Question about Mitsubishi VS-45605 50" Rear Projection Television
Veertical lines mitsubishi VS 45605 after tv warms up i get vertical lines across the screnn
  • carjoe69 Jan 10, 2009
    vs-45605
  • emedepatty Mar 23, 2009
    i have the same problem , but nobody has looked at my tv model
    vs-45605. i spoke to a repair man and he told me that the parts are discontinued and the tv was pretty much history. I dont know who to believe. If i place a fan in the rear of tv what kind of fan and where should i place it
Put a fan in it. Something is overheating in the unit and by placing a small fan in the back, inside the back cover, the lines disappear. Hope it works for you, it did for me.
Posted on Oct 24, 2008
When I first turn on the TV, and until it completely warms up, there are horizontal lines across the screen that roll so you can't see the picture. As it warms up, the lines slowly disapear until the...
You will need to remove the signal board. This is the board with the RCA jacks and RF connectors. On this board there will be many components that are numbered. You will be searching for two capacitors that are bad. These are the locations and values. The first is capacitor location, C2V29, which is 16 volts at 22Mf , replace this. The next will be C2P05 which is 16 volts at 100 Mf, replace as well. And if you do have the board removed, you should, as well, resolder the pins on the convergence ICs. These are ICs are mounted on large heatsinks. Inspect the board for any and all other bad solder grounds. Thanks for asking and show a few hands of support.
Dec 12, 2010 | Mitsubishi VS-45605 50" Rear Projection...
Screen rolls maybe vertical sync
II NEED TO RESOLVE A PROBLEM OF VERTICAL SINCRONICE I SALLBE GRETFULL TO HAVE ADJUSTMENT INFORMATION I SHALL BE GRATEFULL IF YOU COULD HELP ME
May 26, 2009 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi 60" I believe 1997 Model
You need a new PIP module. Surface mount capacitors have leaked out electrolyte and damaged the PIP PCB.
Barneyluc
Oct 01, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi #VS-45605
We had a blue cone on the screen. We have adjusted the sharpness, contrast, and cross hairs. The cone has almost completely disappeared, but we still have blue shadows. Could this mean a blown color tube?
Any suggestions would be greatly appreciated.
Aug 13, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi VS-60705 Large Screen Projection
thanks for your detailed description of what happened.
replacing the vertical output i.c will correct the problem.
the reason it failed was bad connections on it.
Apr 22, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi VS-45605 convergance
you will need to replace both convergence i.c.s as a pair
Nov 27, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Ghostly vertical lines
you have done said it vertical lines then you will have to take your tv to a tech for repairs.good luck.
May 13, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Picture has horiz. lines
There is no vertical hold in the tv circuits now adays. You may find a vertical center or a vertical height. Your problem sounds like (if it has PIP Thats Picture in Picture) its in the PIP module and its a small module that stands up and most models of Mistubishi this module is no longer availabvle. The problem with the module is the small pana caps are leaking and ruins the PC traces. I have heard that theres a kit available on E-Bay to jump out this module. Now if its not the PIP model then it could be a few capacitors in the vertical sweep circuit. Also the B+ feed off the Flyback that supplies voltage to the vertical output IC could have a bad or leaky capacitor in the circuit. If your not a tech or solid state troubleshooter theres not much you can do and SHOULD take this set in to a repair center. Good Luck
May 21, 2006 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi VS-45605 50" Rear Projection Television Logo
250 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
