Question about Samsung SyncMaster 2253BW LCD Monitor
Samsung 2253BW Color issues
Hey guys,
So I bought the Samsung 2253BW the other day and everything seemed fine for a while. Then I watched a DVD and noticed that some of the bright colors appear red-ish. I thought it was the movie or something so I didn't pay that much attention to it at first. But when I got into Photoshop today I was sure something was wrong. When making a smooth transition (with tablet) from white to black, instead of grey I got red-pinkish colors. As the colors go darker they seem to appear normal all the way down to black. But the bright parts are just wrong. Tried to fix it manually and spent like 2 hours in the menu, but nothing changed.
It's so friggin frustrating, cause I can't make a print screen and compare or show visual proof.
I'm pretty sure it has nothing to do with the rest of my hardware. My previous monitor was Dell 1130, but it just started blinking on and off and changing modes - going into sepia and cold tones. It just got completely mangled. Then I used an old Daewoo for a while, but the colors there seemed to be fine, though I'm not entirely sure, cause it had contrast issues(Geez! Talk about bad monitor history)
I'm using the 7600GS with latest drivers and so on. But as I said - it has to be the monitor.
Any ideas as to what might be wrong?
  • 2 more comments
  • bopee Sep 26, 2008
    More or less the similiar issue. Color depth seems to have dramatically lowered from when I first pluggeg it in and downloaded latest driver and software for my graphic card... Anybody have advice? I tried to calibrate and tweak every setting I can find with no change.
  • rickhum Oct 13, 2008
    Hi, had the same prob - tried opening the Video card drivers controls specificly the TV and Video settings and change the control from the samsung to the player and it worked perfectly after the change. Give it a try
    I have a geforce fx 5500 258mb/ddr
    richardhummell@gmail.com
  • Crafter64 Nov 16, 2008
    Thanks for the response, but no go.
    It was OK for a while, but after the new drivers I installed, it's totally messed up.
    I'm gonna get me an abacus and get rid of the PC.
    Right. Just fixed the little bugger.
    It was either the drivers for the monitor which I downloaded from the official site or the fact that I changed to 120dpi and then back to 96 (although I seriously doubt the second "solution")
    Here's a link to the drivers. Hope this helps.
    Samsung 2253BW drivers
5 Suggested Answers
  • 624 Answers
SOURCE: something wrong with my lcd screen
As a quick test I would try connecting the monitor to another PC to make sure the problem follows the monitor. If it does then the likely cause is a circuit board or possibly a poor connection inside the monitor. Since working on this would require opening the monitor case and voiding your 1 year warranty I would recommend you contact Samsung support for a warranty replacement as soon as possible. When you do make sure you mention the problem goes with the monitor and any other troubleshooting steps you have taken. Also the replacement they send will itself be something that was returned and fixed.The only warranty you will get will be whatever is left of your original year so definitely get this taken care of as soon as possible.
Posted on Jul 12, 2007
  • 259 Answers
SOURCE: SyncMaster 2253BW LCD Monitor doesn't fill screen in game's
you can change the size of the screen by going to the set up screen (menu) then adjusting the third box down the coarse and fine and the verticle and horizontal positions my settings are course 1798 fine 48 h position 56 v positiion 50 hope this helps regards Jim
Posted on May 13, 2009
SOURCE: menu features are not available
itdoctor
i am technician the advise i give here is only for wih out any responsiblity, this is only for technicians who know how repair lcd monitor in safe and controled enviromen, user or noon technician donot use at home, danger involves.
The samsung monitor 740n has 85 deg cap at c301 ,c311, c312 all 820 uf 25 v and fuse resistor of 3 amp r401 they all fail monitor does not work since there is to voltage to invertors. replace all the above with
1000 uf 25v 105 deg, replace them all and the fuse resistor too, it should work resolder dry joints. it is advise to change all caps if possible.
i have done several of this problem work fine for me.
Posted on Aug 28, 2009
budmrtn
  • 11361 Answers
SOURCE: samsung syncmaster 914v monitor problem.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 17, 2010
Rainbow color effect appears when Samsung LCD plays Wii or DVD
Hello, I have a question which video inputs are you using for your DVD and Wii connections? The reason I ask is because this sounds like video distortion cuased by noise. If possible can you send a picture of the screen when it has this problem and send which video ports are being used? If it is noise in the video you may have a saw filter problem, or a decoupling issue. In any event I'll know more once you send those pictures and which inputs you are using for your DVD and Wii. Thank you, Shuttle83 http://www.electron-age-technologies-llc.com service@electron-age-technologies-llc.com
May 30, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Feb 14, 2009 | Samsung SyncMaster 2253BW LCD Monitor
Blocky images on a Toshiba DVd player
Well, this was no brainer. After simply unplugging the device for about 24 hours, everything went back to normal. Seem that the player is still having this problem from time to time, probably Bios related. I have also advise Toshiba support of the problem and the workaround. Hopefully, they will come with a permanent solution to that problem.
Have a nice day
Dec 30, 2008 | Televison & Video
Samsung syncmaster 2253BW blurry/out of focus HELP!
cables wont make a difference, are you sure your display settings are set to 1680 x 1050? i have had problems when it is set to 1600 x 1000 and i had to reinstall the video card drivers.
Dec 28, 2008 | Samsung SyncMaster 2253BW LCD Monitor
Color Issues
this sounds like a connection problem. are the scart or av leads ok whatever you are using ? if so then the most likely cause is the signal interface inside the tv. try connecting with a different connection system
Dec 13, 2017 | Samsung TX-P2730 TV
VHS to DVD
I just bought at Best Buy the Samsung DVD Recorder & VCR. You can copy your VHS tapes right to DVD and or hook up an external source into the deck and copy them to DVD.  I find it working well but many of my tapes have tracking issues which is becoming a hurdle for myself.
Apr 22, 2008 | Samsung DVD-V4600 DVD Player/VCR
Blue tent while playing movie
what type cables are hooked to the dvd, check and make sure that the cables are seated properly or chang the cables , could be the dvd player also
Feb 16, 2008 | Samsung LN-T4671F 46 in. LCD Television
Blank Screen Problem
Does the menu come up? If it does, then, the source could be the problem, such as the cable or DVD player. If the source is not the issue, then, the problem would be in the Digital or Analog PCBs. If the menu does not come on, then, the problem is more than likely the DMD. If it is not the source then call a local authorized Samsung servicer in your area. Contact 1-800-Samsung. Hope this helps.
Apr 01, 2007 | Samsung HLP6163W 61" Rear Projection...
Red blue gren dotty
Hi
your monitor is 100% ok check your Vcd/DVD Connection
Mar 06, 2007 | Samsung SyncMaster 740N 17" LCD Monitor
Samsung SyncMaster 2253BW LCD Monitor Logo
176 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
