Question about Philips HTS-3555 System
No audio is coming through my speakers
I've had this system for less than one year. It was working fine, but out of no where all 5 speakers have stopped working. I have tried disconnecting and reconnecting all wires - but nothing seems to work. DVD still works just fine [but no sound through the speakers then either]. Is there anything like a fuse that would possibly need to be replaced to restore speaker functionality? Thanks for your help!
    Scholar:
  • 141 Answers
If the receiver is actually powering up but you are getting no sound, there are few basic things to check.
Check the audio connections on the back (speakers AND inputs) to make sure they are tight at both ends and undamaged. Go into the setup screen for the DVD player and make sure the audio settings are set for PCM output and that you are using a digital or optical audio cable. Then make sure you have the correct function selected on the receiver to match the inputs. If the receiver has a speaker test function, use it to see if there is any output from the speakers. Finally, make sure the volume is turned up and the mute button is off.
Otherwise, the amplifier may be faulty
Posted on Sep 07, 2008
Humming sound
This type of sound can be generated by the back-light inverter board.
Jun 15, 2013 | Sony BRAVIA KDL-52XBR4 LCD TV
Pioneer SX-315 Speaker Problem
The bump may have broken or disconnected speaker wires.
May 17, 2017 | Pioneer SX-315
Supertooth disco speaker issue
You need a new battery that supplies the full 2400 mah to unit. Batteries do wear out and the 1800 mah is not going to cut it.
Aug 24, 2017 | Audio Players & Recorders
TX-NR808 audio unexpectedly off
Hello, I am sorry about your issue. Please contact Onkyo at 800-229-1687 option #3 so that we can discuss options. Thank you, Onkyo USA.
Jun 22, 2017 | Onkyo TXNR808 Receiver
How do I diagnose and fix my laptop's sound problem? Should I just throw it out the window?
which operating system
You receive an error that states: There might be a problem with your audio device
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
hope this helps
Jun 26, 2012 | Fujitsu Siemens Amilo Pi2515 Laptop...
I have a Samsung LE40B650T2 - no sound direct from the TV
It sounds that the sound processing section [digital circuts] are working well, and the fault must be either to the speakers, settings or to analogue audio amplifier section. Make sure that the Mute function is OFF. If it is OFF, and still you do not get audio output by tV speakers, surely the fault must be to audio amplifier circuits, provided speakers are OK. If your TV has a headphone out socket, this socket should also checked for proper interconnection.
Jun 24, 2012 | Samsung LE40B650T2 40 in. Full HD Crystal...
I can't get my rear left speaker to work for my LG LHT854
you bought it new ... every new prodycts should come with warranty therefore best advice take it down to where ever you bought it from
May 30, 2017 | LG LHT854 Theater System
Audio problem...
i have compaq presario c700. when i attach headphones, the laptop speakers dont get off. both headphone and speaker are on. the sound should only come from headphones..
i have windows professional installed
ishric_ishaan@yahoo.com
kindly post the feedbakc on my email
May 26, 2008 | Intel Computers & Internet
Philips HTS-3555 System Logo
413 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
