Question about Mitsubishi WS-65809 65" Rear Projection Television
Device stuck on bottom right icon. cannot change.
Remote no longer has control of tv. new batteries. correct function used for tv control. must manually turn off tv. unable to do so if already selected device on tv. unable to change device status. stuck in bottom right icon. can move up one or left one space temporarily with volume/channel buttons on tv, but will immediately go back to the bottom right icon. can hold device button down and will cycle through all icons. had successfully been able to cycle and press enter to grab a different icon and then everything worked properly from that point. however, old trick no longer working.
  • 927 Answers
Good Day, hcolern2b;
Sound like your TV's front panel button assembly is bad, replace or disconnect and use remote only.
Good Luck, big IRISH.............PS disconnect from front by removing speaker grill and small black panel, follow wire harness.real close by.
Posted on Sep 16, 2008
Source button does not work The hisense Tv cannot respond to change to hdmi and is stuck on monotv
new batteries. But that won't solve the problem if the universal remote apply other code. when the original remote is applied, you touch the tv icon to be sure you are using the correct parameters. When it still won't solve the problem you go to the ir circuit on the set. the reason may be because of the accumulation of the dust and dirt on the buttons.
Apr 30, 2016 | Hisense Televison & Video
Changed batteries in yamaha rav293. Now transmit button stays on and system does not respond to remote.
After a battery replacement, the remote should be set again with the device; with it set-up codes. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Mar 18, 2016 | Yamaha RAV293 Remote Control WR002700
Why will my remote control for Talktalk Youview no longer change channels etc which means I cannot get recent prgrammes? It only switches the TV on and off. I have got new batteries . This makes no di
Check the remote control for its infra-red emission by pressing all the non-functional buttons on it. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Oct 16, 2014 | Televison & Video
I have a Sanyo DP42849 TV and the original remote but when I changed the batteries in remote it no longer works. I have tried several new batteries. The lights work on remote but not functioning the...
A lot of the new televisions today come with remotes that have to be re-programmed after the batteries are changed. I would contact the television's manufacture and find out if the re-mote, the television, or both have to be re-programmed.
May 15, 2014 | Televison & Video
Codes for universal remote control icon tv
como programo este control con un tv marca sansui???
Feb 12, 2013 | Philips SRU5100 Five Function Icon...
Remote will not work tv.
A working TV remote is a security blanket that allows us the peace of mind of knowing that we don't have to get up unless nature calls or the house catches on fire. People are more likely to spend more time and energy to fix their TV remote than to get up and change the channel. There are a number of simple fixes that can ease your mind when your TV remote is not working.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Easy Instructions Things You'll Need:
  • New Batteries
  1. Check the batteries. Make sure the batteries are in correctly and, if they are, replace the batteries. If the batteries are dead or are not in correctly, your remote will not respond and the LED light will not illuminate when a button is pressed. Make sure the TV is plugged in. An unplugged TV will not respond to any remote.
  2. Check the selected input to make sure the remote is set on the TV and not some other device programmed into the remote, such as your DVD player, VCR, or video game console.
  3. Reprogram the sync code. If you are using a universal remote, it may have deprogrammed, leaving the remote and TV out of sync.
  4. Unplug the TV for a few minutes. During a power surge, a TV can become "confused." Unplugging it for a few minutes will give the TV the break it needs to sort everything out and work properly with your remote.
  5. Use another remote on the TV. Program a universal remote to work with the TV. If the TV does not respond, the problem is likely with the TV and not the remote control.
Jan 09, 2011 | Toshiba 62HM95 62" DLP HDTV
Remote want work on tv
Make sure that you're using the supplied Remote (RMY-906) to control the TV. If so, perform the steps given below to resolve the issue.
  • Make sure that you're using batteries which are having enough charge. Try using fresh alkaline batteries.
  • Do not use rechargeable batteries in the Remote.
  • Ensure that the batteries are inserted correctly with the correct terminals by checking the + and - symbol in the battery compartment.
  • Make sure that the Remote is set to operate with the correct functions. On the remote control, press the TV FUNCTION button to re-check this.
  • Press the POWER button and other buttons to test the operation.
  • Make sure that none of the buttons are jammed in the remote control.
  • Ensure that the remote control is being used no closer than 3 feet and no further than 10 feet away from the unit. Try using the remote control at varying distances from the TV.
  • When using the remote control, be sure to point it directly at the remote sensor on the device.
  • Remove any obstacles that may be in the path between the remote control and the device.
  • Ensure the remote sensor of the device is not exposed to direct sunlight or bright florescent lights, as this can interfere with the sensors ability to receive signals from the remote control.
  • Try resetting the Remote. To reset the Remote. remove the batteries from the remote control, press every button twice, and then reinstall the batteries.
  • Try resetting the TV also to check the operation. To reset the TV, disconnect the power cord for a short period of time (approximately 1 minute), then reconnect the power cord and power on the television.
If the remote control is able to operate other devices (such as cable box, DVD Player or satellite receiver), then the issue may be with the IR sensor on the TV. If this is the case then the TV that will require service. Otherwise, the remote control may need replaced.
Good Luck!
KenSolutions
Nov 23, 2010 | Sony KP-61S75 TV
Input button on my new universal remote doesnt work
You'll have to try a new code for your TV.
http://66.77.167.109/rcaaccessories/RcaaccessoriesController.do?ACTION_TYPE_ID=ACTION_TYPE_CATEGORY&ACTION_CATEGORY_ID=STR_CATEGORY_UNIVERSAL_REMOTES
Click the remote code finder link on the left towards the bottom of the page.
Select your remote and device (TV in this case) from the dropdowns.
Scroll down the results page to your brand of TV and try all the codes until you find the one that works with all the functions you want.
Best of luck!
Dec 21, 2008 | RCA Universal Remote 3 Device Remote...
Lost codes for 4 in one used for universal remote control
DRC800 Sanyo TV 0799,0154,0893 Panasonic VCR 0035,0162,1062,0616,0225,1035 press device key for 6 seconds led will blink solid key in code correct code will cause led to blink 3 times press power button to confirm code works. rg
Sep 09, 2007 | Philips 8-Function Universal Learning...
Mitsubishi WS-65809 65" Rear Projection Television Logo
76 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
