Question about Water Heaters
Honeywell wall thermostat
My central heating isn't working at the moment. It turns on and off erratically. It doesn't seem to be the timer and the cylinder thermostat seems fine so I believe it is the wall thermostat which is an old Honeywell model that is no longer on their website.
At the moment a metal wire is in a terminal that has the earth symbol on it, a blue wire is in 2, red is in 3 and yellow is in . Please could you tell me if this is correct?
Thanks!
Richard
  • Richmart Sep 09, 2008
    Many thanks.
    I'll look into this- definitely sounds a posibility.
    Richard.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 171 Answers
Hi,Richmart
I'm Harvey the Plumber,
First, Your question is if your thermostat is wired correctly!
Assuming that it is correct, a common problem that most people and plumbers overlook is correctly setting the heat anticipater on the thermostat.
Assuming that you have a gas central heating system, then you must simply look on the gas valve for the amp rating.
For instance,if the gas valve printing says .4 amps then set the heat anticipater for .4
It's common for the unit to turn on and off erratically (short cycling) when this setting is not correct.
If all you are worryied about is the wiring, you must look at the wireing diagram that came with the thermostat.
Further diagnoses would requie detailed information about your central heating system.
Or the alternative would be to have a hands on tech help you out.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey
Posted on Sep 09, 2008
How to adjust thermostat
How to Adjust Honeywell T6360b1028 Thermostat? ' DIYnot Forums
www.diynot.com > Forums > How to... > Plumbing and Central Heating
Unless the thermostat is faulty, the point where your 'stat clicks is your actual roomtemperature. If your 'stat doesn't 'call for heat' when set to 18 and your room ...
Nov 01, 2015 | Honeywell T6360b1028 Room Thermostat
T6360 dial not working
Turn system off then back on and see if it is working. The manual can be obtained at:
http://historical-products.ecc.emea.honeywell.com/2008_1/pdf/en0r8281uk07r1204.pdf
There is not enough information to give you any more help. What does "Dial not working indicate", the Honeywell T6360b1028 is a heating and cooling thermostat with the potential of having a heat anticipator.
Mar 16, 2014 | Honeywell T6360b1028 Room Thermostat
Honeywell t6360
How do i reset my honeywell thermostat
Remove thermostat from wall, leaving base plate on wall.
Model number appears on back of device.
Google search thermostat model in following format: Honeywell xxxx32 thermostat .pdf
Adding .pdf to search parameter will yield product manual.
Also while thermostat is off the wall, change batteries located in compartment on back of thermostat. These batteries must be changed periodically, for example each 3-4 years.
Jul 17, 2013 | Honeywell TH3110D1008 Pro3000 Thermostat
Why is the clock losing time on my THR860SUK programmer, loses approx 2-3 mins per month.
This is Honeywell digital thermostat.
Warranty is 1 year for workmanship
call Honeywell Customer Care at 0845 604 2893.
Settings are saved with back-up feature, so external power outage or intermittent short should not affect internal time clock. That says the internal electronics are causing issue.
Instruction manual does not have troubleshoot section:
http://www.homexpertbyhoneywell.com/Documents/EN%20Manuals/THR860SUK-EN-d04.pdf
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 29, 2011 | Honeywell Water Heaters
Central heating on all the time!
The zone valve needs replacing.
Sep 24, 2009 | Water Heaters
Central heating comming on,on it own
check motorised valve if you have one on the heating system
Jun 18, 2009 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Honeywell T403A1174 suddenly doesn't appear to call for heat
some times inside the boiler on the internal pipework you will see little sensors, on the central heating piping there sometimes is a thermastic sensor on side of flow pipe with a little reset button on ? i guess with the problem you said the poiler locked out and the pipe work overheated ? this is a safety feature on some boilers not, all and easerly reset via this button ?
Jan 31, 2009 | Honeywell Water Heaters
Water Heaters Logo
219 people viewed this question
Top Water Heaters Experts
paulcarew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
