Question about Whirlpool Calypso GVW9959K Top Load Washer
Ground fault protecting socket trips when washer supply cord is plugged in
Appears to be a short somewhere. I suspect that the last load did not complete its spin cycle. Do you think that it is likely a shorted winding in the motor? If so, how would I verify that?
    Genius:
  • 1,028 Answers
May be a bad ground fault breaker ..putting washer on ground fault not recomended
Posted on Sep 07, 2008
Engine runs rough and stalls sets a p0068 code on a 05 dodge durango
P0068-MAMFQLD PRESSURE/THROTTLE POSITION CORRELATION
' Image
Theory of Operation
This DTC sets when an unexpected high intake manifold air flow condition exists that
can lead to increased engine speed and puts the NGC into a High Air flow Protection
limiting mode. The High Air flow Protection feature includes RPM limits for when a
Throttle and or MAP sensor limp-in fault is present.
When Monitored
During all drive modes.
Set Condition
If vacuum drops below 1.5Hg with engine RPM greater than 2000 RPM and closed
throttle. One Trip Fault. Three good trips to turn off the MIL.
Possible Causes
-VACUUM LEAK
-RESISTANCE IN THE (FS56) 5-VOLT SUPPLY CIRCUIT
-(FS56) 5-VOLT SUPPLY CIRCUIT SHORTED TO GROUND
-RESISTANCE IN THE (Kl) MAP SIGNAL CIRCUIT
-(Kl) MAP SIGNAL CIRCUIT SHORTED TO GROUND
-RESISTANCE IN THE (FS55) 5-VOLT SUPPLY CIRCUIT
-(FS55) 5-VOLT SUPPLY CIRCUIT SHORTED TO GROUND
-RESISTANCE IN THE (K22) TP SENSOR NO. 1 SIGNAL CIRCUIT
-(K22) TP SENSOR NO. 1 SIGNAL CIRCUIT SHORTED TO GROUND
-RESISTANCE IN THE (K900) SENSOR GROUND CIRCUIT
-MAP SENSOR
-THROTTLE POSITION SENSOR
-PCM
Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding.
25312083-mkm0xbqveb5zta3uncrswycs-5-0.png Auto Repair Help US 25312083-mkm0xbqveb5zta3uncrswycs-5-2.jpg
Dec 07, 2014 | Dodge Cars & Trucks
Simoniz S2000 XE02 internal cct breaker keeps tripping after 30secs tried to get a parts break down but that info is really ****** and nothing on line anywhere. Any idea what causes the cct breaker to...
First be very careful because the unit is protected by a ground fault internal circuit interrupter and may trip if there is a short circuit to ground. Even a very small short circuit will trip the circuit breaker.
Something else: If you are plugging it into an already existing ground fault outlet then that may also cause one of the breakers to trip.
Like I first mentioned, if you don't know what your doing be very careful. Electricity and water are not friends, especially if the circuit breaker is tripping.
Good luck,
Marty
Jun 26, 2014 | Coleman Powermate DuraBuilt 1400 PSI...
Washerdryerkeepstrippingelecticsocketswhendoorshuts
You have an electrical fault to earth in it somewhere. The socket tripping out is protecting your safety. Call a service person.
Oct 19, 2013 | Hotpoint Ultima WF860 Front Load Washer
Kenmore 400 series washer. Only three years old. Worked fine until last week, it wouldn't restart after I had paused it. It blew the circuit breaker, shorted the socket, and continues to trip the breaker...
There is a dead short somewhere in the unit, I suspect a leaking pump and the motor got wet, is there any water under the unit? If not then you will have to remove the cabinet and check from the power cord to the control panel and beyound if neccesary to find out what is causing the short. Does the unit trip immediatly or does it take a while. If it takes a while and you have power to the unit for a little while then you may have a motor that is weak and stuck in a bad spot on the winding, you can try to spin it a small distance to see it it will take off. But BY All Means, UNPLUG THE UNIT BEFORE OPENING THE CABINET! These newer machine the cabinet slides off towards the front after you remove a few screws holding the control panel on.
Mar 26, 2011 | Kenmore Washing Machines
Shorting out tripping electricity,when we turn the dial it trips house lecky.was filling wth water an then triped.
Sorry but with such a major fault it is virtually impossible for anybody on this forum to remotely guess what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches, control PCB, water inlet control valves, door solenoid as primary suspects. Secondary suspects could be main motor, drain motor.
I fear that you only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Sorry again and good luck,
John C
Mar 11, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
The socket next to my washer was used to put in an extension cord to fix my deck with a power saw. The socket is still out, but the breaker works for then lights there.
Usually the washer circuit is a seperate 20A circuit. The lights would be on a different circuit usually 15A. Check your panel and see if there is a 20 breaker tripped. Hopefully your panel is labeled (or it should be) Are you saying this tripped while using the extension cord? Another possibility is that it is controlled by a GFCI outlet. You can connect additional receptacles to a GFCI outlet to protect them. Check to see if you have a GFCI receptacle tripped (in garage, bathrrom etc)
Sep 11, 2010 | Gb Electrical 1 30 Amp Ground Fault...
Kicks off imediately ground faught on karcher pressure washer
This is a serious situation. It means there is a short circuit somewhere. You need to have a certified technician or electronics person look into it.
Aug 21, 2009 | Karcher 1750 psi Electric Pressure Washer
Gfi installed yesterday on washer 120 v outlet. washer is maytag 3 years old and gfi began tripping during washcycle. can it be washer 3 pronged cord is not grounded at connection in rear of washer?...
The ground not being connected does not tirp thr gfi. The gfi senses the current between the two legs it will trip when the current returning to ground (neutral) exceeds 5mili amps. This is for personal protection. If you have a gfi circuit breaker disconnect the black wire from the breaker, if it does not trip you likely have a groung fault in the washer. If you have a dryer or other metal object that is grounded (Bonded) you may get a shock from it, also standing (barefoot) on a concrete floor may cause the same. ( bonded is a gronded conductor that attaches all metal parts of a electrical curcuit together) a hot lead goes to ground is a dead short and will trip any breaker.
Jul 11, 2009 | Maytag Neptune MAH5500B Front Load Washer
Ground Fault circuit Breaker trips each time a load is applied
The most likely causes in their order of probability are: 1) water somewhere in the circuit causing the hot wire to ground; 2) a legitimate trip caused by a defect in a device plugged into the circuit; and 3) a defective GFCI breaker. In the first case, wait until it has been dry for about a week and see if it trips. In the second case, make sure there is nothing plugged into the circuit and try resetting. In the third case go ahead and put the regular breaker in, then put a GFCI outlet into the first box downstream from the breaker. If installed according to the directions, that outlet should protect all of the outlets downstream.
Feb 26, 2009 | Cutler Hammer 1 Pole 15 Amp Ground Fault
Trips out the mains fuse.
must be an earth fault within the machine. suspect a burned out wire or switch. possibly carbon dust within the motor. take the top off the machine & have a look at the wireing loom.
SWITCH THE POWER OFF FIRST
Oct 21, 2007 | AEG Lavamat 72640 Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
Dan Webster
Dan Webster
Sal De GO PATS
