Question about Kitchen Ranges
My catalytic oven keeps blowing the fused trip after recently completing the catalytic cleaning cycle
  • 70 Answers
Hi there, you could have a burnt out wire in back of oven. :)
Posted on Sep 07, 2008
Free fuse box diagrams
Parts #: W10317343
Substitution: WPW10317343 $145.98 at sears
Parts #: W10354052
Substitution: WPW10354052 $125.92 at sears
Part #: W10317347 front LED board $230 at sears
Many ovens have a bi-metal thermal fuse-also called a thermal limit switch-that protects the oven from overheating. The oven thermal fuse trips when the temperature in the oven gets too hot. After the thermal fuse trips, the oven won't heat. If the thermal fuse trips after the self-cleaning cycle, try resetting the fuse by turning off electricity to the oven, removing the exterior back panel, and pushing the reset button. If the fuse tripped during normal operation, replace it. If the problem persists, the electronic oven control board might require replacement. Reset the thermal fuse after replacing the control board.
Jul 15, 2014 | KitchenAid Ovens
Clean mode electric current went off was off 10mentis when it came back on oven didnt
I have a whirlpool double oven too and replaced the control board last year the problem started with a F06 code and would reset when I power cycled for a while until it completely quit. Changing the control board fixed that problem. I just used my self cleaning cycle recently and the oven went completely blank on the control panel. Power cycle didn't do any thing. I checked 2 of the thermal cutoff fuses that are shown on most of the parts listing but the problem was with one that is not shown. The link below will get you to the part I replaced it's the power feed to the control board. Turns out that the worst thing you can do to your oven is use the self clean feature. Oven Thermal Fuse
May 29, 2014 | Whirlpool GBD307PDS Electric Double Oven
Have a Kenmore Elite Built-In oven 790.4812. It's a double oven. Was working fine. 1 year old. Wife self-cleaned upper oven for first time. Oven does not work now. Sears Repair guessing that the oven...
It has nothing to do with the tight fit.
It has everything to do with self-cleaning on ovens.
The thermal fuse blows due to extreme temperatures.
Replace the fuse to use the oven.
Use an oven cleaner to clean the oven OR replace more fuses in the future.
Jul 25, 2011 | Ovens
Washer keeps blowing fuses
Do you mean the houses circuit breaker? If so, WHEN in the cycle does it blow the circuit breaker? WHEN it trips will tell you what to look at. I.E. If the circuit breaker trips during the fill cycle then it would be the walter inlet valve or the timer in the control panel; if it trips as soon as it is in the agitator cycle - then the motor or transmission; if it trips in the spin cycle - then the drain pump or transmission or control panel.
Jul 15, 2011 | Maytag LSG7806A Front Load Stacked Washer...
The fuse keep on blowing after few minute of use in electrolux dishwasher ESl4114
Hi, the most common fault on a washing machine is when the heating element is breaking down it will cause a trip or a fuse to go because it is a "resistive load" i.e a small short circuit.
Try to put your washer through a cold wash cycle if it completes the cycle without blowing the fuse then you know that you need a new element. If it still blows the fuse then you are looking at most likely a motor problem.
Jun 11, 2011 | Electrolux 18 in. ESL4114 Slim-Line...
MR Breadmaker 48268 - trips the house fuse part way through kneading process. If I reset the fuse it will trip again immediately. We have popped the dough into conventional oven producing edible but dense...
I have same problem. MR breadmaker tests as OK for earth leakage, but blows circuit breaker when begins the heating cycle. Electrician advises that dust and/or moisture can make internal switches work poorly which leads to tripping of modern circuit breakers. He suggested taking it to service centre for a clean and test, but wasn't hopeful that this woudl cure the problem. Costs more to get things fixed than replace them nowadays!
May 08, 2011 | Morphy Richards 48280 FastBake Bread...
Thermal fuse keeps blowing. Dryer heats up too
The problem will be either your vent is stopped up or the cycling thermostat and the high limit thermostat are bad. If the vent is clean, both the cycling thermostat and the high limit thermostat are welded closed. Both are supost to open to avoid over heating. Go to www.partselect.com and enter your complete model number. It will bring up diagrams of you machine. From there you can find the parts ans also order them if you want to. Good luck.
Nov 25, 2009 | Cars & Trucks
Problem with electric oven
Either your fuse holder/breaker has a bad connection and has a voltage drop tripping your power  or  your heating element is shorting to it's outer jacket which is grounded.  Check your heating elements carefully for wear and disconnect that element and see if it trips still.
Nov 09, 2009 | Ovens
Circuitry may have gotten tripped during clean cycle. Oven will open and electronics work but neither element will heat.
baked control module for heating elements. if you have a volt meter, check for power when oven on, if no juice its the control element, if you do get juice then its the elements
May 28, 2009 | Whirlpool GBS277PRS Stainless Steel...
Kitchen Ranges Logo
56 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
