Question about GE Microwave Ovens
I am trying to find installation instructions for my convection microwave over the range oven.
  • GE Master
  • 9,086 Answers
You can download GE owner's manuals and installation instructions here.
If yours is not a GE, Please reply back with your brand and model number so we can help you.
Posted on Sep 09, 2008
I need instructions on how to use Sharp Convection microwave Grill 2?
Best way short of Sharp is Google the model number of the unit with "manual" to try to locate free one online.
Nov 04, 2012 | Sharp R-930AK Convection/Microwave Oven
Just installed a GE JVM1790 microwave/convection. Microwave works fine, but convection oven makes very loud noise
My bet would be that the convection fan blade is loose on its shaft or has some other problem.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At
our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
here.
Oct 22, 2012 | GE JVM1790SK Convection/Microwave Oven
Microwave convection oven- convection oven will not heat and the fan makes a loud clicking noise.
It may be that the convection fan blade is loose on its shaft, which will keep the heat from getting out well.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Aug 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Have a GE Profile Microwave/Convection oven. Microwave works, but the convection part does not. Has been this way since installation. Oven will go through preheat cycle, say that oven is preheated but it...
It may be a bad convection heating element or just a bad thermal cutout.
If it's less than one year old, it will be fully covered under warranty and you can contract GE here to have an authorized servicer come out and fix it free.
If it's out of warranty and you or someone you know wants to check it out, I'd first suggest you take a look at the "mini-manual" hidden inside the unit (behind the control panel, hidden on the left side behind the grille, or attached to the inside of the outer cover) which is very helpful when troubleshooting, & testing.
Otherwise, see these files: safety disassembly
Accessing some parts may require you to pull the oven from the wall and remove the cover.
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Dec 25, 2009 | GE JE1540 Microwave Oven
GE Microwave/Convection JVM 1090 oven won't reach temperature
You probably have a bad thermistor.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
(At that site, that part is misspelled as "thermister" for your model).
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Accessing some components for testing will require you to remove the oven from the wall.
Jan 02, 2009 | Microwave Ovens
Instruction manual for LG microwave convection oven
You can download Samsung over the range microwave installation instructions here. If that's no good, try here.
Otherwise, visit this page, click on click on the left-side arrow "Busque por Codigo del Modelo" in the big purple rectangle, enter your model number in the box, then click "Buscar". They may list an English version manual available for download.
Good luck.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 15, 2008 | LG LMVM1935 Convection/Microwave Oven
Open Questions:
GE Microwave JVM1441BH04: Safe to reconnect replacement stirrer & turntable motors after accidentally burning out the turntable motor? GE JVM1441BH04 Over Stove Microwave: Tapping noise was coming from the 21v AC stirrer motor which sits atop the cooking chamber. I disconnected the two connecting leads, unfastened the single screw holding it on, placed in on my scanner glass to get a high rez photo of all the specifics listed on the motor label. Bad news: While waiting for the scan to finish, I warmed my coffee in the microwave on the highest heat for 30 seconds. I subsequently discovered the 21v AC turntable motor, which had been working just fine, was now no longer working, with infinite resistance across its terminals, and a burnt electrical smell. Both the stirrer and turntable motors are powered by a 24v tap off the magnetron fan. My theory: By running the microwave with the stirrer motor out of the circuit, I delivered excessive voltage to the turntable motor, which quickly fried. The 24v tap off the magnetron fan motor currently shows the correct 24v output. However, with both the stirrer motor and turntable motor disconnected, running the microwave for a few seconds shows approx 95v across the wire leads for both of the 21v motors. I have obtained replacement motors for both the noisy stirrer motor and the fried turntable motor. My question: Can I simply reconnect both motors in their proper locations, vow never again to run one without the other connected, and all will be well? Or will the newly installed motors simply be fried in a matter of seconds?
Jan 04, 2018 | GE Microwave Ovens
Microwave Ovens Logo
117 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
