Question about Panasonic DMR-ES40V DVD-Video Recorder
Panasonic DVD Recorder
Rb_walker: I have a Panasonic DVD Recorder model DMR-ES40V. When I try to finalize a disk, it give me finalize fail error. I have unplugged the unit for 24 hrs to try and reset it and it still fails to finalize a disk. I am using the proper disks.
  • 4 more comments
  • Ron Walker Sep 08, 2008
    The DVD does record and I can play it back. I cannot finalize the disk. It keeps giving me a "final fail" error. Thanks for the help.
    Dan, I can play back the recording but I cannot finalize the disk.
  • Ron Walker Sep 09, 2008
    Dan, I think the problem is in the finalization stage. The other ideas did not solve the problem. Thanks for helping me.
    Ronnie
  • Ron Walker Sep 11, 2008
    Dan, I down loaded the updates you described. I still get the "finalizing failed" error. Any other ideas? Thanks...Ronnie
  • zofia27 Jan 18, 2009
    I'm having a problem finalizing DVDs. Same brand sometimes works and sometimes doesn't.
  • Frustrateddo Apr 30, 2009
    Same prolem
  • 4,234 Answers
We need to narrow down where the problem lies. Even without finalizing the disc, you should be able to play back the recording. Can you do this? If you can play back the recording, the problem exists in the finalization stage and we'll need to concentrate there. Pplease update this and we'll proceed to the next step.
Thanks,
Dan
Posted on Sep 08, 2008
  • ABRsvcs Sep 09, 2008
    Check the firmware version of your recorder. There is an updated version (UG-149) available from the Panasonic website that may help. I have included below the "items addressed" list from that site.
    Dan
    1. Resolves scheduled recordings not completing when 2 or more recordings are scheduled per week.
    2. Resolves U99 error message displaying after reading "Search and Rescue" DVD-Video.
    3. Improves Flexible Recording.
    4. Resolves scheduled recordings not completing when recording is set to begin before midnight and end after midnight.
    5. Resolves "!" being displayed on the Scheduled Recording table when enough space is available to complete the recording.
    6. Improves playability of DVD-R discs finalized on the DVD Recorder in PC DVD drives with DVD player software.
    7. Improves Auto Clock Setting functionality.
    8. Improves Daily and Weekly Scheduled Recording.
    9. Corrects DVD-Video playback due to Region Code error.
    10. Resolves the "split screen" symptom caused by changing from Interlaced to Progressive Scan.
    11. Resolves the remote code inexplicably changing.
    12. Resolves "OK" being displayed on the Scheduled Recording table for recording to VHS. "--" is displayed by original specification.
  • ABRsvcs Sep 11, 2008
    I don't have one of your models in my shop at the moment. Let me research this a bit and see what options I can get for you.
    Dan
DMR-es40v f60 error
Problem for Panasonic DMR-ES40V DVD-Video Recorder with Built-in... Maching displays F60 as soon as it's turned on and
Nov 13, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
F60 Error message on DMR-ES40V unit
Unplug the unit.
Plug back in and wait till you see 000000.
Press and hold the power button in at least ten seconds or until the clock shows up.
This worked to fix mine.
Jan 05, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
Panasonic ES40v - Can't play DVD's - Incorrect region
I had the same trouble, also wouldn't play back discs that I recorded using it. The commonly listed reset of channel up and down at the same time was not meant for this model.
Below is the official solution that was sent to me by panasonic.
After using this method to reset my player it worked great. it was just like taking it out of the box for the first time.
Dear Valued Customer,
Thank you for your inquiry, reguarding model DMR-ES40V.
Try this reset to fix the issue.
1. Unit power must be on.
2. Press [STOP] & [VHS > DVD] ON THE UNIT for over 5 seconds.
Thank you for contacting Panasonic.
Thank You,
Panasonic Consumer Support
http://catalog2.panasonic.com/webapp/wcs/stores/servlet/CustomerSupport?storeId=11251
Nov 02, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Dvd recorder
Hi Nickstart, start checking if the problem is related with the kind of Disk and test on different brands, disk types.
Even if a recorder is supposed to work fine on both +R, -R etc. , often you find out, that due to error correction methor, a device worksd well on one or the other type.
Your DVD supports the following DVDs -R, -RW, -RAM, all -R disks are supported both on 3'' and 5''.
On +R it just writes regular DVD +R, DVD +RW and mini DVD +R are not listed in DVD specs, therefore are not supported on writing.
When your unit records DVD +R it changes the format to DVD-V, The usint does not support DVD+RV.
I assume it works better with -R
I often get troubles with many DVD low price brands, try testing some good ones like Verbatim, TDK, Sony , Philips etc.
See also the manual here, at page 6 and 7 it also says: "Play may be impossible on some DVD-RW (DVD Video Recording format), +RW, CD-R or CD-RW discs due to the condition of the
recording."
Hope this had been helpful, test both a good brand DVD-R and a Good brand DVD+R.
If it still has problems when finalizing the CD, then it can be the usual lens problem, Or the DVD you are writing is too big in size and your player has problem on the final phase of DVD writing. If Data nearly takes all the 4.7 Gb allowed, there won't be enough space to finalize the DVD.
Sep 08, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
DMR ES40 Panasonic DVD Recorder
hellow if you send me your email ill send you a video repose on how to and how to correct this problem
Sep 06, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Panasonic DMR-ES40V, error codesF60 & U99...
Same problem. Contacted Panasonic. Technician indicated that there is a problem between the CPU and the timer. The unit is three years old and out of warranty, so he offered Panasonic's service at $120 for labor plus any parts.
So I gave it one more try. I pressed and held the REC on the Power button for about 10 seconds, which reset the unit. Then I was able to play a DVD and eject it.
Hope this helps with your unit.
Jul 21, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
DVD Recorder will not format blank DVDs
I kept formatting DVD's until I got the unit to work. Mainly, it was some DVD's I had earlier problems formatting. I tried two new DVD's (Maxell DVD-RW) and they worked thus far. I truly think the unit needs to be taken to authorized service center for evaluation or minor maintenance. My suggestion is to verify the DVD's will work with unit. Try to use better quality ones like TDK or Maxell. Thanks for responding to my problem. If I have others, I will contact you.
Feb 09, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Panasonic recorded dvds? what's up?
http://service.us.panasonic.com/OperMan/findmanual.aspx?model=DMRES40V
Try the Manual. It has a finalizing section. This is the link above.. Pat
Aug 02, 2007 | Panasonic DMR-ES40V DVD-Video Recorder
Televison & Video Logo
479 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
