Question about Archos 604 Digital Media Player
ARCHOS 604 SYSTEM IS DAMAGED. WOULD YOU LIKE TO RECOVER IT ? NO REPAIR FORMAT DISK
SOURCE:
Benimur
  • 6966 Answers
SOURCE: I have a archos 504
Your post/description indicates a possible problem with the firmware. It would seem that the Archos would load but fail to finish and there restarts itself. This could only be possible if somehow the firmware has been corrupted or you tried a firmware upgrade but failed halfway.
There are several versions and you need to determine which one you have.
Things you can try:
1. Do a soft reset. Press on the power button for about 15 seconds;
2. Do a full/hard reset by removing the batteries and pressing the master reset button;
3. Try again the Systems Recovery. You may need also to format the internal HD but that would mean you loose whatever data is inside.
Alternately, you may need to update/re-install the firmware. A more complete and better explained firmware update procedures are here. Briefly, you have to download and save in your PC the ???????.aos file (there are several versions of the firmware. You need to determine which one is appropriate to your model), connect your Archos to the PC, copy/paste (drag & drop) the said file to the Archos device listed in "My Computer" (you may have to overwrite the older copy), disconnect the unit, proceed to System Settings, tap on "Update Firmware". Follow on screen instructions.
If the above is not corrective, am afraid that your unit has been partially bricked. Some have reported serious hardware or firmware problems with the Archos that would require replacement by the manufacturer.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 05, 2008
  • 4 Answers
SOURCE: Archos 604 Wifi Recovery Code 2
hello everybody, i had this same problem with my archos 604 wifi but thankx to someone on another forum i fixed it. it is really easy:
first you take the battery off, then you unscrew the 4 or 6 screw on the sides of the hard drive, then you lift the lid and then the hard drive, VERY CAREFULLY, Then you will see the problem : the little black plug conected through a ribbon to the hard drive is not plugged correctly or it is completely unpluged from the white socket. even if it is not un plugged just make sure it's tight, put everything back together and it should work just fine. ( IT IS A LITTLE DIFFICUL TO SCREW IT BACK TOGETHER BUT YOU"LL GET IT RIGHT) it is a weird problem. but it is easily fixed.
i hope that helps, bye
Posted on Apr 18, 2008
  • 4 Answers
SOURCE: archos 604 (non wifi) recovery 4
  • 6 Answers
SOURCE: My archos 605 won't do anything but to show recovery code 102.
recovery code 102 screen - this error message means the the hard disk has failed - I am guessing that the unit has been dropped at some point - Sorry but it back to Archos - The UK number is 0207 949 0115
Posted on Jan 20, 2009
IPOD tech
  • 61 Answers
SOURCE: recovery code 104 for the archos 405 mp4 player
I fixed my son's 605 4 GB had Recovery code (104) on it These are the steps i followed
* Use the computer for this process that you always used for this archos
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white screen comes up do format
* Wait until all done then put the firmware in to the root sector of the Archos
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug in back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving wait until it is all done and it will shut off. Turn it back on Your archos will be back to normal
Posted on Feb 27, 2009
Hello i have a problem my archos 604 30 gb is broken i dropped it and every time i switchting it on a following information is shown on the screen : Recovery (code 2 ) System is damage.Would you...
Sounds like the hdd has dislodged due to the knock...open it up pull off the hard drive...reconnect it..or reseat the connection..and try again...if that doesn't work...you could try removing the drive to run a chkdsk facility using Linux on a pc...or source another hdd off eBay with the correct file system and drivers...for that model.
Dec 16, 2017 | Archos 604 Digital Media Player
Recovery (code 104)
From Archos' support website FAQ:
When I switch on my Archos device, the following message is displayed: "Would you like to recover your system?" What does it mean and what should I do?
You are on the recovery mode screen. It means that your hard drive has been damaged and must be repaired or formatted.
With this system recovery mode, you will have to select between "Repair Disk" and "Format Disk".
Start by selecting "Repair Disk" and follow the instructions displayed on the screen. See the full PDF manual (available on the Archos web site) on how to use the Repair and Format options.
If repairing the disk did not work, try formatting the disk by selecting "Format Disk". Note that the formatting will erase all data.
If you still cannot restart your Archos after trying a system recovery, you should contact Archos technical support.
http://www.archos.com/support/support_tech/faqs/en/faq_Archos405.html?country=us&lang=en
Feb 17, 2011 | Archos 405 Digital Media Player
I have archos 504 160 gb when it turn on i have message (recovery code 4) would you like to recover your system ? no - repair disk - format disk when i push no no thing action . when push repair or...
This is a recovery mode, and this menu allows you to:
-Format your hard drive
-Restore your system
In case of repair disk is selected :
For the first step you have to go on our website, and download the latest firmware update for your product.
Plug your Archos 504/604 on the computer and copy the firmware previously downloaded at the root of your device.
Disconnect your device as usual, and select done on the screen.
You have to plug the dc adaptor to update successfully, press a button to reboot your device.here is the web address  http://www.archos.com/support/support_tech/updates.html?country=us&lang=en&#firm
Nov 27, 2010 | Archos 504 500870 Digital Media Player
How to deal with this problem
I was watching a film on mine and it paused and I hade to hold in the power button to shut it off.
When I restarted it I get that error message too.
I did the same as everyone else with no luck, so I left it on thinking that maybe running the battery down and charging it again might help but no luck.
I left it for a week then decided to have another go at fixing it.
I removed the battery and used the reset button to set it to factory defaults.
I powered it up and got the error message and tried the USB cable again (Can't remember for sure if it was on or off when I connected it) and I got the option of connecting to my PC and copying a system update to it.
I downloaded the update and copied it to the harddrive and it then updated itself and restarted.
It booted up ok but when I restarted it I get the error message again.
I redid the first bit again and using the XP Disc Management I removed the partition, then redone it.
I restarted the 604 and formatted the harddrive and copied the update and it updated and restarted again.
The pointer needs to be calabrated again on it to work but it's back to normal now and working great.
I set everything up and copied all the folders into a folder on my PC so if it happens again I just need to fix the harddrive and copy the files over.
Jun 01, 2008 | Archos 604 WiFi Digital Media Player
Archos 404 could not start
it sounds like the partition that hold the recovery files has got damaged,i suggest you talk to the manufacturer or supplier on how to overcome this problem,if it was a pc i would say format hard drive & re-install the software but its not .
good luck
Terry
Mar 23, 2008 | Computers & Internet
Archos 605 is stuck in Demo mode
Should be the same as it was for my archos 604, try my instructions at
http://thepoetrydude2.blogspot.com
Dec 31, 2007 | Archos 605 Digital Media Player
Recovery (code 2)
I got the same message when I took out the hard drive. I'm sure this will void any warrant, but maybe you should open it up and make sure the hard drive ribbon is secure.
Nov 12, 2007 | Archos 604 Digital Media Player
HELP!
Can you hear HardDrive clicking?
Oct 03, 2007 | Archos 604 WiFi Digital Media Player
Archos 604 Digital Media Player Logo
292 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
Harrie
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
