Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Print head removal
I have tried everything to remove the darn thing but can't seem to have any results. Put my finger in the black ink hole all I get is a black finger. Just can't find anything to push or pull on this 5300 easyshare A/o;
Lahoma
Button in the top back to push to take it out
Posted on Sep 10, 2008
Error message reads "unable to
It means that the printer is unable to clean the print head number(s) 46. The print head is located under the ink cartridges. Remove the cartridges, and you should see a plastic piece with a hole in it to put your finger under and snap open. This allows you to see the print heads. The print heads look like a sponge type dabber on top of a plastic case. Grab a hold of the print head and pull it out. Look for ink that has spilled behind it or on any of the brass colored computer connections. use warm water and a lint free cloth to scrub it off. Press the print head sponge with your finger and make sure that ink primes and fills the head then put the printer back together and try a test page. If you stll get the error then you need to contact brother for a print head replacement.
Jun 29, 2011 | Brother MFC-465CN InkJet Printer
I have a Dell 926 All-In-One InkJet Printer, I put a new black ink cartridge in the printer; still have plenty of color ink. When I have a document that I want to print from Word, it will sound like its...
Make sure you've removed the shipping tape from the cartridge's print head. More than likely the black cartridge is not disbursing ink - clean the print head carefully with "Q" tip and alcohol and see if black ink comes out slightly. Re-insert cartridge and try again. Perform "clean cartridge" in printer properties window.
Nov 03, 2010 | Dell 926 All-In-One InkJet Printer
My PIXMA 780 has been standing for a while. It will now not print from the 3e BK cartidge. When I print a test page there is no output from this cartidge at all, ie no black prints at all. Colours work...
After setting for a while it is possible the print head is completely clogged with dried ink so bad that even deep cleaning won't help.
You can manually clean the print head by raising the lever and Remove all the cartridges. You can now remove the print head by leaning it forward and up.
Some people use different solvents to clean the print head. I don't like to use solvents because they tend to dry out the rubber seals. I use distilled water.
Set the print head in just enough water to cover the bottom of the print head.
The more clogged it is the longer it needs to soak.
Before reinstalling the print head make sure it is completely dry.
Oct 28, 2010 | Canon PIXMA MP780 All-In-One InkJet...
My black ink ran out so I replaced the ink
Hi:
I have used the printer series that you have for years, and once in awhile, I get a new cartridge that won't immediately print. Often, there is just a bit of dried ink residue on the print head, and that won't allow the cartridge to work correctly.
Some simple things to try are :
1) Remove the black cartridge. and take a damp paper towel and gently swab the print head area. Next, apply some pressure to the sides of the black cartridge, until you see black ink oozing out of the print head. Repeat if needed. Once the ink starts flowing, blot off the excess, and install the cartridge.
If you can't get ink to flow, then the cartridge might be bad. Most of them have an expiration date on the packaging.
Mar 31, 2010 | HP DeskJet 960c InkJet Printer
Canon S900 - No black ink (none!)
Clean the contacts on the back of the print head.
Aug 22, 2009 | Canon S900 InkJet Printer
HP 5510 will not print using black cartridge
  • Put a tiny drop of isopropyl alcohol, or bio ethanol on the opening of the printhead (remove cartridge, you will see the opening below the cartridge)
  • Put cartridge back
  • Clean print heads
  • It WILL work again!
Jun 03, 2009 | HP Officejet 5510 All-In-One Thermal...
Black Ink not printing
Call this number. I had the same problem, and Kodak is replacing my print head FREE of charge. As the printers in the 5000 series are still under warranty. 1 800 421 6699
(To remove your print head: first remove the color ink cartridge. there is a button of sorts under a small ledge just above the picture of the finger used for installation. Press FIRMLY here, up towards the ceiling. The print head will come out. To reinstall, just put back in and press again firmly on the pic of the finger till it snaps.)
If you get the same quality of print, you need a new head.
Aug 07, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
My Canon ink jets are blocked an need to fix this quickly
Run the printer's Maintenance program and run Deep Cleaning.
Do a print check after each clean as this uses a lot of ink to clean and you don't want to continue after you get a good print result.
Good Luck.
Apr 18, 2008 | Office Equipment & Supplies
Canon iP90 Printer Problem
take printhead out and put cleaner or turps on gauzes, dab off with paper towel, reassemble and run clean programme - this worked for me and from no black output I ended up with full function printer
Jan 02, 2008 | Office Equipment & Supplies
Dell 922 All In One Printer wont print
did you remove the seal of new catridge. bye
Sep 24, 2007 | Dell 922 All-In-One InkJet Printer
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
32 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
