Question about LG RU-52SZ51D 52" Rear Projection HDTV-Ready Television
LG Rear Projection Model PT-53A83T Convergence Problem
Hello
My picture had a Red line on the left and now the picture is warped on the top and botttom. The Red colour seems to have moved out of alignment. I tryed to align it with the Convergence Screen but the Red only moves side to side. It doesnt move up or down. The blue colour is fine to move up or down. What do i need to do to fix this? Please Help.
  • devinderr Oct 14, 2008
    I have the same problem for LG Rear Projection TV Model No. SDNVW 143 cm. Set is 4yrs old. Is worth to repair it and how much it cost?
Sank
Posted on Sep 24, 2008
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
We have a PT-47WX51CE panasonic cinemavision hdtv 1080i and the colour is off. We see separated mainly green and magenta and the picture is warped with some lines.
All that mess in picture is due to failure of convergence output chips in this tv.
Replace convergence output ICs (two ICs) to solve picture problem. Required ICs are available in Part Store, click the link to have price info.
Thanks.
Jun 25, 2010 | Panasonic PT-47WX51 47" Rear Projection...
Blue convergence wont work
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly. 4) TV Chirps
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 05, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic pt-47wx53g red is out of convergence range
Have you moved the TV recently?, if so the red can(Red source) in the back bottom of the TV may have physically shifted in its holder, this is common when a rear projection tv is moved, jostled. Take the back off, look at the three cans,Red, Blue, Green, see if they all look like they are nested the same, bet the red is shifted a little.Good Luck with it!
kskip69
Aug 22, 2009 | Panasonic PT-47WX53 47" Rear Projection...
RED ARCH ON LEFT BOTTOM CORNER
This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
Jul 16, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Red and blue ghosting,
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 12, 2009 | LG RU-52SZ51D 52" Rear Projection...
The picture is pushed to the left of the screen. Reds are VERY red.
  • Screen looks 3D
Jul 01, 2009 | Panasonic PT-53WX53 53" Rear Projection...
PT47WX52F Convergence problem, 3-d look, green worse
So you are able to adjust? the crosshairs move left and right up and down. you might have to get a tech to adust it in service mode.
Feb 24, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Samsung 52" rear projection tv convergence problem?
THE PROBLEM IN YOUR TV. IT'S THE CONVERGENCE. YOU NEED REPLACE THE CONVERGENCE STK'S AND AFTER THAT YOU NEED DO ADJUSTMENTS.
Jan 14, 2008 | Panasonic PT-47WX49 47" Rear Projection...
LG RU-52SZ51D 52" Rear Projection HDTV-Ready Television Logo
165 people viewed this question
Computer Repairing
Computer Repairing
