You need to take your camera in for repair. Call the Nikon USA 1-800-645-6687 between 9AM-8PM EST, Monday to Friday for instructions for returning your camera for repair. They do not charge to examine your camera and estimate the repair.
Are your pictures properly exposed and are they sharp or are your pictures degraded? Is that 1/3-second you describe a delay between the time you push the shutter release and the time the picture is taken or somthing else? Check to make sure you're in the proper shutter release mode (slider switch to right of the mode dial). Also, your self-timer may be turned on. Your camera allows you to set a 2 or 10 second delay from the menus. If it is set to 2 seconds and turned on, it might seem like a 1/3-second delay. If that doesn't help, you camera is covered by Nikon's warranty. Contact Nikon Service at 1-800-NIKON-US (1-800-645-6687) 9AM-8PM EST, Monday to Friday.
Sometimes cameras that have been stored for a long time can experience stuck or sticky shutters. This is caused by lubrication oil residue building up on the shutter from non-movement over this extended period of time. But this can sometimes be easily fixed, without even opening the camera. To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. If you do succeed in opening the shutter, remember to conduct the post-fix multiple continuous shutter shots to lubricate the shutter.
The ERR message indicates a camera malfunction. In my D-90 manual it says that it can be cleared by releasing the shutter. The only way to do that is to turn the camera off and back on. Rarely, that won't work and you have to remove and reinstall the battery.
The manual also says that it this have frequently or persist to contact a Nikon authorized service center. I would contact Nikon tech support at www.Nikon.com and discuss the problem them before contacting an authorized service center.
In S and M modes you control the shutter speed directly by turning the command dial on the back of the camera. In A mode the dial controls the aperture which indirectly affects the shutter speed. In P mode the dial shifts the exposure to another equivalent exposure, which also changes the shutter speed.
You can download a manual from http://www.butkus.org/chinon/nikon.htm
This is an internal problem, either software or hardware. You have to get the camera to a electronist for repairs, or toa Nikon dealer for repairs/exchange.
If you can dare servicing youself You can open bottom cover of and turn a little red wheel manually. try pressing the release button now and will start working. If you have this problem re-accuring, then get it checked wih professional.
That sounds like your shutter isn't opening. take the lens of and set the shutter speed to B this should keep the shutter open as long as the release is pushed down. advance one frame and hold down the shutter release while looking at the opening where the lens should be. If the shutter opens you will hear it and see the back plane where the film would sit to be exposed. I expect your shutter won't open.
