Question about Siemens SpeedStream 4200 (13A4200001) Bridge
Which is faster 5200 or 4200
I have a speedstream 5200 I got a few years back from windstream and had a 2000 windows on it.Well 2 months ago got a new Dell computor with vista's on it my question is all my friends have a 4200 series,which would be faster,a 5200 or a 4200.I can get a 4200 from a freind of mine if it would make my internet faster.
Thanks,P.B
  • 59 Answers
SOURCE: speedstream modem 4200
put the modem in bridge mode and then connect a DSL/cable router to it...you'll have to configure the PPOE if its DSL... Cable is a little easier because there usually is a MAC authientication not username and password...plug dsl/cable router into cable modem...turn both off for about aminute then turn modem on first then router... Be careful most routers with wireless have it enable with no security by default...turn it off or set securty (wirelss that is)
Posted on Aug 27, 2007
tech curly
  • 298 Answers
SOURCE: speedstream 4200 dsl modem
If you will have the new modem and the same problem will occur, then you can say that it could be a fault with the phoneline or if it is with the old modem.
Posted on May 19, 2008
SOURCE: Placing Sppedstream Modem 4200 in bridge mode
Plug your speadstream modem into your router via ethernet cable. Make sure router and modem are powered on. Once you have conected the two and the power is on just push and hold the reset button on the modem for the count of five. Your modem has now been bridged with your router....It worked for me and I have the same modem just different router. I hop this helps you good luck :)
Posted on Aug 20, 2008
  • 59 Answers
SOURCE: Static Ip with Speedstream 4200 Modem
I am assuming here with the way you have it set up your getting an internet connection.
what you saying i understsand mostly so i'll see if i can help you
first of all you have speedstreem modem that connects to you isp, this is assign your internet address from the isp if you paid for a static IP it would be in here, if not it's assiged by a dhcp from your isp company so if you if turn it off or have a power loss for anymore than 5-15min your ip changes.
now your modem then connects into your belkin router this as well as your modem it's prob set up as dhcp so it wants to issue each computer with an internal address of 192.168.0.X the reason for this is so it knows where to send the incomming information to what computer.
no matter what computer your using the address that goes over the internet will be the one assigned to modem from internet provider so if this need to be static IP to run your game server you will have contact your internet provider for an address.
but you may be confussing the issue a little, my suggestion to you would be:
1. go to your connections on each computer
2. right click on the lan connection choose properties
3. go to internet protocol (TCP/IP) then click properties
4. then click on obtain ip automatically and obtain dns automatically
this will remove the static windows address you may have put in.
try this and see if you can get you game or game server will work.
btw you may have to reboot your computers after this to get be sure to get the new address.
Posted on Oct 09, 2008
http://192.168.254.254/brgmode.html ...or if they have the gay firmware >.> go to http://speedstream/brgmode.html then click apply....now set your router to log in with your user information with a PPOE login...if your like me and using the dlg-4500 just go to setup and do internet wizard to set up easily...then your ready to go... it can take up to 10 minutes for your router to configure so give it time..and if it doesn't seem like it's working in that time...try cycling your power then check again...and if still not working, do a hard reset (hold reset till lights alternat from green to red) to reset to factor default (do it for your router too becfause it will still be set to sign into your isp for you)
Posted on Dec 13, 2008
Internet speed go up to 2mb/sec but it go down to 50kb/sec and don't go back up isp:windstream
Sounds like you're being shaped to dialup speed (~50kb/s) when you have used all your download for the month. This is standard for DSL, at least here in Australia.
When the new billing month starts, your speed returns to normal.
Apr 22, 2010 | Siemens SpeedStream Modem (4100) (SS4100)
Neither front window works anymore...
Sounds like it could be the actual switch for the windows with could be an easy fix if U know how to remove the switch from the door.
Hope this helps
Matt
Jul 03, 2009 | 2000 Oldsmobile Alero
Speedstream 4200 gaming issues
dude i have the same problem but the only wany u can fix that is getting a new one because your NAT is set to Struct and to play some of the games like Halo 3, Saints Row 2, and other 360 games you need to have it set to open.....
May 12, 2009 | Siemens SpeedStream 4200 (13A4200001)...
Trying to use SpeedStream 5100 with new DSL Provider
I have Centurytel myself, so maybe I can help:
A link to your Speedstream 5100 router:
http://www2.windstream.net/downloads/links/SpeedStream211.pdf
And the typical setup for the westell 6100 that centurytel uses:
Centurytel will provide you with your username and password.
PPPoE Configuration:
VPI 8
VCI 35
Protocol: PPPoE
Hope this helps.
Jun 12, 2008 | Efficient Networks SpeedStream 5100 Modem
Speedstream 4200 dsl modem
May 19, 2008 | Siemens SpeedStream 4200 (13A4200001)...
SpeedStream Modem DSL Light
You might want to check with your provider to make sure that they haven't changed anything.  Power cycle the modem, and even perform a hard reset if possible, usually by means of a small button on the back of the box.
Of course you could have just got a bad modem, and in that case, it's just as easy to take it back where you bought it.
Oct 19, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
Speedstream 5200
here is the pdf download link for this modem
should be of some use
Oct 10, 2007 | Efficient Networks SpeedStream 5200 Modem
Siemens SpeedStream 4200 (13A4200001) Bridge Logo
223 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
