Question about Belkin (F5D72304F5D7000) Router
What is 54g? - Belkin (F5D72304F5D7000) Router
    Novelist:
    Scholar:
  • 128 Answers
54g is Broadcom's maximum performance implementation of the draft specification for IEEE 802.11g wireless networks. This technology is expected to quickly become the next mainstream wireless LAN technology because it works faster and farther, is backward compatible with 802.11b and is affordable. Authorized products displaying the 54g logo use Broadcom's 54g wireless LAN chipset and ensures that products are designed to be completely interoperable at maximum performance with other 54g products and are compatible with the draft IEEE 802.11g specification.
Posted on Feb 16, 2006
Belkin 54g wireless router
To reset your router to default settings, hold down the reset button for 10 seconds and realese it. Then unplug the power cord and plug it back in. This should work with most routers.
Feb 13, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
How do I rename it so I can further protect my network
  1. Log-in to your router (default: 192.168.2.1)
  2. Go to LAN Settings
  3. Change Local Domain Name to a name of your liking.
  4. Click Apply Changes.
  5. Done.
If you have any more questions or this is not clear to you, just come back here and leave a comment - I'm happy to help.
May 22, 2009 | Belkin (54G F5D7230UK4) Wireless Router
Cant connect
Hi! Did you go into the router configuration through IE (Internet Explorer)?
May 24, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
How does the wireless range of 54g compare to 802.11b and 802.11a?
The range of 54g products is the same as 802.11b. They both operate in the same 2.4GHz frequency. Both 54g and 802.11b have better wireless range than 802.11a.
Feb 16, 2006 | Belkin (F5D72304F5D7000) Router
What is 54g-LRS mode?
In some cases, older 802.11b clients may not be compatible with 54g wireless. These adapters tend to be of lesser design or use older drivers or technology. 54g-LRS (Limited Rate Support) allows these clients to be compatible with the newer 54g technology. Switching to this mode can solve problems that sometimes occur with these clients. If you suspect that you are using a client adapter that falls into this category of adapters, first check with the adapter vendor to see if there is a driver update. If there is no driver update available, switching to 54g-LRS mode may fix your problem. Please note that switching to 54g-LRS mode may decrease 54g performance. It is not recommended you use this mode unless you have a very specific reason to do so. This mode exists only to solve unique problems that may occur with some 802.11b client adapters and is NOT necessary for interoperability of 54g and 802.11b standards.
Really see 54 Mbps with 54g?
As with any wireless protocol, 54g has overhead associated with it that limits performance. While signaling data rates of up to 54 Mbps may be achieved, like most shared media (e.g. Ethernet) throughput will be significantly less. There are two scenarios for 54g performance. In an environment with only 54g clients, throughput can exceed 24 Mbps. This performance is equivalent to that of 802.11a, although 54g is usually available over a greater range. The second scenario is where 802.11b clients are present. RTS/CTS flow control must be used to allow 802.11b clients to recognize and establish communications with 802.11g access points. This leads to delays in transmission and drops peak throughput to about 10 Mbps. 54g performance is still well in excess of the maximum measured speeds of 4-5 Mbps for 802.11b. The use of RTS/CTS is important because it provides determinism to the wireless network, ensuring a minimum bandwidth for each user. Like Ethernet, 802.11 LANs normally use a ג?œcarrier sense media accessג? mechanism to signal transmission without asking for permission from the network. As the network becomes highly loaded, collisions occur more frequently and the network can become saturated with packet retransmission attempts that eventually make it impossible for any data to get through. RTS/CTS provides a more formalized flow-control mechanism that avoids this problem.
Performance
54g products will perform differently depending on whether or not there is 802.11b traffic in the immediate environment. The rules-of-thumb for throughput are: In an 802.11g-only environment, throughput will be between 4-5 times the throughput of an 802.11b network. The maximum throughput can exceed 24 Mbps. In an environment that includes 802.11b devices, throughput will be about double the throughput of an 802.11b network. The maximum throughput can exceed 10 Mbps. In addition, all 54g radios have better sensitivity than current 802.11b radios, and 54g provides outstanding coverage in its 802.11b compatible mode.
What is the difference between 802.11g and 54g?
54g implements the latest draft of the IEEE 802.11g specification. The two primary distinctions between 54g and 802.11g are: 1) 54g is designed to enable 54 Mbps connectivity. The 802.11g draft specification makes 54 Mbps connectivity optional, and simply requires up to 24 Mbps connectivity to comply with the specification. 2) 54g products are based on the same wireless LAN chipset, which means they are interoperable. Because the standard is not final, it is not yet possible to test for 802.11g interoperability.
Belkin (F5D72304F5D7000) Router Logo
337 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Pamela Bates
Pamela Bates
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
