Question about Bosch Dishwashers
Bosch dw model shu3002 The timer gets to a certain point and wont advance
2 Suggested Answers
  • 1214 Answers
SOURCE: the dishwasher continues to drain and the timer does not move
Sounds like the timer needs to be replaced, especially if the tub is empty of water, and the timer will not advance no matter how long you leave it there.
Posted on Jan 24, 2009
Hi, we have a Bosch SHU53EO6UC/14 dishwasher. It is getting stuck in wash and isn't advancing. We think it may be the timer but there are lots of references to running a test program. Unfortunately...
My Bosch DW SHU5302 also got stuck during a cycle and ran and ran. Turns out this is a known problem with these DW's. The problem is that a trace on the main board burns off that controls the heater. If the heater doesn't come on then the DW keeps running waiting for the water to heat up. Re-soldering this trace fixes this problem. If you get a repair guy out, he will only change the board. They are not allowed to re-solder which doesn't fix the problem for long as the same trace will burn off. Did this about 8 years ago and it is still fine.
Aug 29, 2011 | Bosch 24 in. SHU53 Built-in Dishwasher
Will not heat just cold air and once it reaches 32 min left it stays there
Sorry for the troubles sounds like you have a bad timer since its not heat then the timer wont advance past a certain point. I would recommend you calling a qualified service technician come look at it and to replace the bad timer or you can do this yourself. You will need the model number off the dryer which will be on the back of the unit on the dash or inside the door opening take that number to your local appliance parts house so they can get you the proper timer. Now for installing it make sure you unplug the unit and then you will have to remove the back cover panel on the dash once removed slowly remove wire by wire replacing it to where its suppose to go on the new timer if you put a wire in the wrong spot you will fry the new timer once completed remove the old timer it should have 2 screws holding it to the dash and replace it with the new timer and put your cover back on and then plug it back up and set the timer to 60mins on the timed dry and tune it on and see if it Advances and heats. I hope this helps and thank you for using FixYa!
Jan 27, 2011 | Crosley CDE6000 Electric Dryer
Whirlpool AWM1200 washing machine wont advance at certain stages
there is a little motor in the selector switch that moves the dial around.  This little motor is defective and needs replacement.  Sometimes it's sold separately and sometimes you need the whole timer.
Apr 01, 2009 | Whirlpool AWM6120 Front Load Washer
Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Mar 24, 2009 | Bosch Dishwashers
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
Mar 24, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Bosch built in dishwasher shu4302uc The dishwasher appears to run through the cycle but the cycle takes over three hours. When the cycle finally finishes the dishes are not completely dry. Is there a way...
There are no adjustments for cycle timing. What does affect timing is temperature of the water coming into the DW. The hotter your supply water, the shorter the time to cycle, BUT if your water is too hot, the cycle time may become too short to light the NSF 'Sanitize' indicator. But since the cycle is taking so long, this is an indication that the DW's water heater is not heating the water hot enough to advance the countdown timer in a timely manner. The control logic is waiting for the temp to come up to an appropriate level to ensure adequate washing, rinsing or drying times. Likely your display is showing '1' for a long time as a symptom of this problem, as well.  - This link http://www.applianceaid.com/boschDW.html has procedures to run self-tests on various Bosch models. I suspect that you can confirm a 'heater fault' on your unit by running the self-test.  - This problem invariably relates to a 'heater fault' which has usually been traced to an open solder joint on the control board located behind the switches/indicator lights on front door. If you have a Torx driver, soldering iron & bit of solder, you can effect a repair yourself in about an hour. Otherwise, a replacement control board is required.
If you'd like to attempt replacing the control board yourself, refer to this link for part & DIY information. http://www.appliancejournal.com/appliance-parts/bosch-appliance-parts/bosch-dishwasher-control-module-266746-37/
- Else, place a service call to the tech of your choice.
Feb 22, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
The dishwasher continues to drain and the timer does not move
Jan 24, 2009 | Avanti DW181SS Stainless Steel Built-in...
I have a GE roll around dishwasher, Model GSC3200Z03BL. It worked one night, did not work the next. After hooking intake/discharge hose to faucet and turning to start, no water is pumped in. Only a...
First off.. the pump does not let water in.. it takes water from your sink faucette via the hose and allows it to enter the DW via an inlet electrically operated valve. If that valve is not commanded by the control system to open, then no water will enter the DW and a wash cycle will not start. Please find the informaton shown below that decribes some reasons why your DW may not be filling with water. You should go thru this series of checks to make sure you've set up the DW correctly aqnd it is not in mid cycle.If by chance you are setting it up correctly and are not in mid cycle then you may have a hardware problem with the system. I would be happy to assist you if it comes to that but I am hoping that the information below will get you started,...
Copied directly from the GE website for your refererence..
Dishwasher - No Water Fill
Often the cause of a dishwasher not filling at the start of its cycle is not electrical or mechanical. Often times you may be starting your dishwasher model incorrectly which results in the machine skipping its first water fill period.
There are presently three different types of starting procedures being used:
  1. Pushbutton type. This system is found on all POTSCRUBBER models.
  2. "Turn-to-start" timer type. After latching the dishwasher door, you turn the timer dial until you hear a click. By advancing the timer dial beyond that point, its possible that the first water fill would be skipped. The first fill is necessary for automatic pre-rinsing of the dishes.
    View a short video about turn-to-start timers:
    Play Video
  3. The most common type is a "push-to-start" timer dial. All that is required to initiate the cycle is to push in on the timer dial. It is NOT necessary to turn the dial.
If you are unsure as to the starting procedure used by your model please consult the Owner's Manual. Download a free copy of the Owner's Manual and/or Installation Instructions.
Here is a link to the website too.. http://www.geappliances.com/search/fast/infobase/10001005.htm
Hope this gets you going..
Sep 02, 2008 | GE Dishwashers
Endless cycle with wet dishes
If it's a Bosch, check for Rinse Agent (e.g. JetDry). Rinse agent is not optional with a Bosch.
Apr 14, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Change a white door to stainless??? can I
Okay here we go. The SHU43C05UC/17 is the stainless model. The parts needed to change over to SS are 1) 431828 SS Facia cost 72.80. 1) 417981 power switch button 15.40. 1) 426062 program buttons set 5.40. 1) 214750 SS outer door panel 101.50. 1) 426063 lid (fits inside the handle area) 3.90. As you see it will not be cheap to change over to a SS dw. These prices are from Bosch's Quick Finder website. Hope this helps.
Mar 31, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
44 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
