Question about iLO V27DMBX Television
Cleaning tv screen
My ilo HDMI tv screen was cleaned with pledge and now I have a dark place on my screen. Do you of anything that will take care of getting this off my screen?
  • iLO Master
  • 5,568 Answers
Pledge has a solvent (maybe kerosene) that can damage plastics. I think it warns of use on plastic on the can. You may be able to buff the area with a plastics polish that is used on fiberglass tubs and showers. Try a small area first-
Posted on Oct 06, 2008
I have an ILO HDTV. I try to change the station with the remote but the TV only changes the station between 2 and 22. It doesn't respond to my commands when I want to place it on channel 3 for my...
My ILO TV has a source selection that can select where the signal input is coming from that I want to display. Do you have the sat hooked up to an HDMI input? If so try selecting that. If you do have the option of using HDMI - buy a cable and hook it up between the sat (assuming it does support hdmi) and the ILO (mine does, and it about 5 years old). This is the least problematic way to make it work.
The Poodle Guy!
Nov 21, 2010 | iLO 2600 Television
No luminance
poor very dark is sighn of bad bulb ok after 3000 hours they get dark they wont die just get darker in darker like what going on now and have stuff looks like red nasty get new bulb ok
Feb 10, 2008 | Mitsubishi WD62627 62" HDTV
Black blotch on bottom of screen
if you can take the screen out , then use some dish soap,rag and water to clean the black blotch
if that don't work you may need to use something a little stronger , but not enough to hurt the screen
please rate a fixya and I'll be happy to assist you in the cleaning process and care of the screen
Nov 07, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
Dark Blotches
This is probably caused by dust, either on the mirror, lens, or possibly inside the light engine. There is a 5" dia hole on the side of the back of the tv where you can take out one screw and take the door off. this is just big enough for you to put your hand through to clean the mirror and lens. Hope this helps.
Mar 30, 2008 | JVC HD-61FN97 61" Television
Dark Blotch on rear projection TV screen
usually these are caused by cleaning the screen with a damp cloth or fkuid rear projection tv's usually have two plastic screens separated by about quarter inch with bulbs between,one being a magnified screen.problem is,condensation can occur causing various blotches,letting the screens naturly dry out usually solves this but failing this you have to strip down and wipe them with clean dry cloth.be careful though the inside screen is very delicate.
Feb 21, 2008 | Televison & Video
Dark picture
take the screen off by unscrewing all screws around back of tv. remove panel with a sticker that says " no user serviceable parts inside" remove both screws on each side of screen at bottom with black tabs. there will be 2 screws behind the panel with the sticker on it and unplug the front panel buttons connector. then clean the small mirror with very soft cloth maybe nice cotton t-shirt. be very careful not to scratch the face of the mirror. i would recommend ussing just the cloth but have found isopropyl alcohol to work well if you need to use any liquid.
Feb 20, 2008 | Mitsubishi WD-62725 62" Rear Projection...
ILO-26HD Audio & Video
I have a ilo 26 lcd tv with built in hdtv tuner and I have a red line down the center of the screen that started today. t
Feb 06, 2008 | iLO 2600 Television
Dark picture
do you get all three colors? red, blue and green?
Dec 16, 2007 | Panasonic PT-51G44 51" Rear Projection...
ILO 26" LCD HDMI TV
I had the same problem at first. Then I went back to fry's and bought a new DVI cable. Make sure you bought the right one.
Nov 25, 2007 | iLO 2600 Television
Help
if the tv has never been service before you could have dust on the 3 tubes,this will decrease the brightness to the screen. try taking the front or back off & see if you can see the top of the picture tubes. remember to unplug the tv & to clean spray the cleaner on the colth , then clean the tup of the tube. never spary on the tube itself. hope this works for you. to remove the screens remove the front grill, then remove the screws @! the bottom of the screen & if i remember right the top just sits on a lip, so gently try to lift the screen up.careful, these screens are expensive & you will have 2 or 3 of them. some of them are really easy to scratch.
Oct 22, 2006 | RCA P46924 46" Rear Projection Television
iLO V27DMBX Television Logo
132 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
