Sony RDR-GX315 DVD Recorder Logo
Posted on Aug 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I'm trying to record home vhs tapes to this Sony DVD Recorder (RDR-GX315) and not sure how the hookups should be to do this? My VHS player has only 2 video in and out plug ins.. Please help! Thanks, Heidi
Grubhead
Level 3:
  • Sony Master 5,755 Answers
  • Posted on Aug 21, 2011
 Grubhead
Sony Master
Level 3:
Answers
5755
Questions
Helped
1662433
Points
11417
If the VHS player has a scart socket you can connect it to the Sony using one of these converting connects.
I'm trying to record home - grubhead_16.jpg Check out this link too
http://esupport.sony.com/perl/support-info.pl?info_id=75&mdl=RDRGX315
3answers
I have a Panasonic DMR-ES30V. I've only ever recorded from what I'm watching on the TV to a DVD. I now have a VHS tape that I'd like to record to DVD. I tried starting the dvd to record...
Most Combo Recorders (VHS and DVD) will prevent you from
recording a Copyrighted VHS tape program onto DVD.
Try recording a TV program onto your VHS tape, then
transfer it to your DVD and see if your new DVD recording
will work or not.
Our Sony dual recorder has been spitting out the vhs tapes after a couple of mins being played. And no shows are being recorded.
First, make sure you got a good quality tape. Bargain tapes can destroy a recorder before its time. Run a Cleaning Tape to get rid of dust on rollers.
Cannot play DVD's on different recorder
did you finalize the disc? if you didn't it will not play on other dvd players
2answers
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Why is my vhs tape immediately ejected from my Sony DVD/VHS machine, tapes will not stay in long enough to record or playback.
mechanical problem usually in rubber belt types it has to replace new belts for it was already worn...
3answers
Will not record on a DVD R
what I would do is play the vhs tape for a bit then rewind and press the dub botton only and see what happens. if nada then insert a new blank dvd and make sure its formated.
4helpful
SONY DVD RDR-GX315
Turn off recorder. Hold the on/off button on the dvd player for a few seconds. until "CHILD LOCK" disappears. The child lock is now disengaged...Check page 37 in the manual (I found it online -- same thing happened to my player -- I just freed it)
www.manualshark.org/manualshark/files/4/pdf_6908.pdf
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
