Question about JVC Audio Players & Recorders
On my new jvc rx-d206 hybrid feedback digital amplifier sometimes when I watch tv programs that show they support dolby 5.1 surround sound, sound just comes out of the right and left front speaker, sometimes the 5.1 sound works but has little quips of it just playing out of the center speaker, I would really like help fixing this problem, thanks
3 Suggested Answers
  • 9 Answers
SOURCE: Onkyo TX-SR500 Dolby Digital problem
I just read over the problem you were having with your Onkyo TX-SR500 receiver. It sound like the unit needs to be setup for all five channels.Sence your symptom says the diplay shows Dolby D3/2.1. According to the owners manual with the remote control look for speaker setup whin the button is pressed the current speaker setup will be shown in the display. Press the preset/adjustment<> to change the current setting to five speakers. the listening mode will automatically change according to the number of channels you selected. Hope this helps. Radiotech
Posted on Aug 14, 2007
SOURCE: jvc rx-5020v dolby digital problem
Also...If your BluRay player only has a optical output for audio you will need to swap the inputs on the JVC rx-5020v. Press the "settings" button repeatedly until "digital in" appears on the display. Now use the "adjust" up and down buttons until DVD is selected as option 2. It will look like something like: 1CD2DVD Note: this may bugger any other previous setup you have.
Posted on Apr 24, 2010
How do I hook up my receiver to my PS3 player and create a surround sound. The amplifier is already connected to a dvd player which is already in surround sound but I can not do the same with the PS3.
If your receiver has another digital audio input available to connect to, such as a coaxial or optical input, you can use either of those for the PS3. Another option is to use one of the composite audio inputs, but however, your surround mode for that type of input will not be Dolby Digital, DTS or any of the high definition surround sound formats. You will instead be able to get one of the Dolby ProLogic formats, or one of the various surround modes that are proprietary to the receiver model by it's digital signal processor...depending on which you choose.
May 11, 2010 | Yamaha RX-V800 Receiver
Can i plug in my i-pod and listen to it?
All you need is either a dock, which will keep the I-Pod powered up, or a 3.5mm plug to two RCA phono leads, which will also be needed for the dock, this plugs into your headphone socket of your I-Pod and the two RCA's into an aux socket on the JVC. You can then listen to it in Dolby Pro-Logic. You won't be able to listen in Dolby Digital, unless the I-Pod has Dolby Digital output, which will require a different lead.
Of course the sound source (music) would have to be recorded with Dolby Surround, to get the full benefit, but many are, they just don't say in the imformation given.
Mar 09, 2010 | JVC RX-6008V Receiver
I just moved and can only use 3 speakers with my jvc 1028. what setting should I use when watching TV?
Unless the TV has an output for Dolby Digital, you can only listen in stereo or a pro-logic modes, or other none digital mode. If you only connect 3 of the 5 speakers, then the other two channels will simply not be heard, but it shouldn't damage the amp.
Feb 28, 2010 | JVC RX-1028V Receiver
Used digital optical connection on amp from panasonic plasma tc 42x1 all I get is pcm linear can't get dolby whats up
pcm linear refers to how the tv is communicating with the amplifier. Follow the steps in your tv manual to ensure the tv is capable and setup for output of dolby and or dts, then try a dvd or a hd channel to test it
Jan 11, 2010 | JVC RX-778V
My center and surrond sound speakers don't work with just one output from my dvd do I need to purchase an amplifier also?
You need to first check whether your dvd player supports dolby 5.1. If it supports that then you could connect the digital output of your dvd player to a surround receiver such as Yamaha RX-661. You can then connect all the speakers to the output of RX-661 which has 7 inbuilt amplifiers for all the channels. Its a 7 channel receiver and would be useful with DVD-Audio and such that comes in 7 channels. For your requirement any 5 channel receiver will do. Please let me know if you need any more clarifications.
Jul 28, 2009 | Audio Players & Recorders
Hooking up surround sound
to get the digital you have to have the digital optical line or the coax rca jack digital audio connection from device to stereo reciever to get the dolby digital surround sound to work , otherwise you can only get a virtual surround sound from the reciever( no dolby digital )
Jan 04, 2009 | Sharp CDBA3100 Remanufactured Mini-System...
Onkyo digital reciever has poping noise when in dolby sound
I have the same reciever, and had the same problem.  Contact Onkyo, this is a known issue where defective DSP chips were used and manifest problems with a popping / clicking sound when using surround settings.  These receivers also have a Dolby Digital input issue that can cause audio dropouts when watching cable or SAT broadcasts that encode DD using a 'newer' broadcast encoding methods.  Onkyo is covering the cost of that repair for me now, even though the receiver is 5 years old now....
Jan 02, 2009 | Onkyo TX-DS797 Receiver
Dolby digital signal
yes go in main menu of tv audio output and use dobly digital out ok not pcm anlog ok
Feb 03, 2008 | JVC RX-7030V Receiver
No Prologic Surround Sound
im thinking the reciever is set to get its audio from somehwere other than the dvd, sounds like you did most of the troubleshooting but do you get audio out of the reciever if its just playing the radio or something other than a dvd?
Nov 19, 2007 | JVC RX-778V
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
