Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Side by side daewoo american frige freezer
My water dispenser keeps shooting out water had it just over a year
than you
    Problem Solver:
  • 18 Answers
Many possibilities, calcium build up broke loose and a granule is stuck under valve, pivot screw loose or missing, rubbe seat hard or cracked, first see that vale accuater ( the thing you push your glass against is un obstructed and moving freely, then try rapidly opening and closing, to dislodge any thing. If that doesn't work shut off water and disconnect, past ice maker valve, blow
back ward with clean compressed air ( 5lbs psi ) while holding dispenser valve open. Reassemble and test. this should do it , if not start looking further.
Posted on Sep 09, 2008
I have a Daewoo FRN U20DA type american fridge freezer. The Ice maker has sropped working. There is no water getting into it. There is water getting through to the water dispenser in the front door. the...
The water filter should be changed every six months, not two years.
The water lines may still be frozen even though you turned the unit off, but most likely you are not getting water flow due to a clogged filter. Change it.
Feb 26, 2011 | Daewoo Freezers
Water is accumulating and freezing on the bottom of the freezer
Apr 26, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have just bought a Daewoo FRN-U20DC fridge-freezer with dispenser i did not know it had to be connected to the water mains when i bought it, i have to keep the frige in my dining room as theres no space...
If you want to make use of the facility provided by the fridge then you will have to fulfill its requirements. Else it will not dispense. You may like to take the toughest way. Attach an elbow and a vertical pipe to the water inlet and keep filling it at regular intervals depending on the consumption. You will have to use a funnel and keep the pipe going higher than the fridge. Will look very odd and you will get bored of the procedure in no time. Might as well think of attaching the water pipe to the fridge. Choice is yours.
Mar 03, 2010 | Refrigerators
Ice maker & water dispenser won't work
I recently found out that the water supply lines are coiled up inside behind the frige on the refrigerator side moving the unit will cause those coiled up lines to shift to the freezer side of the unit, causing a freeze up,take the cardboard lower back off and move those lines further away from the freezer side of the unit, as one of those coiled up lines are to chill the water for the dispenser and the other is supply for the icemaker, this should fix your problem, becareful not to move them too far away from the freezer side as they are meant to chill the water for the dispenser
Jan 16, 2009 | Frigidaire FRS266ZDSB Side by Side...
Samsung american fridgefreezer
2 years is much too short for starting problems with a refridgerator contact your dealer for a condition because of warranty on the repair you eventual will spend on it. Hidden defects are factory falts are there some holes for melting water are clogged inside the fridge somewhere
An ordinary refrigerator is made for a 17-year life span. like brands as Bosch Siemens Kuppersbusch easely have that lifetime but your dealer is the right point to get your service .
Aug 18, 2017 | Samsung RS2630SH Side by Side Refrigerator
Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Dec 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Water running down door & dispenser light always on......
If you trace up from the water leak it must have an origin. If it starts high level I would suspect the door not sealing allowing warm air to be chilled down cold enough to condense. If it starts around the water or ice dispenser you may have a bed connection or break in the supply lines. I am assuming this is on the freezer section. It would also account for the light as there are normally door switches for the light and fan. If you open the door on the freezer section and push on the switches you should see the light go on and off. Hope this helps, water leaks are always a pain even for engineers.
Aug 17, 2007 | Whirlpool S20DRSS33 Side by Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
88 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
