and also remove!!
Aug 20, 2010 | GE WSXH208A Front Load Washer
Where?s the filter on my GE WSXH208A Front Loader? Thank you beltronic205 (GE WSXH208A Front Loader won?t drain). I drained the tub by lowering the drain hose as suggested. But where is the filter, what...
There is no acutal filter on this unit...You cab remove the back panel to access the drain pump ...Or tilt the washer back and access it from the bottom...Remove the drain hose from tub to drain pump...(careful of flow of water from tub)...Check the hose for any blockage...If no blockage then your pump is bad..
Apr 20, 2010 | GE WSXH208A Front Load Washer
My font load washer wont fast spin or drain
gimme those older models anytime. their having a lot of trouboe with this front loaders
Jan 07, 2009 | GE WSXH208A Front Load Washer
Ge front load washer, 7 years old
speed control module faulty replace it .Close Ireland bye bye
Nov 22, 2007 | GE WSXH208A Front Load Washer
GE WSXH208A Front Load Washer Logo
261 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
