I have clicking sound from my Toshiba 1.8" hard drive and it is not opening? Where can I get it repaired?
    President:
  • 2,961 Answers
The clicking is the the head trying to read or park in the drive, this is unrepairable, you have to replace the drive
Posted on Sep 07, 2008
Toshiba canvio 1 tb is displaying red where it used to be blue when I click Computer and it's drives.
It sounds like the drive could be full? Right click the drive and select properties. It will show you how much of the drive is used up
Apr 19, 2014 | Toshiba Canvio 500 GB USB 20 Portable...
Tip
How to back up a offline disk folder
<p>Backing up your computer in a folder on the hard disk that goes offline, because sometimes surprisingly simple for the Windows Sync Center. You have a network available offline. Your computer will copy the backup of the hard drive of your computer's hard drive when you're online. The folder will appear as if it were accessible online, because the files are copied to the folder on your computer and then sync when the device is online. <br /> <p><br /> <p>1. Click "Start", "computer" and open the folder with your backup folder. Right-click the backup folder and click on "always available offline." <br /> <p><br /> <p>2. Waiting for the files in the directory so that the copy on your computer available offline. <br /> <p><br /> <p>3. Right-click again on the backup folder and click on "Map Network Drive". Click "Finish". <br /> <p><br /> <p>4. Click Start, Control Panel, System and Security "and" Backup and Restore. "Click" Create Backup.<br /> <p> <br /> <p>5. Select the mapped drive that you defined earlier in the Drive list. Click "Next" and follow the steps to complete your backup to adjust. Click Save Settings and perform the backup. " <br />
on Jun 22, 2011 | Computers & Internet
Tip
How to back up your iTunes in Window 7 OS
<p>On CDs (Discs)<br /> <p>1. Open iTunes. Click "File" tab at the top of the screen to "Library" and click "Backup to disk" option "iTunes Backup" window.<br /> <p><br /> <p>2. Choose one of the backup "iTunes Backup" screen - with the back of the entire iTunes library and playlists "or" you only buy from the iTunes Store. "<br /> <p><br /> <p>3. Insert a CD-R or DVD-R drive and click "Next "in the "iTunes Backup" window. iTunes will automatically read the disk and start the burning process (see tips).<br /> <p><br /> <p>In an external hard drive<br /> <p>1. Close iTunes if open. Connect your hard drive on the correct port on your computer and switch it on.<br /> <p><br /> <p>2. Find your external hard drive in My Computer and select the folder you want your files back.<br /> <p><br /> <p>3. Open a new browser window and locate your iTunes folder indexed. These can be found in "\ Users \ username \ My Music \".<br /> <p><br /> <p>4. Click Start, and the required files to the hard disk, or select your entire iTunes library and drag the contents to the external hard drive to drop. The transfer may take several minutes to several hours.<br />
on Jun 21, 2011 | Computers & Internet
Toshiba 1tb hdd external hard drive not reading
Try using HDD Regenerator to check and possibly to repair the disk. HDD Regenerator allows to repair bad sectors on damaged hard disk drives without losses of the existing data. http://ulozto.sk/xzjZ2Bd/hdd-regenerator-1-71-keygen-h33t-murtajiz-zip
Jan 11, 2013 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
Bad Hard Drive - Toshiba Satellite A665-S5170
I suggest you back up your hard drive right away and have the hardware tested for possible replacement.
Sep 18, 2012 | Toshiba MK6465GSX) 640 GB SATA II Hard...
Tip
How to back up window 7
<p>Back up your important files and programs absolutely necessity for time.<span> </span>Fortunately, Windows 7 has a built in your favor in the implementation of data backup and recovery procedure for your computer support. Use Backup and Restore Backup Windows 7 and all data stored on the hard disk. Although the Windows utility does not have many extra features such as third-party tools, is more suitable for the backup process and cost you a penny.<br /> <p> <br /> <p>1. Connect the USB cable from the external HD into a USB port on your computer. Connect the "Startup" window that opens.<br /> <p>2. Click Start, click Control Panel. Click "System and Maintenance, click Backup and Restore" button.<br /> <p><br /> <p>3. Click on "Configure backups to backup and restore window that opens. Click on" External Hard Drive "in the destination window and click Next. This means that the hard drive as the location of backup files.<br /> <p><br /> <p>4. Click the "Let me choose" option to a dialog to open files on your computer. Click to select Include system image units. "This option ensures that the backup is a copy of Windows 7 operating system, so belong to reformat or hard disk crash can be recovered.<br /> <p><br /> <p>5. Click "Next" and click "Save Settings and Run-up" on the confirmation window to start creating a backup of your operating system Windows 7. Do not get your hard disk to the process.<br />
File names and folders appear, however no files will open. nothing is being allowed to be copied or copy to it. Error 0x8007045D I/O device error
1) Download (0x8007045d) repair utility.
2) Install program and click Scan button.
3) Click the Fix Errors button when scan is completed.
4) Restart your computer.
Try that, it sounds like a registry error. If it doesn't help let me know.
May 04, 2011 | Toshiba 640GB USB 20 Rocket Red Portable...
My SONY VAIO Eseries laptop model VPCEA23EN serial no.7004176 does not have the option of "Repair your computer" . It does not open further after indicating "starting windows" after...
In your case you can do one thing, make a bootable USB drive of your current windows installation and then boot your laptop from the usb. Now you can see the option "Repair your windows", click it and it will show you the your current windows on your hard drive. Click on that and repairing process will start.
May 20, 2017 | Computers & Internet
2 laptops, 1 no power, 1 no desktop
TO RESTORE DESKTOP ICONS
1. Right-click the desktop, and then click Properties.
2. On the Desktop tab, click Customize Desktop.
3. Under Desktop icons, click to select the check boxes of the icons you want to view.
4. Click OK two times.
If you need to reload Windows and you want to save/backup your data then :-
Remove the hard drive from the laptop, connect it to an USB hard drive adapter and then plug it into a working computer's USB port.
This computer will see this as an external hard drive, then open the various folders and copy/backup the files and or folder that is on the external hard drive. When done, reinstall the hard drive in the laptop and reload windows.
For the laptop that is not getting any power, check to adapter plug that plugs into the power socket of the laptop with a multi-meter.
The voltage reading should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If you are getting a very low reading then the adapter is faulty and needs replacing.
If the voltage reading is OK then plug it into the laptop and wriggle this plug. If the charge LED flashes as you wriggle the plug, then the power socket is either faulty or has a dry solder joint. This can be repaired but it requires the laptop to be dismantled completely to do this repair. Get a quote for the repair before you go ahead, it might not be cheap.
Aug 12, 2009 | Toshiba Satellite M40-S417TD Notebook
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
