Question about Kenmore Dryers
Dry belt disconnected - Kenmore Dryers
  • 70 Answers
You need to either put the belt back on or replace the belt. :)
Posted on Sep 07, 2008
My compressor smels like its berning
Clutch is bad or compressor is leaking and the oil has dried out...At that point it is probably fried. disconnect the electrical lead to the compressor to it to prevent further damage and possible seizure and ripping of belt. and take it to a mechanic. I assume you are talking about the air conditioning compressor. Just keep in mind you probably won't be able to defog you windows once you disconnect the compressor .
Mar 10, 2015 | Cars & Trucks
Tip
Snow throwers
Just returned from the parts store, they had sold out of drive belts for the auger drive on snow throwers... figured I could help out here;
Wet snow is heavy, duh right? Before you run your snow thrower disconnect the spark plug, for safety. Check the chute, and sand any loose paint rust etc. you want a smooth chute.. paint if needed, let dry 24 hours before use, spray with silicon lube spray, this will loessen the stress on your auger belt and hopefully keep your machine running all season. Good luck!
on Feb 28, 2010 | Air Purifiers
Bosch service manuals
See if the washer spins out more water with part of the wet load removed. Sometimes the problem is a simple as the wet wash is too heavy. Next, be sure to disconnect the power and then check the belts.
Nov 30, 2013 | Washing Machines
Vertical drive
If it's where i think it is you have to disconnect the axel rod off of one side and put the belt around the shaft from there.
Feb 07, 2018 | Garden
How to take out air condition compreser out of a2001 mercury sable
have dealership discharge airconditioning system.you need to disconnect refrigerant lines going to the AC compressor you probably need refrigerant lines disconnect tools to remove disconnect refrigerant lines.you need to remove drive belt.and safely raise support vechicle remove tire or wheel work from under vechicle you have to loosen AC COMPRESSOR bolts then remove AC COMPRESSOR.be sure pour old refrigerant in a measuring cup so you can pour same amount new oil in the new compressor.add couple ounces if old AC COMPRESSOR dry.
Feb 11, 2013 | 2001 Ford Taurus
I bought it in 2003 neptune dryer and the 3 bar inside the dryer broke and the dryer is not working right . we have to dry them 3 time before they are all dry
Instructions
Things You'll Need:
* Phillips-head screwdriver
* Replacement belt
1. Disconnect the power cord of the Maytag Neptune dryer from the dryer electrical outlet.
2. Open the dryer door, and locate the four screws on the inside lip of the door opening. Use a Phillips-head screwdriver to remove the four screws. This will disconnect the front panel from the shroud assembly.
3. Grab the front panel on each side with your hands. Lift up on the front panel to unhook it from the retaining tabs on the side panels. Remove the front panel, and set it out of your way.
4. Use a Phillips-head screwdriver to remove the four outside perimeter screws that secure the shroud and tumbler front to the dryer cabinet. Pull the shroud and tumbler front away from the tumbler while lifting the top panel partially up.
5. Reach both of your hands underneath each side of the tumbler. Use your left hand to grasp the idler pulley, and pull it to the left while using your right hand to slip the belt off the motor pulley. Pulling the idler pulley to the left releases tension on the belt. You can now slip the belt off the back of the tumbler.
6. Take the old belt with you along with the model number of your dryer to purchase a new belt. Most appliance repair shops will have replacement belts in stock. Make sure that the new belt matches the old one by comparing the two.
7. Slide the new belt over the rear of the tumbler with the ribbed side pointed to the inside. Using both hands under the tumbler, route the belt around the motor pulley and idler pulley. Pull the idler pulley to the left while routing the belt, and carefully allow the idler pulley back to the right to apply tension.
8. Reattach the tumbler front and shroud to the front of the cabinet using the retaining screws. Place the front panel over the side retaining tabs, and push it down to lock it in place.
9. Open the dryer door, and secure the front panel to the shroud using the retaining screws. Close the dryer door, and plug the power cord back into the dryer electrical outlet.
Feb 28, 2011 | Maytag Neptune MDE5500AY Electric Dryer
My dryer is producing heat but is not drying, i am drying the same size load i usually do on the same cycle. the lent is cleaned out, and the oustide vent is blowing hot air. why are my clothes not getting...
make sure that all the seals are ok, door,front and back drum seal, blower housing seal(inside dryer). also consider that depending on washer type if you overload or have a worn drive belt in washer it will take twice the time to dry. also make sure that the dryer drum tumble. open door,press door switch and start dryer to see if drum turn. lastly disconnect vent pipe behind dryer and dry a load. if it dry ok then you have a partial blockage. you can also have a weak heating element.
Feb 11, 2011 | Whirlpool WED5300S Electric Dryer
Hi Im having a problem with my dryer..........Its getting hot and everything but the drum on the inside is not turning so only half of the clothes are getting dry.Can you help me?
Almost certainly the belt has either slipped off or has broken.You need to ask an appliance tech to check it if belt is broken as the electrics have to be disconnected and drum removed to install new one.There is a belt tensioner on some of the units as well.
Aug 09, 2010 | Whirlpool Dryers
Dvd player
Do replace the loading belt in the loader unit ,the belt is serrated (full of cracks) and is very dry .The belt slips when pulling .
Oct 07, 2007 | Toshiba SD-V392 DVD Player/VCR
Whirlpool lhw0050pq washer will not spin
Possible your belt is loose; you have to unscrew the back after disconnecting electrical connection from wall socket. If the belt "gives" more than half an inch, you have to loosen the motor bolts and push motor upwards, then tighten the bolts very well. Try spin only to check, before closing the behind. It shd spin very fast.
Apr 25, 2007 | Whirlpool LHW0050PQ Front Load Washer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
