Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Where can I buy two capacitors for my Mitsubishi WD-52525 52 in?
I have pulled out the board and took out the two capacitors that looked bad, but need to know where to buy them. I had previously ordered them from http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits/osCsid/145ffde26a9336eaf57c21ff6389def7 but the ones it came with, where like the ones I took out, I would appreciate any suggestions, thanks in advance.
  • Jasso A Sep 09, 2008
    Thanks Slinteriors, I did end up putting those on, the 16volt, and the TV is finally working, YEAH!!! it only cost me the kit's cost 26-36$ not sure which, and the tools to fix it 20$ at radio shack, thanks again.
  • Mitsubishi Master
  • 8,617 Answers
Thats the best place to order them from, as they have the correct replacement cpacitors which are the high temp orgional capacitors. They should have which ever ones you need.
Posted on Sep 09, 2008
  • Sonny Berry
    Sonny Berry Sep 09, 2008
    thats good its working again, and alot cheaper than a service call thats for sure. congratulations on a job well done.
My mitsubishi wd-60737
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 19, 2012 | Mitsubishi WD-60737 60 in. HDTV
I have a mitsubishi wd-62525 the power light keeps blinking, and i can't get picture. i unpluge it than want 2min than it stop blinking and i can turn to tv on and get a picture than after 30-40mi
Good day!!!!
Jun 06, 2012 | Mitsubishi WD-62525 62" Rear Projection...
Flashing timer light on a mitsubishi wd-57733
Good day!!!!
Jun 06, 2012 | Mitsubishi WD-57733 57" HDTV
Tv wont power up after replacing 6 caps 4 bad 2 looked good but were in series so replaced with larger voltage. mitsubishi wd 62725
That model will usually have 8 caps that require replacement on the Power board and also 4 capacitors on the DM board which will usually cause the Non stop blinking light symptom.
Sep 23, 2011 | Mitsubishi WD-62725 62" Rear Projection...
Blinking light with no picture or sound
If you have a green blinking light,
Most likely issue is with bad capacitors on the DM an FMT boards.
1) Look for bad 1000uf 16v caps on the dm board and the fmt board.
2) checked surface mount fuses (small white boxes) on DM and FMT board
Look carefully for other bad capacitors in the general area.
Start here and let me know the results.
Note, there is a lot of disassembly to get to these boards. Not a fun project.
Feb 20, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD62525 Dead NO Power-Won't turn on
Don't think dm board will solve your issue, might want to check power board for buldging caps.
Aug 09, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Blinking green timer light on mitsubishi wd 52525
disconnect the connector for the front switch control board. Try turning it on with the remote. If it works replace that board, also look for bad caps on the small signal board. they're 1000Mf 16v
Mar 22, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi tv
ok.
#1. replaced capacitors on power board. DM board FMT board .
# 2 on power board you need to chek caps. 3300mf x 35 v.QTY 2.
# 3 12 capacitor 1000mf x 16 v.
If caps 1000mf x 16 v . looked good. replaced anyway......
Sep 14, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-52525 Projection Tv
?? give description of problem?? plug it in and hookup some cable!
Jun 03, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525
I get the same red lamp led indicator, bought the lamp and I am unable to locate the lamp inside the tv, took the lower back panel out and don't see anything that i can make out the lamp housing. is hard to replace the capacitor and where is the power board located. thanks a mill.
Nov 22, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
91 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
