Question about Mitsubishi WD-52525 52" Rear Projection HDTV
I need to replace two capacitors on my Mitsubishi WD-52525 52 but
The ones I have available that came in a kit are not exactly alike, the voltage is higher. The ones I took out where 3300uf 10volts and the ones I have available are 3300uf 16volts. How will that affect the TV if I end up putting those in since its higher voltage? Thanks in advance.
  • Jasso A Sep 09, 2008
    Thank you Guest I did end up installing them and the TV works fine, I am so glad it only cost me around 56$ dollars after it was all said and done, thanks again.
Actually, the new ones are correct , which is why the 10v ones crapped out.
Posted on Sep 08, 2008
The timer light is continuosly blinking when i plugging in the tv (mitshubishi wd-5252) and won't reset?
Thats one of the famous capacitor issue most likely. Thats the V26 Chassis DLP and usually that symptom is caused by failed DM and Power Board capacitors. There is a repair kit that will work in alot of cases with that symptom. Its called The V26 Chassis DM / Power repair kit available at the following link with detailed instructions http://tvrepairworld.com/mitsubishi_repair_kits
Apr 03, 2013 | Mitsubishi WD-52525 52" Rear Projection...
Where are the capacitors that need replacement located on the Mitsubishi WD-62528.
Look for ones that are bulged on the tops and replace those, if you don't see any bad ones your going to need a ESR meter to test them
Jan 05, 2018 | Mitsubishi WD-62528 62 in. LCD Television
Replaced my lamp, when i push power it powers up for a few seconds then shuts off and the red lamp button comes on again.. wd 62725
Thats usually caused by failed capacitors on the Power board. The mitsubishi repair kit called the V26 Chassis DLP DM / Power repair kit will often repair that. Its available from www.tvrepairworld.com and contains the capacitors and the CD with repair instructions.
Nov 05, 2010 | Mitsubishi WD-62725 62" Rear Projection...
I have lines that float across the screen from left to right.
The V26 Chassis FMT repair kit should repair that issue. The kits available from www.tvrepairworld.com the kit contains the replacment capacitors and the CD with instructions
Oct 31, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi wd-52825. red lamp indicator, new lamp installed
Failed caps on the power supply will cause that. The V26 Power pwb repair kit will usually correct that issue. Its available from www.tvrepairworld.com the kit contains the capacitors and the CD with instructions.
Oct 30, 2009 | Mitsubishi WD-52825 52" Rear Projection...
5 year old mitsubishi wd-62525 with blinking timer light. This site says there aren't replacement boards available for it any more. Also to send it to a technician for repair. One suggestion was that it...
The WS62525 doesnt have an inverter board. The blinking led is usually caused by failed capacitors on the DM board. You can get the V26 Chassis dlp DM repair kit at the following link which contains the capacitors and the CD with detailed instructions. www.tvrepairworld.com
Aug 29, 2009 | Mitsubishi WD-62525 62" Rear Projection...
The timer light won't stop blinking - the tv wont go on at all -- I have unplugged it for a week and then tried plugging back in and it just blinks. I have tried the reset nothing will make it stop...
You need the V26 Chassis DLP DM repair kit available at the following link. The kit contains the replacement capacitors and CD with full instructions on how to do the repair .Its listed under the mitsubishi repair kits category
http://www.tvrepairworld.com/
Jul 12, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Where can I buy two capacitors for my Mitsubishi WD-52525 52 in?
Thats the best place to order them from, as they have the correct replacement cpacitors which are the high temp orgional capacitors. They should have which ever ones you need.
Sep 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mits TV problem
I finally got my TV fixed, I had to replace two capacitors the ones that were bad seem to be the same ones everyone else is having problems with, they were bad when I pulled the board out, they read 3300uf 10v and I bought this kit at this site http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits/osCsid/145ffde26a9336eaf57c21ff6389def7 that came with the replacement ones which were higher voltage but they worked just fine, if you order the kit, it will come with a manual and a bag full of capacitors, but you will probably just need the two I replaced which read 3300uf 16volts. I bought the soldering tool at radio shack for $20.00 it came in a kit as well. that was it, so like I said the TV is well and running now, it's great to finally get to see out of it, good luck!
Sep 05, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD 62327 DLP TV
Can I ask where you got the capacitor kit from?
Aug 17, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
94 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
